Ailerons
UnAnswerd
Activity Terminated
In the history of fixed-wing aviation, has there ever been any other means of banking the aircraft, other than ailerons? Any odd-ball setups out there, that do not use ailerons???
Yeah, MU-2s and Beechjets use "spoilerons". They are basically small spoilers that extend and retract on the top of the wing.
1903 Wright flyer used a system that warped the entire wing. I am not sure but I think the flying wings use a system that is mostly spoilers and no or tiny ailerons. Only ones I know of.
The MU-2 and Beechjet do not have spoilerons - Lear 35s and Boeing 727s have spoilerons. They use straight, old-fashioned, honest to goodness spoilers and nothing but spoilers for roll control. They use small trim ailerons for roll trim.
'Sled
'Sled
Ah. Well then... I stand corrected.
There is also some experimentation on wing warping on the F18. Easy to bank the airplane at +1 Mach.
The A-5 Vigilante used 2 sets of spoilers, one facing forward on the bottom of the wing, and another facing the normal direction on top of the wing.
Don't feel too bad, a lot of people are under that misconception. There are also a few light planes that use spoilerons - the Wren modified Cessna 182 has what are essentially spoilers on the top of the wing that work in conjunction with the stock ailerons. I believe that Helio Courier uses a similiar system as well.
Back to the original question...
In response to the United DC-10 accident in Sioux City, NASA has be experimenting with a computer program that allows for full aircraft control using differential power inputs.
'Sled
The rudder will do it under high AOA. In the T-38, it can actually roll the jet BETTER than the ailerons if you're deep into the red chevron.
'Sled
Gee, all that time in a B-727 and I never knew I had "spoilerons". Please educate me some more. <bg>
~DC
It's been 20 years since I was last in a 727, so I don't remember the exact flap setting when the spoilers started working in conjunction with the ailerons. Regardless, when you've got spoilers and ailerons working together - you've got spoilerons.
I knew you knew that. ;)
The Lear 35 also has a similiar system, it's been 10 years since I've flown one of those, but I believe that you get differential spoiler operation to augment ailerons with flap settings greater than 20 degrees.
'Sled
