The_Russian
Low Level Pilot
- Sep 3, 2003
Ok, so which one did he file. I am pretty sure it says NASA report:You're aware this is the ASRS program not the NASA program, right? This is not the ASAP program, either. Never has there been a breach of confidence in the ASRS program. You state otherwise; provide the citations to show your case, or stop bantying around these false allegations.
He should not have self-diclosed anything if he did nothing wrong.already sent in a NASA report and explained that I was only questioned as being an airspace violator and that it could have POSSIBLY been me but I did not believe it was.
You know as well as I do that it is against the forum rules to post names. Therefore, I am not going to give specifics. I will not be the one to cause harm to these pilots careers any further. What happened, has happened. Read the darn reg. It says:You insinuate that the FAA learned of the violations of certain aviators from their ASRS report, and subsequently used the information contained in the report to press for enorcement action agaist the pilots. False and wildly far fetched...cite the case the references to the disposition of the case, if you can. I seriously doubt you can...and if you do, you'll quickly find that you have the facts wrong.
You also assert that the FAA took the pilots jobs. The FAA doesn't do that. You assert that the pilots only lost their jobs, which the FAA took from them, rather than suffer loss of their certificate or a suspension? You must be joking.
any enforcement action except information concerning accidents or criminal offenses which are wholly excluded from the Program.
If the FAA finds criminal intent, they can take certificate action. Thats what they did to these two pilots. Even though their error was a mistake.
The FAA never took the pilot's jobs. The company did. The FAA wanted to revoke their certificates. It was a bagan between the union/company and the FAA.
Where is your proof of that? You want me to "prove it", you prove it!You keep waving about this false assertion to support your misunderstanding of the program, when there has never been such a case in the history of the program. Ever.
