TonyC
Frederick's Happy Face
- Oct 21, 2002
I don't believe anyone will argue that rules based on science that incorporate the effects of circadian rhythms would be far batter overall than arbitrary limits based on well-intentioned yet less well-informed advocates of safety of flight. However, removing one of these arbitrary rules in favor of NO rule hardly accomplishes that goal.dgs said:The key to success was your circadian rhythm. The research clearly supports this.
You acknowledge that the best solution will be, by its very nature, complex. How, then, can you advocate the simple removal of a strict rule as part of a solution to your problem. (As far as I can tell, the only problem you seek to alleviate is the LGB layover followed by a LGB-JFK redeye.)dgs said:Unfortunately, trying to legislate common sense seldom works. You just can't cover all the possibilities without making the regulations incredibly complex.
Again, I must ask: How does removing a sensible limit qualify as a "baby step" in the quest to overhaul the current system into a complex set of rules that recognize circadian rhythms?!?!dgs said:However, the European solution seems to make a lot more sense than FAA rules that allow some very tiring trips. Maybe we need to take some baby steps before overhauling our entire system of rules on crew rest and flight time.
In the utopian Blue world, it must seem that everything WILL work out the way you dream, and if by some incredibly minute chance it does not, all will STILL be well. It will be a simple matter to go back to the FAA and ask them to reinstate the rule, or rescind the exemption, and all will be well. Of course, the ONLY trip that will be affected is the JFK-LGB-JFK trip, and pilots will always have full control over pairing construction and scheduling parameters. In fact, you could probably have the FAA incorporate that language into the exemption you seek, just to be sure, right?dgs said:The guys who are working for this change at jB are trying to improve pilot quality of life and safety. They also happen to be the same pilots who build our trip pairings. They are not management pilots trying to "screw" the work force. Quite the contrary, they are line pilots on the scheduling committee who are trying to improve our personal productivity and quality of life. If these pairings are popular, they will continue. If nobody likes them, the scheduling committee would react accordingly. Personally, for the reasons stated above and based on what I've seen with our flight attendants, I think these trips will be very popular and will go very senior.
That's exactly right, you cannot control how other companies WILL pervert any rule change. And you can NOT control how JetBlue will pervert the rule change, either.dgs said:We can't control how other companies might pervert any rule changes we ask for, but that doesn't mean the changes aren't a good idea that enhance both safety and productivity. Ultimately, if the FAA approves this exemption based on scientific data, we should claim it as a victory and a step in the right direction to improve our lives and our performance, as better rested pilots.
BUT, you can pat yourself on the back as you arrive in the JFK terminal area at the end of your 16 hour day and look at the TCAS targets that surround you. They also will be affected by any rule change, and may not fare as well in the rest department as do you, with your blue pairings and blue schedules. Just like you, they'll be more "productive," and just like you, they'll be the worse for the wear. Look at the TCAS again. How many of those crews will be fully rested, and how many will be the victims of your rule change, stretched beyond limits of fatigue in the quest of productivity? How many will be safe? How safe will you feel?
P.S. I couldn't help but notice the personal pride you showed in supporting an effort to make yourself "more productive." Productivity is essentially a measure of how much work can be extruded from a commodity for how little cost. That would make YOU, the pilot, the commodity. Even JetBlue considers you to be a commodity, a cost center. Don't fool yourself. If you really want to be more productive, why not offer to work for half pay? That would double your productivity, right?
You ought to talk to some folks that used to live in a purple utopia. You might be surprised.
