that's great that they blamed it on the russians....lol...course it couldn't have been our space junk!
A "hazard not controlled" sounds like an emergency - more than just a pirep. That's my point. Either you're in a tight spot or you're not. Don't cry wolf.
I swear, this drives me nuts. You know, if a meteor hit an airplane, the NTSB would cite the crew for failure to see and avoid the meteor....
Anyone heard of going missed? It is this procedure where you set go around thrust, ensure spoilers are in, set flaps 8 and climb like your life depended on it. It works real well if either pilot is close to the ground and has to exceed normal bank angles to get the landing gear over a paved surface.SKYWEST AIRLINES INC (D.B.A. Skywest Airlines)
The captain stated that almost immediately upon entering the top of the fog layer they received an ICE caution message. He stated they turned on the wing and engine inlet anti-ice, but the ice accumulation on the windshield wipers was rapid and ice was accumulating on the winglet. The captain stated the approach lights came into sight when they were just above minimums and that he had the runway in sight at approximately 140 feet above the ground. The first officer then disconnected the autopilot and the nose came up slightly. He stated he informed the first officer to keep the nose down and add thrust.
He stated the airspeed was just inside the "bottom of the bucket" and the trend vector was indicating a decrease in airspeed. The captain stated he "again said something about more thrust and keeping the nose down." He stated the airplane continued to move to the right of the centerline and he took control of the airplane. He stated the airplane responded "poorly" feeling "heavy and sluggish." The captain stated the airplane was close to the right side of the runway and he added thrust at which time the ailerons became more responsive. He stated the left wing dropped, scraping the runway, at about the same time the left main gear touched down. The captain stated the airplane bounced into the air then landed hard on the runway.
The first officer, who was flying the approach, had about 15 hours of total flight time in the CL-600. The captain, who was also a check airman, had a total of 1,196 hours of flight time in the CL-600. At the time of the accident the local weather was reported as being visibility 1/4 mile in freezing fog, vertical visibility 100 feet.
Inspection of the airport and airplane on the afternoon following the incident revealed ice was still visible on the antennas, windshield wipers, radome, winglets, and horizontal and vertical stabilizers. The main body of ice on these structures measured between one-half to five-eights of an inch thick and that the main body of ice plus the "ice spines" totaled three-quarters of an inch thick. A Kinematic parameter extraction showed loss of lift consistent with airframe icing but there was no early stall due to icing prior to touchdown and no indication that airframe icing had caused any loss of control. Marks on the ground and on the runway revealed the airplane initially touched down 1,976 feet from the approach end of the runway with the right main landing gear in the grass off the side of the runway. The left wing tip then left a 63-foot long scrape mark on the runway, which was followed about 1,100 feet later by another set of tire marks. Data from the flight data recorder showed the airplane rolled slightly to the left followed by a roll to the right when the autopilot was disengaged. It then showed the airplane touched down with a vertical acceleration of at least 1.8g's. The airplane then became airborne in a 16-degree left bank, with a 5-degree nose up pitch at which time the ground and flight spoilers deployed contributing to the firmness of the 3.25 g touchdown one second later.
The National Transportation Safety Board determines the probable cause(s) of this incident as follows:
The copilot's failure to maintain control of the airplane during the landing and the captain's delay in initiating remedial action. Factors contributing to the accident were the low ceiling and low visibility due to fog, and the aircraft's deviation from expected performance due to airframe icing.
The sad fact is that airlines will continue hiring with 200 / 50 and upgrading IP's with only 1,000 hours in the aircraft, while trying to chase away the IP's with almost 20,000 hours total time & and a little uncommon sense. In my opinion this report really highlights the dangers of inexperienced crews out flying together.
If an instantaneous 3.25g is "firm", I wonder how high the g meter has to go to get a "hard" landing?...at which time the ground and flight spoilers deployed contributing to the firmness of the 3.25 g touchdown one second later.
So, someone is gonna bitch about SKYW calling Severe icing? So should they NOT call braking action NIL?
http://forums.flightinfo.com/showthread.php?t=94082&highlight=braking+action
Very true, the safety folks get it wrong on plenty of occassions, but usually the NTSB is a reliable source and "not under the influence" particularly of the FAA who they internally kind of regard as hacks. But the other decisions on this flight (letting a 15 hour FO perform the approach with VV100, keeping it coupled up in ice, flying right at VREF with a decreasing trend vector, not going missed) seem to indicate inexperience. Maybe the Capt. missed his cup of coffee, who knows, but taken only on the information presented in the report it looks like NOOB flying.. and every airline has managers that fly, sort of, usually who hold IP credentials, reference the worst aviation disaster of all time - Tenerife.Hey fins, this guy was in my recurrent class last year(the captain, C.A.). He said when they "pulled" to flare, there was nothing there. Not an icing accident? There were plenty of indications that it was. The NTSB, I think, might have been influenced by the findings of the FAA inspector who had a personal vendetta against this guy. He has also been with the company for a long time...not flying the RJ...but a long time. You can't judge this thing based on what you read in an NTSB report. If you ever get a chance to hear the story from the horse's mouth...it makes a lot more sense.
Cardinal:
There is a well known and respected training CA at SKW who lost all control of a CRJ on an ILS in South Dakota due to severe airframe icing which occured with no warning...
The thing rolled off the LOC and dove for the dirt...the CA realizing he had almost no controll decided that it wouldn't hurt any more to hit the ground faster, so he fire-walled it. Fortunately he picked up enough airspeed at the last second to get some aerodynamic control and plant the thing on the runway. This guy basically KNEW he was dead and had to make the decision that more speed couldn't hurt and might help. How would you like to be in THAT situation?
Everybody at SKW knows this story, so they operate as though the monster in the closet is real, cuz we know it is...
Fins-
You are talking about an entire mind set in this country. Treating Pilots like professionals instead of blue collar labor. A labor cost that needs to be controlled....
Where do we even begin?
There is no silver bullet or magical cure. However, there are many many pieces to puzzle....
I am in.....
