I worked for an airline that changed the hat policy to "hats optional". It was awesome because you could tell immediatley who the contol freaks were by who kept wearing the hat. My beef with the hat is they are so darn uncomfortable. Why can't someone make a hat that doesn't have a hard leather head band that fits nobody and is lined with plastic so it traps all your head it in and causes you sweat like a pig?
Don't work for the company nor am I a shareholder. Just thought you can use the information...
http://www.premierhatco.com/?page=shop/index&
These are the guys that use to make those great hats for the original Bancroft company.
FYI, Superior bought the name Bancroft but the Bancroft hats they currently make are not of the same quality as the original. Premier are the best.
•Premier’s DRI FIT - Designed by Premier Hat - Wear tested and perfected by line pilots!
•New DRI-LEX® moisture wicking breathable lining.
•Perforated crown protector with card holder allows heat to escape.
•New Microfiber sweatband designed and proven to wick moisture away from your head.
•Same quality construction and traditional look as the classic style Premier hat.
•One-piece quality construction.
•All seams are lock-stitched for durability and reliability.
•All eyelets have back up washers for strength and stability.
•Posts have screw-backed buttons - not wire-backed buttons.
•Front stay is made from twin wire steel - not plastic.
•Stay is covered with matching lining material for a clean, finished look.
•Matching tape includes stiffener in crown seam.
•Sweatbands have reeding to create a natural roll and cushion that keeps stitches away from your head.
•Genuine Clarino™ First Officer visor tops and leather bottoms laminated and cut "in-house" - not imported.
•All hats come with a 100 % satisfaction guarantee
Check this out http://www.3dvo-models.com/clients/Blackstone/links/01127/model.php
ALSO Rez,
What you really should have your panties in a bunch about instead of the lack of hats is the one uniform article that actually DOES look unprofessional and almost demeaning: The Leather Jacket. Looks trashy and well, unprofessional. Unless you're a professional biker. In which case it might look professional when you're at a biker gathering.
The hat is a brand icon and image for the public.
