metrodriver
No jobs anymore in here??
- Aug 25, 2002
metrodriver said:I guess he doesn't know what he is talking about either, although if you see his "credentials" he should know better. And supplemental and flag ops have the same limitations, so there can't be much confusion.
Funny thing is that the BOG- MDE trip from MIA is only 8 hrs of flying
McNugget said:Minus two thrust reversers would be a major factor in going off the end in an 800,000 lb. airplane.....I would be happy to see this be blamed on mechanical issues and not the crew.
Haven't seen CSY Mon on here in a while, hope he wasn't involved.
It's the same for all transport-category aircraft...the use of reverse thrust is not calculated into the stopping distance, which of course is a factor in determining V1 speed.ackattacker said:Forgive the ignorant question, but on the turboprop I fly reverse is not allowed to be considered in the takeoff calculations, the theory being that if you abort due to engine failure any reverse would be asymmetrical and hence unusable. Is it different on a 747?
Given the altitude of Medallin and based on Jepps Runway Analysis from Bogota, I would guess (only) that the GW was less than 700k, but could have easily been max gross for the runway limit. Also, civil takeoff data on a wet runway allows a decrease of screen height from 35' to 15' and also allows the use of reverse thrust (if it doesn't require exceptional skill on the part of the pilot). In the case of the 747, wet data allows the decreased screen height (15') and the use of 2 symetrical reversers (presumably since using 3 would require exceptional skill). If the refused takeoff is due to something other than loss of thrust, then 4 reversers can be used as a bonus. The Boeing standard for a "wet" runway (vs. a "cluttered" runway with standing water) is to reduce dry runway V1 by 10 knots.McNugget said:Minus two thrust reversers would be a major factor in going off the end in an 800,000 lb. airplane.....I would be happy to see this be blamed on mechanical issues and not the crew.
Junkflyer said:We dialed in some numbers using our companies OPS program for a q-powered 200 in MDE. It gave a max of 753,000 lbs ,but you only get a 256 foot stop margin. Most times your stop margin is 3,000' or better. I wouldn't be at all surprised if they had unknown weight on board coming out of SA. In the old days, they would ask you how much you could carry and that's what their weight and balance would say. The funny thing is all the cargo was already on pallets and nothing was ever added or subtracted.
