Air France Flight Missing
Correct me if I am wrong, but didn't the Airbus that crashed over long island have some issue during it's manufacture? I remember reading somewhere that the tail had been damaged at the factory and that was a major contributing factor. Anyone?
If that's the case, not good for Airbus.
Here's some NTSB copypasta for ya:
No deviations from the original design and materials specifications were found in the vertical stabilizer (including the repair to the left center lug area that was made during manufacturing) that would have contributed to the vertical stabilizer separation. Also, a detailed inspection of flight 587’s wreckage, including an extensive examination of the vertical stabilizer main attachment fitting fractures, revealed that each main attachment fitting had features that were consistent with overstress fracture and exhibited no evidence of fatigue features or other preexisting degradation.
http://www.ntsb.gov/publictn/2004/AAR0404.pdf
UK papers now saying French suspect that the pilots stalled the airplane. I'm not a commercial / ATP (only PPL) so don't understand the aerodynamics of high altitude / high speed stalls. Do know you slow down to aircraft specific speed to penetrate turbulence.
Would appreciate your insights...
Thanks,
LAFF
Vb is the turbulence penetration speed and is usually right about the same as LRC (long range cruise) at those altitudes and weights so no adjustment is usually required. Just hang on.
Most airlines don't teach very much when it comes to radar, unfortunately. It's becoming a lost artform.
I went through one green echo on my first night flight in the ITCZ last summer. That was also the last time I'll do that.
Rant time, here: Why the heck can't we have a real time satellite uplink of radar and sat imagery?? The technology is easily there, it's not very expensive and freaking Cessnas have it and 99% of airliners don't. Heck on our PTV equipped planes the passengers have better "big picture" weather than we have.
-Good point.
The answer is: Airlines are run by the cheapest bastards in the history of cheap bastards-thes guys will not spend any money (except for each other's bonuses) if they are not forced to do so.
-I evny the avionics capabilities most Cirrus and Cessna guys have every time they talk about it!
Thanks,
LAFF
Yea, just like you want to keep your 172 in the green arc on the airspeed indicator in turbulence.
I hope they can figure this one out, but I would bet that most of it will remain a mystery.
probably will be the most intensely investigated aircraft accident in history. The recovered parts of the Titanic from that depth so they should be able to get the recorders.
Actually the HMS Titanic is in water about half the depth of some of the wreckage.
http://news.yahoo.com/s/ap/20090604/ap_on_re_la_am_ca/brazil_plane
Interesting part of the article. No idea how true it is though...
The messages detail a series of failures that end with its systems shutting down, suggesting the plane broke apart in the sky, according to an aviation industry official with knowledge of the investigation who spoke on condition of anonymity because he was not authorized to discuss the crash
France's accident investigation agency said only two findings have been established so far: One is that the series of automatic messages sent from Flight 447 gave conflicting signals about the plane's speed; the other is that the flight path went through dangerously stormy weather
The last message from the pilot was a manual signal at 11 p.m. local time Sunday saying he was flying through an area of black, electrically charged cumulonimbus clouds that come with violent winds and lightning. The automated messages that followed suggest the plane broke apart in the sky, according to the aviation industry official.
At 11:10 p.m., a cascade of problems began: the autopilot had disengaged, a key computer system switched to alternative power, and controls needed to keep the plane stable had been damaged. An alarm sounded indicating the deterioration of flight systems. Then, systems for monitoring air speed, altitude and direction failed. Then controls over the main flight computer and wing spoilers failed as well. At 11:14 p.m., a final automatic message signaled loss of cabin pressure and complete electrical failure as the plane was breaking apart.
Patrick Smith, a U.S. airline pilot and aviation analyst, said the failures could have begun with a loss of electrical power, possibly as the result of an extremely strong lightning bolt.
"What jumps out at me is the reported failure of both the primary and standby instruments," Smith said. "From that point the plane basically becomes unflyable."
"If they lost control and started spiraling down into a storm cell, the plane would begin disintegrating, the engines and wings would start coming off, the cabin would begin falling apart," he said.
The pilot of a Spanish airliner flying nearby at the time reported seeing a bright flash of white light plunging to the ocean, said Angel del Rio, spokesman for the Spanish airline Air Comet.
"Suddenly, off in the distance, we observed a strong and bright flash of white light that took a downward and vertical trajectory and vanished in six seconds," the pilot wrote in his report, del Rio told the AP. The pilot of the Spanish plane, en route from Lima, Peru to Madrid, said he heard no emergency calls.
The New York Times reported that Airbus (EAD.PA) issued a warning on Thursday to airlines that pilots should follow "established procedures" if they suspect airspeed indicators are not working
The New York Times said Airbus told clients "there was inconsistency between the different measured airspeeds" in the Airbus 330 that crashed, though the company noted it was not prejudging the investigation's outcome
at 0210Z : from bottom to top :
- AUTO FLT AP OFF
-F/CTL ALTN LAW
- FlAG ON Capt PFD
- FLAG ON F/O PFD
- AUTO FLT ATHR OFF
- NAV TCAS FAULT
- FLAG ON CAPT PFD
- FLAG ON F/O PFD
- F/CTL RUD TRV LIM FAULT
- EFCS2...1..EFCS1...AFS
- EFCS1...X2..EFCS2X
at 0211Z :
- FLAG ON CAPT PFD
- FLAG ON F/O PFD
at 0212z:
- NAV ADR DISAGREE
- ISIS ....ISIS
- IR2...1,EFCS1X, IR1, IR3
at 0213Z :
- F/CTL PRIM1 FAULT
- F/CTL SEC1 FAULT
- AFS 1 FMGEC1
On Wednesday, searchers recovered two debris fields and had identified the wreckage, including an airplane seat and an orange float as coming from Flight 447. Officials now say that none of the debris recovered is from the missing plane.
I don't know what to think from all of the news reports. Everybody is speaking on a condition of anonymity, and contradicting what info has already been released.
Yeah this just came out on CNN as of now. This story is just becoming werid. Dont know who, or what to trust anymore...
http://www.cnn.com/2009/WORLD/americas/06/04/plane.crash/index.html
The Brazilian air force said that debris picked up Thursday near where officials believe Air France Flight 447 crashed Monday into the Atlantic Ocean was not from the plane.
"It has been verified that the material did not belong to the plane," Brigadier Ramon Borges Cardoso told reporters in Recife about the material recovered Thursday. "It is a pallet of wood that is utilized for transport. It is used in planes, but on this flight to Paris, there was no wooden pallet."
He added that oil slicks seen on the ocean were not from the plane, either, and that the quantity of oil exceeded the amount the plane would have carried.
"No material from the airplane was picked up," he said.
The announcement left open the question of whether other debris that had not yet been plucked from the ocean might be from the plane.
So after all this talk of debis being plucked so far, none of it aparently is part of the bus. Where would such an oil slick come from? Must be one hell of a leaking ship, or something...
The BBC initially reported the story of the wreckage as to not being from AF447 and only CNN has picked it up.
- AUTO FLT AP OFF
-F/CTL ALTN LAW
- FlAG ON Capt PFD
- FLAG ON F/O PFD
- AUTO FLT ATHR OFF
- NAV TCAS FAULT
- FLAG ON CAPT PFD
- FLAG ON F/O PFD
at 0211Z :
- FLAG ON CAPT PFD
- FLAG ON F/O PFD
at 0212z:
- NAV ADR DISAGREE
- ISIS ....ISIS
at 0213Z :
- F/CTL PRIM1 FAULT
- F/CTL SEC1 FAULT
- AFS 1 FMGEC1
That's ugly on a CAVU day in CONUS ops. Avionics fire????
The Pig.
