8 hour flight time limit
Eric
See you in the Wasatch!
Question:
You are scheduled for just under 8 hours in a day. You are delayed along the line and you know your last leg will put you over 8 hours. Are you legal to finish? (I'm warming you up with the easy one) I think the answer is yes.
How about:
You are scheduled for just under 8 hours, and on your last leg, you divert. Now, after you have waited out the weather, are you legal to fly to your original destination since the divert wasn't on your original schedule?
Let's hear it
Question:
How about:
Let's hear it
Yes because it is a continuation of an original flight.
Question:
How about:
Let's hear it
First case yes, second case, if you land at the diverted airport and have over 8 hours, you are done for 16 hours (or twice your flight time).
Hi!
This from the pov of scheduled -121, from what I remember at TSA ground school in 2001.
The old way of interpreting the regs was legal to start a trip, legal to finish. That changed to a leg-by-leg evaluation at some point. The FAA re-interpreted their own regs and they were sued by the ATA which claimed that the FAA re-interpretation amounted to creating new regs. The FAA won, which is why the scheduled airlines now use the leg-by-leg method.
If your trip/day is scheduled under 8 hours, you're legal to start. Then, u have to evaluate each leg separately.
If, on your last leg, it should take you 45" of block time, and you block out at 7+00, u r OK as you would block in at 7+45. However, if you then took a 20" taxi delay, you CAN'T takeoff, as that would put you at 8+05 at the end of that leg. U have to taxi back to the gate and the airline will get a new crew to fly that leg.
Now, if you did block out at 7+00 for the 45" block time leg, and you took off normally at 7+05, and then, enroute, you took a 30" holding delay, for example because of ATC requirements, you would now block in at 8+15. In this case, U would be perfectly legal, because the delay was IN FLIGHT during your last leg and out of your control.
So, in both cases the answer would be no, you can't block out knowing u will be over your 8+00 when you block in.
This is what we were taught at TSA, which is a scheduled, 121 carrier. I now work at a 121 supplemental carrier, and they fly legal to start-legal to finish. They are allowed to do this either because it is supplemental, or our local FSDO allows it.
If it's only because our FSDO allows it, that is bad, because if something were to happen, then FAA HQ could easily violate the pilots and our co. by saying the FSDO was interpreting the regs incorrectly, and we would be screwed. This has happened recently with the charter/broker situation and what different entities are required/allowed to do with regards to flying charter PAX aircraft.
cliff
YIP
Note: I don't use the 121 regs with the aircraft I operate, which is why I don't understand the 121 vs. 121 supplemental differences situation so well.
Completely untrue. We go over 8 all the time. Legal to start legal to finish. Heck with the delays in EWR this year we've had guy doing 10 hour flight timed days.
Not agreeing or disagreeing with your statement, just qualifying. Just because something is being done over and over, does not make it legal. I can point to a couple of things my current employer had been "doing" until the FAA slapped their hand and said, I don't think so.
Here's another twist to that question. Before coming to work, your trip is scheduled for 7:58 minutes of flying. Duty day is not a factor here, lets say. When you show up and check in, it now shows a flight time day of 8:10. Dispatch has amended the times. Are you legal to start and finish that trip if it will take you over the 8 hours?
Yes, I believe it was Delta that had the FAA get an official interp on this one. The flight was originally scheduled for under eight hours. The time on the flight plan is irrelevant here.
Wrong. You need only to look back and see your 8 hrs rest in the last 24hrs (unless you were on reduced rest). You could be scheduled for 7:50 flying and on you last out and back, divert then fly to your origional scheduled destination and land at 12 hrs block time; as long as you can look back and see 8hrs in last 24 (and you will be able to do this at your estimated duty off time back at base) you are legal to go. In theory if you you can fly 16hrs minus the time it takes you turn the plane and duty off...this is not to say it is safe or smart to due so.
