Read my post. I never said anything about how, why, where ETOP proving runs can be done. I just said it was not a proving run, it was a new aircraft delivery.
New delivery??? Over the pacific?? Thought A320's were make in France? Also the crew was chatting on 123.45 with a UsAir crew. They said they were flying to test the route out? see if it could do it?? Could have been BS but VA guy was asking the Cactus guy about somebody he knew was trying to get on the airways flight.
Head,
Yes, VX will be going to Hawaii. Pick up our first Bus w/ winglet's, which will make the crossing in Sept of 13'. Going to be a very good route for us as well...lots of requests from our guests for the route.![]()
Head,
Very good? Meaning full seats? Have you seen the yields to Hawaii?
One of the problems with Hawaii is that flights have boatloads of non-revs, both ways.
The company is pretty agressive in pushing for approvals.
" We also plan to do CUN with a more efficient routing."
How would any route to Cancun from the U.S. require ETOPS?
The reason I ask is the fact that ETOPS does not help with a more efficient routing to CUN from any U.S. city pairs.
Hawaii notwithstanding.
Airbus has an A320 final assembly plant in Tianjin, China. Opened in 2009 I believe.
China to SFO? I think you would have to fly up and over though Alaska for that.. ??
Yes, the routing is the same as the usual extended overwater route vs the 162 nm rule route. The ETOPS MX & MEL compliance experience is the difference and necessary to get the A320 from 120 minute to 180 minute ETOPS.
Since we do not presently have EOW in our ops specs, just the 162 MN exemption it will save us time on route.
And I don't think the A320 has the legs to do HNL CUN nonstop, but I wouldn't mind such a pairing in something bigger some day!
So the aircraft dont have dual HF? The Gulf does have a portion where you do enter class II airspace. You either need dual HF or you can apply for a exemption to operate without it.
SKC is correct....Op Spec A013 allows operations up 162NM off a coast- "Conduct extended overwater turbojet operations without the required emergency equipment" (life rafts). The AR routes on the east coast are all within 162NM for example. ETOPS allows operation greater the 60 minutes from an adequate airport (for a 2 engine aircraft), has nothing to do with flying over the Gulf.... a B757-200 60 minute range (1 engine out, still air) is about 435NM
The 162nm rule for ops without rafts. With rafts (non ETOPS), you're limited to the one hour from an alternate or ~300nm.
This is the crux of the issue as I read it. As of now, VA is limited to the 162nm limitation on the SFO/LAX - CUN flights requiring an excessive routing near land when crossing the east coast of mainland Mexico over the gulf to CUN. In order to exceed the 162nm limitation (out to an approximate 300nm limit) VA needs to install life rafts. VA's plan seems to be to proceed with ETOPS certification, which will both satisfy the CUN "shortcut" and eventually allow for west coast/Hawaii service.
S
A320 is just over 400nm off shore.
SFO-CUN isn't ETOPS. And delivery flights are Part 91, no ETOPS required.
Bingo! You got it.
We will need ETOPS "experience" to push the new sharklet & NEO busses from 120 minute to 180 minute ETOPS. Mexico routings will be one of the ways to get it. The other is conducting the delivery flights under ETOPS, even though we could do them FAR 91.
You can be certified 180 minute ETOPS initally without first holding 120 Minute certification.
MTV
