moxiepilot
Florida Pimp
- Apr 13, 2005
Not quite. If the pilot reports, "Traffic in sight," it gives the controller a green light to issue a, "Maintain visual separation from that aircraft," instruction and THEN it is the pilot's responsibility to maintain separation - UNLESS he reports, "Traffic no longer in sight."zbwmy said:"As soon as I report traffic in sight I then must take on the complete responsibility for separation.."
WRONG...you have to also advise you are taking corrective action, or I have to continue giving you traffic.
You've got the wrong attitude here. It's not about being a jerk. It's about staying away from other aircraft. Facilitating that, whether it be in VMC or IMC conditions is YOUR job when it comes to IFR traffic. I will call traffic when I'm darn good and ready thank you very much and if I never do then separation responsibiity remains with YOU 100% of the time. If that's the way I want it, that's the way it's gonna be. It's as much a tool for me to use as is for you.zbwmy said:"Why should I do that when there is an ATC guy who can help me just in case I get busy and loose sight of that traffic? "
Because I am busier than you..if you see the traffic, call it in sight. If you want to play go IFR. Don't be a jerk
I'll agree with this as an across-the-board rule as long as the PF is the PIC. There are instances when the PF is the SIC and their judgment about what's a safe margin of separation and what's not is not all it could be. PIC authority must enter into it fo rthis to be a valid rule.LAXSaabdude said:Even more important, when in a crew environment, the NFP should not call traffic unless the PF has it in sight.
Point well taken. I guess I just take my "veto authority" as PIC for granted, and forgot to include it. I was just saying that at NO time should the NFP call traffic unless the PF has it, regardless of seat.TIS said:I'll agree with this as an across-the-board rule as long as the PF is the PIC. There are instances when the PF is the SIC and their judgment about what's a safe margin of separation and what's not is not all it could be. PIC authority must enter into it fo rthis to be a valid rule.
A better way to do this is make sure that BOTH pilots see the traffic before calling it in sight. While I understand that this is not always possible on those occasions when it is a better level of situational awareness is created by it. You can always have a discussion about it if only one guy has the ability to see a traffic point out but that should, and almost always WOULD be the exception rather than the rule.
TIS
FlyChicaga said:We should start a thread, "The Top Ten Reasons I Love TCAS".
I haven't seen SOCAL do this in a long time but they used to pull something that I just couldn't believe was legal until I had a friend at ASRS tell me it was.EagleRJ said:The only pet peeve I have with ATC and seperation is the way some facilities will attempt a visual so they can tuck you in behind a heavy and move more airplanes. Socal Approach (LAX) and NY Approach (JFK) are notorious for this.
is it any wonder?EagleRJ said:Some pilots at Eagle would refuse to play the game, and wouldn't call the heavy, even when it was right in front of them.
TIS said:I haven't seen SOCAL do this in a long time but they used to pull something that I just couldn't believe was legal until I had a friend at ASRS tell me it was.
The plan went like this. The airport is "VFR," by METAR only - not really a true statement from a practical standpoint in a jet moving at 3 miles a minute. This means visual approaches are possible. They point out some big guy headed for 24L - he's doing the ILS. You call him in sight. Bingo-bango, "Maintain visual separation from that aircraft, he's for the left, you're for the right, cleared visual approach to 24R." Yep! That's right! You're doing a visual approach by following a guy doing an ILS to the parallel runway! TIS
Vector4fun said:TIS,
I'm sure I don't grasp the whole "picture" here, but I'm curious why you'd feel less comfortable being, say 2 miles away from the guy on a parallel final and being able to see him, than you apparently would being 2 miles away and being solid IMC, which would also be quite legal. You've both got a localizer to track.
