Verifying the flightplan with the legs page
This is the problem when "procedures" take the place of "common sense"...Really folks, just make sure you know where you are supposed to go and that it is set....Funny how we never had a "procedure" before FMS.
The "procedures" will always change as there are many people working in cubicles who's job depends on writing procedures...
Procedures will never stop "excrement from happening" and common sense goes a long way....
FAA Inspector: Did you do the procedure?
Joe: No, I was using common sense.
FAA Inspector: Thanks, your suspension letter should be sent out in five to seven business days.
I'm sorry bud, but the minute you started working at an airline is the minute you agreed to fly per the OM and FOM. The problem with common sense is that it isn't that common. If we had no published procedure, how would pilots know what to expect of each other?
I agree that for the most part, manuals are written by those that do not fly the line. But, also for the most part, procedures are well thought out and are made to fix a problem. With ASAP and FOQA data, expect more changes to the manuals as time goes on. Course deviations are a major ASAP driver right now.
If you want to be a cowboy and fly by your rules of common sense, you should fly corporate. Especially at a regional airline, where it isn't uncommon to have a 10,000 hour pilot fly with a 1,000 hour pilot, well-defined procedures are extremely important. If a procedure isn't working, or it's unduly cumbersome, then pass on your feedback.
I've seen too many occurances where even though it looks OK on the flightplan page there is a discontinuity on the legs page. Especially when runway, departure, or flightplan changes are received The flightplan page may be quicker, but the legs page is definitely more accurate and comprehensive.
If there is a discontinuity on the legs page it will show up on the flight plan page unless you have not executed a new entry. If everything has been executed and you have a discontinuity in one place but not the other, you might need to defer your FMS because it isn't working right.
Classic.... the guy has an inferior complex.... nothing worse than a regional guy who can't go to the majors, yet has to prove himself to himself.....
As a back up... just double check the miles on the release and the FMS. Should be the same or one off..... not absolute... though...
Drew and Sweptback,
Let me ask you a few questions:
Do both of you read the entire weather package you get before each leg? The entire thing, not just certain parts of it.
If not, why not?
Have either of you read both copies of the company manuals from cover to cover? Both the aircraft and the company manual. If not, why not?
Do both of you follow every policy, procedure and rule to the letter? Have either of you ever uttered one word that wasn't pertinent to the safety of flight during sterile cockpit?
Do either of you knowingly drive faster than the posted speed limit?
I have yet to meet anyone that doesn't willingly and knowingly violate some policy, procedure or rule or alter the procedure to their liking.
I agree that there has to be some procedures. The problem is the important things get drowned out by all the useless ones. In addition, the constant changing of "little" things contributes even further to confusion and mistakes.
Examples:
Does it really matter what words you use to verify the gear is down? Why has that terminology constantly changed over the years?
How about the terms "checked", "set", "verified", "cross checked"...Those are constantly changing and I have yet to get through an "originating check" by using the "proper" terminology for every response. How about a simple "checked".
Speaking of "checklists"....How about the "cockpit check" which became the "originating check"...or the "before taxi" that became the "after start" check...
Sometimes the "solution" creates even more problems...The extensive "briefing" of minutia has IMO created more distraction and loss of situational awareness in the terminal environment and on the ground while taxing...Sometimes these procedures create even more of a hazard.
Classic, you can have the proper route in there and still be off by 20 miles depending on SIDS, STARS, and which way the airport is turned...Doesn't mean you don't have a mistake in there.
If you think procedure and following things to the letter is the key to safety and correctness, I challenge you to go fly with Jim Keet or Jeff Callibut on the 700 and tell me how safe you feel!!!! You will be begging for a little "common sense"...haha
if you think procedure and following things to the letter is the key to safety and correctness, i challenge you to go fly with jim keet or jeff callibut on the 700 and tell me how safe you feel!!!! You will be begging for a little "common sense"...haha
bingo!
Some ASA folks here wrapped around the axle about following the OM by every syllable might be comfy at Cathay. They supossedly dictate syllable by syllable how every word is uttered in the cockpit.
Remember, were NOT talking about altering SOP's here. We're not talking about skipping checklists or telling somebody to shut up and watch during an unstable approach. The OP was complaining about a procedure being changed that has been done a certain way for a long time, and the new procedure is a little quicker but really accomplishes the same thing.
The surprising thing is, Delta doesn't get anywhere near to ASA to controlling every minutia of every profile. There is a suprising lack of "procedure" for many things. Something about those 600 hour guys needing direction and hand holding for every eventuality.
I bet the Delta OM probably just says "ENSURE the filed route is properly entered into the FMS". How it's done is captains discretion. The FO's learn to go along with it.
But not here ar ASA. You ask an FO to do ANYTHING outside what is dictated by our manuals and about 15% want to argue that it's not supposed to be done that way and they're not doing it. Do you FO types record the fuel at brake release? Why not? It's in the OM. Then you question why some Captain wants to thoroughly check the route? You can't just break the SOP's you don't like and then be annoyed if somebody is EXTRA thorough.
Also trip 7, when U upgrade, you WILL feel the yoke of more responsibility on your shoulders. YOU will be the person held responsible for ANY errors committed during that flight. You will want to ensure that everything has been done properly and part of that is doing it the way YOU as pilot in command feel most comfortable doing it (without violating SOP's or the regs). Even if it is not required by the book and takes an extra 20 seconds. I promise you, the last thing you should have to tolerate is some new hire telling you he doesn't wanna do it because we don't have to.
Man all that wind for nothing. You're missing the point. I don't mind if the legs page is used as long as its not the sole method of verifying the flightplan. Lateral deviations have become quite and issue at ASA and if verifying with the legs page was sufficient they would have never changed the procedure.
Well said!
Yeah I love the FO's that want to challenge everything. But it's usually the FO's that used to be captains that are the worst. Always dread flying with those guys.
I couldn't agree more that it was a waste of breath. Some will never hear.
Our latest spate of lateral deviations had nothing to do with verifying leg by leg. It had to do with not verifying it at ALL, not the method of verification. The training dept changed it because it was quicker/easier to verify it on the flight plan page. Maybe crews will do it if theres an easier way.
Please just ALLOW those loser Captains in your seat to do it the way they feel most comfortable and be glad they have the logic to verify it at all. You sure seem to want to second guess ALOT of your Captains methods. (autopilot deferral thread)
I hope you upgrade soon, you can show everybody what a true aviator looks like, but you won't believe some of the FO's you'll have to fly with. Good luck.
I'm done. Time for a single malt
It should not be a First Officer's job to learn each Captain's individual "procedures," it should be each pilot's responsibility to know the book and do things as written. That's not to say there isn't room for technique, but every it's the company that gets to decide how much room for technique there is, not individual pilots.
You never answered my question...Have you read every book from cover to cover?
I tell my FO's, I don't care how you do it as long as we don't die, get fired, or violated in that order...Technique doesn't interest me...
Have you ever violated "sterile cockpit"? How about speeding on the highway? I bet you have ignored rules or laws you don't agree with...
Regarding the company vs. the pilot to "decide how much room for technique", as I said, I don't care about "technique", but it is my cockpit and not the companies....I will go home at the end of the day, and some of these stupid procedures make things more dangerous....Sorry for being politically incorrect, but I like to call a spade a spade.....
