Weapons
Most gun laws are illegal anyway no matter what some idiot judge, politician or lawyer says.
You're a militia, are you? To which militia do you belong? You belong to a well regulated militia?
You hear what you want to hear, and appoint yourself to interpret the constitution. You disregard the government established under the constitution, and the judiciary which was established as one of the three divisions of government...and which was established not only to adjudicate the law, but to interpret it, and the constitution.
Fortunately for those of us who honor, uphold, and obey the law, your opinion on the matter has no weight nor authority...and does nothing to change the efficacy or legality of firearms legislation and code...nor the fact that this thread is about crewmembers with weapons when operating under Part 135...to which you've contributed nothing.
As for stupidpilot who was done with this thread a number of posts ago and can neither contribute to the topic or quit...the name still fits.
"You belong to a well regulated militia?"
LMFAO!!!!
That is the whole concept of a malitia, NO REGULATION!
The problem with this country is people like you that think the Constitution of the United States is of no consequence or irrelevant to your own ideals or agendae.
No one man, agency, or group can ratify or amend the Constitution. Every change requires a 3/5 majority of congress and 75% of the States.
Unless, you're in the 9th Circuit Court of Appeals, the Supreme Court or Nancy Pelosi. Then you can say or do whatever the hell you want and call it Law by "popular vote".
100-1/2
It's militia, brightspark.
You'll not be contributing to the thread by discussing the carriage of weapons by crewmembers operating under CFR Part 135 either, then? Very well.
While you're busy expounding on the constitution, you might consider that the 2nd ammendment is just what it sounds like...and ammendment. If you're one of the "constitutionalists" who can't fathom or stand for anyone or anything adding to, interpreting, or ammending the constitution of the United States...bear in mind that the 2nd Ammendmant is just such an act. The Constitution was intended to be a living document.
That said, while you're quite certain that a militia can't be regulated, why do you suppose it is that the 2nd ammendment speaks to a "well regulated militia?" You really can't have it both ways...you can't stand on the 2nd ammendment and then suggest that a militia can't be regulated...as the right to keep and bear arms is predicated on the requirement for a well regulated militia. You understand this concept? You might like to pick and choose the parts of the law you'll obey or support...but you really can't. Especially when they're found in the same paragraph.
I really shouldn't open my mouth but way back at the beginning of the thread:
The aircraft is private property. Noone has the authority to enter it without your consent ...
The key word in this discussion is consent.
Avbug has not been saying that in all situations, LEOs have the right to search the aircraft, he has been saying that in some jurisdictions they do. The thread segued into reasonableness and probable cause but that was a mistake-- the doctrine at question is implied consent. In some jurisdictions, merely by virtue of landing at a [public use] airport you may have consented to a search of the aircraft. The onus is on the pilot/operator to know the regulations that pertain at each airport they visit. He's at least mostly right.
Implied consent gets applied often in DUI cases-- in many states you have consented to a breathalizer (a type of search) merely by operating a vehicle on public roads. This has been routinely upheld! In other cases such as search of a vehicle or apartment, the doctrine is sometimes upheld and sometimes denied by the courts. I am not aware of any case where it has been applied to an aircraft search, which may be part of the problem with this thread.
Often in legal cases where limited precedent exists, the question of the alleged infraction is measured against the actions of the 'reasonable person'* in the same situation. Pt 135 pilots being presumed professionals they would be held accountable to higher standard than a pt 91 owner/operator.
I think it's entirely reasonable to suppose in absence of cited precedent that:
In the case where flight goes from ABC to XYZ where XYZ does not permit firearms on airport property and there exists an implied consent law:
pt 91 pilot is let go
pt 135 pilot is charged and found guilty because the 135 would be expected to have known that he was flying into a location where his firearm was not permitted (absent other conditions such as federal deputizing, etc), since as a professional he is assumed to take greater care in his planning than an amateur (not a dig at professional 91 guys!)
In the case where the flight was intended from ABC to DFG but diverts to XYZ where DFG permits firearms, but XYZ does not:
both would be let go (but probably after long and costly legal proceedings), since the pilot did not expect to be at an airport where he could not posses the firearm.
The issue does not need to be as fracticous as firearm rights-- in the freight world we're moving to the point where some airports will have local regulations requiring anyone moving on the ramp to have high-visibility vests. I can not imagine that 'We didn't know [or attempt to find out].' would be an acceptable excuse from a commercial operator, though I imagine the transient GA aircraft pilots probably won't start racking up fines. Somewhere in the GOM for my company is a line which states that the most restrictive of FAR/GOM/state/local regulation is what we're required to adhere to. I can't imagine it's different with anyone else.
It's a fine thing to stand up for your rights, or even excersise civil disobedience if you think a law is unjust. Really! But I can't imagine any working pilot who can afford to fight a legal case like this just on principle, and if your job truely does require you to carry a firearm on your plane, and your job is worth having, then it's worth the time to check the local and state regulations of the places you fly through and get clearance from the sherrifs department or whatever to carry your gun while in the SIDA.
Not a lawyer, 121/125 pilot in any case, my opinion only, etc, etc,
-TF
*-http://en.wikipedia.org/wiki/Reasonable_person [I hate citing wiki, but whatever..]
Thanks for the post Tony. It's nice to see someone on flifo post an intelligent, reasoned well thought out reply without sounding like a pompous jerk and insulting a person every other line.
That would be you, stupidpilot. The only name you've been called is...your own...the one you chose.
You, on the other hand, have repeatedly hurled insults and resorted to name calling. Over and over and over. This is, of course, the essence of stupidpilot.
You have yet, however, to address the topic at hand, or offer anything meaningful on the subject.
Or be right or correct or make a truthful statement, but I digress...
Liar.
Let me ask this: what good is a gun do you in flight sitting in your holster? Unless you have reinforced cockpit door to "slow" someone down a bit, tactically you are a sitting duck!
Quite true.
You're making the assumption that the pilot is under attack, and that this is the only reason to have a firearm. Previously, a number of situations were cited in which a firearm is of benefit in a Part 135 cockpit or a 135 environment, specificaly when it's been of value to me.
Again, numerous considerations apply regarding the aircraft being flown, the pilot, the situation, the type of operation, the location, etc.
I've flown 135 in locations where carrying a handgun was necessary just to get to the airplane, as protection from dog packs and other critters.
As for very, very stupidpilot, he or she is on the ignore list, where it belongs.
I understand if you are outside the airplane, but if its a "9/11" type of attack, any pilot with his gun in the holster is at a huge tactical disadvantage. There is no way to defend yourself from a gun, or any weapon when you are flying--no matter what your side arm is.
You might want to read Heller. The Supreme court has indicated therein that the 2nd amendment conveys an individual right to keep and bear arms.
I'm familiar with Heller, and nobody here is challenging the 2nd ammendment, the individual or collective right to keep and bear arms, the US constitution, or the court's decision. I own several firearm safes myself, each full of handguns, shotguns, rifles, and so-called "assault weapons," including Class III firearms. I hold multiple carry permits, have carried professionally, and continue to carry firearms in various capacities.
I'm one of the last that anyone has need of preaching to regarding firearms use, ownership, or the rights thereof.
Firefly asserts that all firearms laws are illegal. This can be immediately discounted as idiotic. 100-1/2 asserts that a militia can't be regulated. Also clearly in error and contrary to the wording of the 2nd Ammendment itself.
Neither of these assertions, nor the remainder of the sentiment attached to those posts address the topic of weapons and 135 crewmembers.
There certainly is a way to defend, though it may cost one one's life. This isn't particularly significant, however, as in such an attack one's life is over if one doesn't defend. No attack is a sure foregone conclusion; defense is absolutely necessary, as you know, to the death, or conclusion of the fight.
When one comes under attack, one might always be said to be under a tactical disadvantage. This works both ways, however. One who is focused on an attack is also at a disadvantage, and has dedicated himself or herself to the act not only of attacking, but becoming a target. Never lose sight of that.
So far as operations under 135, few hijackings of charter aircraft in the US have occured in flight. Many have occured prior to the flight, when the pilot was approached on the ground. Far better to prevent the aircraft from being airborne, and possession of a weapon is or can be an advantage in preventing the aircraft from becoming available to someone who should not have it.
I have been involved in two situations, one a holdup and one a carjacking, either enroute to the airport or from it during 135 operations, when a firearm was central to my being here to type this.
In another unrelated case, while moving from one city to another (being transferred by a Part 135 operator, in fact), I had an occasion to use a firearm defensively when by coincidence I was confronted by an individual with a rifle in the apartment complex. The individual with the rifle had exited an apartment in pursuit of an unarmed person, and saw me in the passage way. He stopped his pursuit and aimed the weapon at me, forcing me to act. I wasn't operating under 135 at the time, though I was making the move due to employment with a 135 operator. Regardless, I'm a very big proponent on adequate, continual weapons training, ownership, carriage, and where necessary, use.
I submit that when one is faced with a large bull next to one's aircraft during the unloading of a patient into one's Part 135 airplane, it matters little whether the threat is an angry muslim or an angry bull. It's still a threat, and having been in that situation where the safety of not only myself, but my nurse, my patient, the ambulance crew, my aircraft, and the ambulance itself were at stake, the ownership and legal carriage of a firearm was not only instrumental in a successful outcome of the flight assigment, but to our collective wellbeing. One example among many legitimate ones in which carriage of a firearm is appropriate, and right.
From an airline perspective, the only use of the firearm is defense of the cockpit. The scope of 135 operations is considerably broader and presents far more unique situations in which carriage of a firearm is appropriate. Whereas a 09/11 style attack hasn't yet been forthcoming in modern 135 operations, other situations have occured in which possession of a firearm by a trained and prepared crewmember may have made a difference.
A fairly recent event involved the hijacking of a helicopter. The pilot was alble to make a run for it to preven the helicopter from being used, at the same time a tactical team was setting up. The pilot took gunfire in the back from the perpetrator, who was then shot by law enforcement. One might postulate that the pilot may have had a better chance from the outset while armed, though it's impossible to say with a certainty.
The fact remains that whether it's an individual surprising people in the night who are siphoning avgas from airplane tanks (a problem, locally...particularly with the economy) and running into trouble, a hijacking, or a dog pack, many applications exist in which possession of a firearm is warranted and certainly recommended. If one flies in locals such as Alaska, it's formerly the law, and regardless, a darn good idea.
I worked for a company years ago that did a large number of tours. During one of the tours, one of our pilots was confronted by a passenger with a knife. The passenger didn't attack the pilot, but attempted to kill his wife during the flight. The flight took place in a light airplane with no cockpit doors or barriers. Had the pilot been armed, the pilot would have had an opportunity to intervene decisively. Another example of an airborne 135 application of a firearm.
The list of possibilities is extensive for reasonable, legal ownership, carriage, and even use or employment of that firearm.
I flew for one company that had it's own FFL, or Federal Firearms License to deal and sell firearms. One could approach the parts counter in the shop to check out an Aeroquip mandrel to fabricate a fuel line, or one could approach the parts counter to select, purchase, and order a handgun...and every one of us did both. It wasn't uncommon for people during a lunch break when working in the shop to travel to the far end fo the runway and shoot targets on the airport fenceline. I did so on many occasions.
Heller affired what most of us already knew, and didn't improve or take away rights for most of us in free states. It made a difference in places that are restrictive, such as Washington DC where the suit took place, and it was a positive decision. It didn't change the application of the 2nd Ammendment nor discount the wording or requirement for a well regulated militia, but simply reinforced the individual freedom to keep and bear arms...exactly as per the wording of the Ammendment.
As for those who assert that firearms laws are illegal...think it all you want. If you intend to do something about it, then seek to change the view of the courts by legal means (ala Heller, Emerson, or Parker). Until then, you're obligated and have a duty to uphold and support whatever legislation, codes, laws, and regulations apply...whether you think them legal or not.
I think some people just have way too much time on their hands!
