UPT to Majors?
  • Thread starter Thread starter Tycer
  • Watchers Watchers 9
Tycer
Here is the situation: I took a military leave of absense as Captain from a regional for a Guard slot and am currently in UPT. After UPT, IFF and RTU I will be active with my unit for about 18 months before being a traditional guardsman. I have my applications in with SWA and Fedex. I have the type for SWA and did the meet and greet with Jack Lewis (put in the "good pile"). My question is should I keep updating my apps. even though it will be over two years before I am employable. Or should I wait until a few months before I can be employed. Should I give them a call and let them know of my situation or what. What would happen if I was called during this period for an interview? Was hoping that someone might have been in this situation and could offer some guidence. Thanks all. Fly Safe.
well.....first off enjoy UPT, it is a blast....IFF....get through it...Hawg RTU...you would be lucky if that is where you are going. USERRA law prohibits an employer to discriminate from MIL LOA. Whether future or present. Being that you are NOT active duty (title 10) they technically cannot not hire you because you are in pilot training. However they will come up with an excuse as to why you are not called...blah blah blah. You should keep updating your resume, but you aren't going to fly for crap compared to RJ slave driving. Is it really worth an update ever 6 months for 80 hours or so? It will get better when you get done with MQT at your home base. You have bigger issues to worry about than to update your resume. You will now be challenged in aviation. Especially if you get to point the nose at the ground, and stare the enemy in the eye as you unleash 200 rounds of CM 30mm. Good luck and may the guard be with you!
If you are Hawg...which unit(sts)
Update update update--even if you availablity is 2 years away. That way when you are interviewing you can say "see....I've wanted to be here for years..."
Shoot straight with airlines on availablity--playing games won't make any friends.
As always Albie is spot on...update, it doesn't hurt anything but when it calls for availability on the form, make it clear you're not available for the 18-24 months timeframe....they won't call you with an interview but your app is in & as Albie said, you have a story to tell when it comes time for the interview....have a great time at UPT & good luck.
I don't know how far along in UPT you are, but I would suggest you worry more about getting through UPT than applying for various airline jobs. Just a suggestion as I personally found UPT to be rather challenging.
Thanks for the heads ups. To anwser some of the above questions....I am about to track select for the 38's, and have done well on all the checkrides so far. I have had my apps. to the airlines long before I started upt, so I just wanted to cover my bases. I will not be going to Hawg RTU (which would be a blast), but the F-16 at Luke. Once again thanks for all the info.. Fly Safe!
I'm 28 are they lettin guys in the guard slots over 27 anymore?
You must be younger than 30 at the time you enter pilot training..After day one you can turn 30 and your fine...Typically you need at least 2 years lead time for your UPT slot so you should interview and be accepted by your unit of choice by no later than 28.
Good friend of mine interviewed while on active duty. Was offered a job, but still had to finish his military time. Airline said can you start on this date? No? OK, thanks anyway.
I would make sure if you interview you are able to accept a job.
Congratulations! I'd update the app. PIC time is PIC time. Plus you can add .2/sortie to your mil flights.
Keep your apps up to date. I got calls while in UPT for interviews and told them I was on AD for awhile but was still very interested. They all said to call when I was done to set up interviews. In the end, I did not get one of the jobs I wanted but ended up somewhere that is good right now. Who knows what the future will hold. Just keep the apps up to date and enjoy the ride. Good luck
UPT age
I know of many folks over 30 that have gone through UPT to end up with guard/reserves. The bottom line is this: does the unit want to hire you? Oldest I've heard of is 33.
B
What he said...good luck in 38s!
FastCargo
geriatric upt students
I have seen two Majors going through upt in the last year. They were both 35+ years old. If the guard wants you to go to UPT you will go, even if you are already collecting social security checks!
RedDog,
I know what he meant in the original post but someone else asked a question about how old you could be and get into UPT. I have seen people 35+ years old going through UPT and they had already pinned on Major (the rank, O-4, not the term used to refer to large airlines) in their Guard units before being selected for pilot training. Sorry for any confusion.
IJ
