Yes, you are. I'm talking in generalities and not blaming you or the pilots of SWA for anything at all and you got personal.
No, I pretty much put it right out there. There wasn't any "hiding" it at all. The grin was because I think you're a putz.
Ditto. You can't debate facts, constantly make things personal, and everyone knows it. Not worried about it in the slightest. If my "reputation" is that I believe our pilots should have been treated better in this process and that GK should have honored the Process Agreement, stayed out of it, and let it go to arbitration then integration as he promised in the Process Agreement, I'm good with that.
I've said as much to senior SWA management. I don't call anyone names. I don't get angry about it. But I also have ZERO tolerance for bullsh*t, yours included, and call things like I see them. If that's earned me a reputation... I'm good with that.
Like Winston Churchill said: "So you've made enemies? Good! That means you've stood up for something at least once in your life."
As was his post. I don't respond personally unless someone attacks me personally first. You'll find I do the same in person.
As are you. Inferring that I should just take his personal attacks and not respond, and making a cheap shot yourself in the same post. I'll give you an example in your last post:
You accuse me of being arrogant, your own cheap shot at me, then you berate me for taking "cheap shots"...
Pot paging Kettle... come in, Kettle.
The sheer ARROGANCE of people like you thinking that "ALL" the AirTran pilots (or even the majority of them) are just peachy happy with the way things happened is simply asinine. I mean you guys REALLY need to get over your own ego.
Will people move on and make the best of it? Sure. Do you REALLY think they're HAPPY with the way this worked out?
You're going to need a reasonable suspicion test. Seriously. Lay off the wacky weed.
