Traffic Pattern Anyone?
aucfi
Endowed Member
What happened to entering the traffic pattern the proper & courteous way?
Two aircraft both called 6 mile finals within 10 minutes of each other while there were 3 other aircraft in the pattern including myself. To top it off, one of the aircraft (a Cirrus) called his 6 mile final, his 3 mile final, his 1 mile final, and his short final and then called a go-around after realizing he had made his approach to the CLOSED RUNWAY!
One guy in the pattern simply departed and came back in after things calmed down (smart guy). The other plane in the pattern turned final ahead of the other guy on the long final because the long final traffic said "yeh you guys got plenty of room, Im still 4-5 miles out." Im not going to bank my life/career on this guys estimate of distance on his final approach. My student and I elected to extend until he was in sight and beyond us and simply because he technically has the right of way.
We get a lot of corporate traffic in and out of the airport and they usually cut corners in the pattern. Though its practically no different, I usually dont mind extending to let them in ahead of us or to give them a chance to depart as long as they call ahead and give us in the pattern time to kind of coordinate an opening for them. It doesnt take too long for a corporate jet to fly a 6 mile final, but a 172, c'mon.
That's what scares me about uncontrolled feilds. My time is pretty low, and ALL of it has been at a towered airport, where ATC basically tells you what to do. The thought of whipping around an uncontrolled feild with other airplanes in the pattern, not to mention others airplane inbound....scares the hell out of me. I hoping I'll get some experiance with non-towered feilds durring the X-country phase of training.
how come no one was courteous enough to tell this guy the runway was closed?
The Cirrus pilot was calling his final to runway 20 and actually made his approach to the closed runway 24
UA-RESURRECTED said:
That's what scares me about uncontrolled feilds. My time is pretty low, and ALL of it has been at a towered airport, where ATC basically tells you what to do..
f'n a hes back
towered or uuntowered you're still responsible for see and avoid. i cant count how many times ive been cut off or had towere lose track of whos who in the pattern
My suggestion: less "whipping".
MFR
"I had the right of way!" is a common engraving on tombstones. That's why it is called en "graving".
Just a thought but it sounds like the Cirrus is the bonanza of the new millenium. Underexperienced aviators overreaching their skills with deep pockets. Instead of the fork-tailed doctor killer its the glass based moron thriller.
What a tool. You would think that with all of the toys in the Cirrus, the guy could get the name of the runway correct.
pprobably was too busy keeping his head square in the cockpit so that his whizbang sectional-chart-replacement device could land the airplane for him.
just curious what the airport identifier is.
i like to head to quasi-busy non-towered airports every once in a while to keep myself fresh (b/c the field where my school is based is towered). just the other day i went to sebastian and no one was there to provide traffic advisories, so i overflew the field, used the windsock to pick my runway, entered 45 degrees to the downwind, and landed, after announcing everything at the proper times.
i was up in ohio last week and i couldn't get over how HORRIBLE some people are on the radio.
"uh.... morrow county traffic, cessna N12345 is, uh..... right field down-- right downwind of the field for, um, landing."
that is pretty funny :laugh:
cforst
im glad you are learning and doing the proper procedure
A couple of weeks ago I landed at an uncontrolled field, with several aircraft in area. I arrived IFR and cancelled on arrival at the field. After announcing a downwind, base, and final, I observed a small twin sitting on the opposite end of the runway, while I was on very short final. I went around. As I went over the top of him, I enquired on the radio if the twin sitting on the end of the runway were listening.
He immediately came back and said yes, he was, and he was departing.
Foolish on his part? Yes. He had been sitting down there, he knew I was there. I didn't see him on the runway. The terrain, layout of the runway, and another distraction lead to my failure to see him (and possibly some eyesight that isn't what it once was...though I'm not ready to concede on that point, yet)...yet he was fully aware of me, and my intentions.
End result? I went around, stayed in the pattern, and landed. He departed, and didn't return.
Not a big deal. See and avoid, deal with traffic as you see it.
If the aircraft doing the straight in is a Hawker 800XP, then so be it. Deal with it. If the aircraft doing the straight in is a Cessna 172, then so be it. Deal with it. If the aircraft doing the straight in is a Cirrus, then so be it. Deal with it.
Perhaps the other guy will do the right thing, perhaps he won't. Your problem is taking whatever action is necessary to address the situation. If that means going around extending, leaving the pattern until the other guy figures it out, making an extra announcement, directly querying the other guy, adjusting your speed and/or spacing, or any other action necessary to ensure safe operation, then that's what you do.
And you don't worry about it after the fact.
Don't get wrapped up in what the other guy does or doesn't do, or who was "courteous" to you and who was not. Deal with what you can control, act accordingly, and leave the rest of the baggage behind you in your wake.
You'll live longer.
And happier.
I learned at an uncontrolled field and my experience is the opposite of UA: I get much more uptight at towered fields. I feel much better about negotiating my own way into an airport than trust that the tower has their act together (especially at a field that doesn't have radar, like KHIO used to be; what a zoo that was!). I know that even at a towered field it's up to me to see-and-avoid, it's just that I'm more experienced with talking with everyone else and figuring out on a peer-to-peer basis where I can fit in.
Avbug,
I don't always agree with everything you post. In this case, I can say that I absolutely agree with every word of it...
cforst513 said:
entered 45 degrees to the downwind, and landed...
I suggested that I do that on my commercial checkride and the DE said to just go straight in...and to not worry about 'that 45 degree thing'. So I called a 7 mile final, put it down and went in to collect my new certificate.
So lets beat this to death again.........There is nothing that says you MUST do a pattern. Straight ins are normal and legal. What happened to talking to eachother to figure out things while in the pattern? I remember the days when i trained at an uncontrolled field (which is now controlled) and we used to actually talk to each other to figure out landing sequence when someone would call straight in. Nothing wrong with that, and there is absolutely nothing wrong with talking to the other people in the area versus just announcing your pattern locations.
Since when did Danville become uncontrolled...I thought they had a tower there. You know on second thought, maybe that was the training tower for Averitt (sp?). Anyway...aucfi, have you tried that nice little grass strip up off the military academy there in Chatham? Nice area with trees at both ends, and i think it is something like 2000'...maybe you could take the cub in there...although i do not know of much to do around there after you are there...oh except hit the girls school just down the road from the academy.
Sometimes reprimanding on the radio is in order.
At uncontrolled fields, you should always enter on a 45 degree left downwind. You should begin to monitor the traffic flow about 10 miles out and begin announcing your position no closer than 5 miles from the airport. Position should be stated entering the 45, established on the downwind, turning base and on final. Once on the ground, report clear of the active when you're past the hold short lines of the intersection.
Remember, at non-towered fields aircraft do not require a radio and can legally enter the pattern and land without any verbal radio calls. Don't rely soley on position reports as there may be unannounced traffic joining.
with the volume of planes entering the pattern, I think everyone conforming to standard pattern entry and callouts would be much safer than half a dozen or more planes trying to "talk" to each other and sort things out using lengthy nonstandard language.
This becomes especially confusing when there are numerous similar aircraft.
A verbal reprimand, on the radio? Seriously for your own safety, unless you know the offender, don't get in a pissing contest on the radio. Wait until you both have landed and can have a civilized conversation with them.
FAR = Regulation
AIM = Information
You will not find traffic patterns in the FAR, you will find it in the AIM.
While 'Right-of-Way' rules are found in the FAR, they are POINTLESS if you are DEAD!.
Likewise, I will not take my 200+ KIAS across midfield to do a wide descending circle on the traffic pattern side and to enter a '45' midfield and down wind to a 'busy' or otherwise uncontrolled field. This tremendously increases the odds of running into the pattern pounders, busy 'instructing' away in the pattern rather than purposely looking out the window and monitoring radios and making proper position reports at the proper time. There is no regulation that says you must have a radio OR USE IT in an uncontrolled field. I would much rather assess the pattern traffic as much as 10 minutes out. Listening for departures, arrivals and local traffic and judge the most expeditious route to an active runway where the most minimal exposure to conflicts will occur. It is common in my situation that a right hand base to final will accomplish this, YET, you CFI 'Professionals' want to get bent out of shape and wrapped around your axles because guys like me don't slow to 150 KIAS or less and fall in behind you. Often my assessment is that I will be base to final on your Upwind cross or Downwind legs yet you want to try to debate my procedure or contend over the busy CTAF. GET OVER YOURSELF!
While we are on the subject. STOP BROADCASTING YOUR TAXI PROGRESS TO/FROM the RAMP. On many Freqs, it is not only annoying as he<<, it often blocks out more pertinant info being transmitted.
my $.02.
100-1/2
100-1/2 said:
FAR = Regulation
AIM = Information
my $.02.
100-1/2
I agree with everything you said, except you can't make a right base to a left traffic pattern (FAR. 91.126). I don't know if that's what you meant, but it is a big "gotcha."
Traffic Patterns really come down to Situational Awareness. Imagine being 10 miles south of an uncontrolled Runway 18, one guy's in the pattern just turning downwind. If you make a straight-in you'll probably safely land behind the traffic as he'll be on his next turn to crosswind turn. On the other hand if you enter on the 45, you'll most likely both be on the downwind, at the same time in place.
Which is safer or better? Well just like most things in aviation there are no hard answers. In the previous scenario, making a straight in is clearly a safer option to avoid the "known" traffic, but it does open the door to "unknown" traffic. On the other hand the CFI that always insists on entering a pattern on a 45 in the previous scenario is creating a "traffic" issue by being in the same place and time as the traffic in the pattern.
Back to situational awareness, do you really need to be in the traffic pattern? If I were a CFI, and there's more than three in the pattern, that'd be a day I go out and do some stalls and turns, or go to a controlled field.
what about the older guys that have no radios? how are you going to communicate and do a lading sequene?
If someone is reporting the 45, then stay clear of the terminal area until they're established on downwind or turnign base. Then enter the patter. Simple as that. Remain clear of the legs if someone else is on them. No need to be in the same place at the same time.
If the pattern is empty, the occasional straight-in may be okay. When you've got lots of traffic, it's common sense to conform to standard legs. This allows the other pilots to know where they might expect you and in a sense you get in line to land.
[FONT=&quot]I guess it’s my fault that I had instructors & examiners who always stressed proper pattern entrys and departures. Maybe my complacency will come once I get "enough" time, oh I hope I make it that far.....
Whether its in the FAR/AIM/AC it doesn’t matter, the traffic pattern was created to increase safety at uncontrolled airports right???
Were the straight in landings unsafe? Generally speaking no, they are not unless you have some Cirrus calling an approach to one runway and almost landing on the other. That is what bothered me the most about the straight in landings. Why not use the "recommended" pattern entry/departures which advocate safety?
I guess it was good he did a straight in landing to the closed runway. That’s better than having him fly a pattern to the closed runway. Wouldn’t that be an interesting day... Maybe if he used his eyes and brain he would have realized what runway was actually two zero. MAYBE, just MAYBE if he had planned ahead and entered the pattern properly, he could have avoided his embarrassing moment.
Yes, LOOK WITH YOUR EYES, NOT THE RADIO, I/we know this. But if someone calls final to a particular runway, where will you look?[/FONT]
[FONT=&quot]The only thing I would debate is how to keep ourselves from occupying the same airspace at the same time. Thanks for the right hand base entry to the left hand pattern, my students will appreciate the visual of what not to do. Lead by example.
I know you guys are in a mad rush. I’ve dabbled in the corporate scene and completely understand your rush. This is why I do not mind helping out when I can if given the opportunity.[/FONT]
au
You abide aviation's "Golden Rule," FAR 91.113b, you see and AVOID. And it's not always the little cub that's out there without radios.
A while back, going into TRK, I went around for a Global Express, that apparently didn't have radios. Did I get pissed off, or "reprimand him on the radio;" of course not, you know why, because stuff happens everybody makes mistakes, that's life.
After finding out that the GEX crew had 122.7 dialed in for the CTAF, that's was actually 122.8, they ended up buying lunch. That's what happens in the real world.
