So, you're now starting to look at it [UAL] from a new perspective? Status quo for yourself prior to retiring was a good thing, now it's not? Everything you said about the mx bases and "Titanic" was correct...Are you maybe seeing why pilots did not want the age to change on top of all this? If you had been lucky enough to stay, would you have worked to help out those at the bottom of the list? If the answer is "yes", you should try to go there now, out of principal, and make good on this.
