Swa Pool 2
So those of you in the 4/9/08 class, are you going to be in with the re-hires? Is that correct?
Congrats by the way.
The time has come...
We'll guys, finally got the call late last night: Apr 9th. Good luck to everyone and here's to getting to class. REST ASSURED as I get info, I'll pass it along, even when I'm in training. Good luck!
Name-----------------Pool Date-----Class Date
1.
GFunk20---------------5/23/07-------4/9/08
Tabex ------------------5/23/07------
AuburnAviator-----------5/23/07-------4/9/08
SW Poolie---------------5/23/07------
NoCompromise-----------5/24/07-------4/9/08
fixy---------------------5/24/07------
Stewy-------------------5/25/07------4/9/08
BlueandWhite------------5/25/07-------4/9/08
10.THEPRFCT10----------5/27/07-------4/9/08
Ballgag------------------6/01/07-------
Prop Trash---------------6/06/07------
zdriver-------------------6/08/07-------
Avgslin------------------6/10/07------
crj410 -------------------6/10/07------
Lakempnative------------6/10/07-------
O-Weone Ubabe----------6/10/07------
capt1900----------------6/10/07------
msmb--------------------6/11/07-------
20.SW Poolie-------------6/11/07-------
SW Poolie (LH) -----------6/11/07-------
SW Poolie----------------6/11/07-------
obadie-------------------6/12/07-------
palmtressairlines.---------6/12/07-------
GuyBehindTheGuy---------6/12/07-------
VoidFighter---------------6/12/07------
Superherc----------------6/12/07------
So cal--------------------6/14/07------
SW Poolie-----------------6/14/07-------
30.SW Poolie-------------6/16/07-------
SW Poolie-----------------6/16/07-------
MJG-----------------------6/17/07-------
SW Poolie-----------------6/17/07-------
40.Uplift------------------6/18/07-------
RogerMOSA----------------6/19/07-------
Nutts---------------------6/19/07-------
f340dvr-------------------6/20/07-------
Chellsha-------------------6/20/07-------
Bluto13--------------------6/21/07-------
ofacegangsta--------------6/21/07-------
2jet-----------------------6/21/07-------
Rosie----------------------6/21/07-------
Flybigsky------------------6/22/07--------
50.SW Poolie--------------6/22/07-------
SW Poolie-----------------6/24/07-------
Sundevil-------------------6/26/07-------
BOZO----------------------6/26/07-------
Beech Balls-----------------6/27/07-------
b727fe---------------------6/28/07-------
ddp------------------------6/30/07-------
SWPoolie-------------------6/30/07-------
TXDanno-------------------7/01/07-------
DesertDuck-----------------7/07/07--------
60.SW Poolie(SF)-----------7/08/07--------
Bayou Bengal---------------7/10/07------
beechbumn-----------------7/10/07--------
SW Poolie (SG)-------------7/10/07--------
50Pesos--------------------7/12/07-------
SW Poolie------------------7/14/07------
Califlyer--------------------7/15/07-------
WNC Flyer------------------7/16/07-------
PJF-------------------------7/17/07-------
SWPoolie(CF)---------------7/17/07-------
70.JBFlies------------------7/17/07-------
SWPoolie-------------------7/17/07--------
Jdru25----------------------7/17/07-------
SwPoolie(JW)---------------7/18/07--------
U2drvr----------------------7/19/07--------
cvr104----------------------7/19/07-------
skypine69-------------------7/22/07--------
SWPoolie--------------------7/23/07--------
Tristarpilot------------------7/24/07---------
Pandasfly--------------------7/25/07--------
80.Inigo Mentoya-----------7/29/07--------
SW Poolie-------------------8/05/07--------
Ghettobeechjet--------------8/05/07--------
Island Driver ----------------8/05/07--------
SW Poolie-------------------8/12/07--------
Huge------------------------8/14/07--------
Texman---------------------8/14/07--------
Sabregirl--------------------8/15/07--------
DT--------------------------8/17/07--------
gradywhite------------------8/20/07--------
90.srv141------------------9/16/07--------
Mickey D--------------------9/28/07--------
SW Poolie-------------------9/28/07--------
showboats------------------9/30/07--------
ARJLVR---------------------10/6/07--------
Snake---------------------12-1(ish)-07----
So one of the other April classes will be filled only with the rehires? So technically only two "newhire" classes for April? Is that what everyone is hearing?
April 2nd = 15 Retirees
April 9th = 24 Poolies
April 23rd = 24 Poolies
Good luck poolies, hang in there. We will be posting the most updated info once we get to DAL!
I read on the APC forum about a couple of guys that are already building seniority on the 76ER at DA and chose not jump airlines. That would be a great (and tough) decision to make.
Looks like a high percentage of deferees. Makes you wonder if SWA is all its cracked up to be, with so many folks bypassing.
Perhaps they decided that a culture where cutting corners to save money is accepted, just isn't what they are looking for.
Or perhaps they didn't want to work with kool-aid junkies like prfect10 and waveflyer etc etc etc.
You know; I've just seen some of your rants on other threads regarding SWA. You don't have a high opinion of our company or our pilot group. That ok and I apologize if someone has offended you; but you know? Your kind of an a$$hole!
fwiw,
I was told that I am not at the very bottom of the 9 Apr class, so I think and hope that maybe they are further down the list than is perceived. Good luck again to everyone here!
I have found SWA pilots to be among the friendliest and nicest guys I know, and aside from the occasional member of your "5% club" who post here, I bear no ill will to the pilot group whatsoever.
Some of the poolies here, however, are butt-smooching kool-aid guzzlers, without an original thought in their bodies. Those tools are who I take exception to.
1.GFunk20---------------5/23/07-------4/9/08
Tabex ------------------5/23/07------4/9/08
The two poolies on the 23rd are guys I got my type with. I havent been able to verify yet if they accepted the class.
jke406,
Just an honest question, why do you spend your time on threads that have nothing to do with you or where you work? Every thread that comes up about SW has your dumb a$$ on it posting all kinds of worthless drivel. One can only come to the conclusion that you are either jealous of our company and pissed off that you will never be a part of it, or you are just an ordinary everyday a$$hole that just likes to see if you can get a rise out of people. In either case you are a pathetic little piece of crap. I hope you take this personally, because it is. Now go run along and play with yourself.
Don't worry about it!
jke406,
Very funny and well said! It is very obvious that with almost 800 posts under his/her belt, he/she has nothing better in life to do than to wreak havoc and spread nothing but worthless b.s. all over this site. You really kinda have to feel sorry for people like that, you know. As for his/her comments on feelings to 'certain' poolies without original thoughts, well that was just a stupid comment with no bearing. Poolies, keep positive, ignore the negative comments on this board and just keep thinking that our situation and lives are so much better than those who try to bash us!!!!
Got me twisted homie-- but i do have a question: How do you reconcile your hating WN w/ your right-wing political beliefs?
Congrats to all poolies who got a class :-)
-wave
OK- but shouldn't WN be the poster-child for a right-wing free market capitalist? What you call Kool-Aid is exactly the attitude that has taken Southwest so far. They don't achieve what they have if it's not for the attitude of the everyone in the company. And all they've done is take on every challenge and be better and more efficient than every other player.
like i asked: How do you reconcile hating that, w/ Reaganomics? WN may not be the business model we all want- but we all wish our management's were like theirs.
WN has earned the employees attitude/trust by keeping their promises. Now if Tilton or Dougie Fresh starts spouting off Southwest type rhetoric- and a guy buys into it-- That's Kool-Aid- I don't see how someone believing in a company that has a track record like southwest can be called a Kool-aid drinker.
That same "attitude" could very well have killed someone, after SWA purposefully skipped its mx inspections to save a buck.
that "free spirit" culture is a double-edged sword, it would appear.
Please- that's nice flame-but doesn't answer the question. It's not the southwest attitude that caused the inspections to be missed. What about People working real hard to get the job done do you think is unsafe? Do you think adding employees where 3 people do the work of 2 is inherently safer? I don't.
You said you did that weeks ago...I guess not.
And SWA complied with their MX inspections weeks ago, too...I guess not.
MX if overrated. For real. How many thousands of walk arounds have you done? How many times do you find something? Hardly ever. It was a good calculated risk.
:smash: I JUST PUT jke406 ON MY IGNORE LIST AND IT FEELS GREAT!
I did that a while back too. Puts a smile on my face every time I see the blank box by his name. It's like seeing a little kid inside a car throwing a tantrum--and you are outside and can't hear him.
Congrats by the way...see you on 9 Apr!
Congrats to the guys in the 9 April class.
Just spoke to PD this afternoon. They said they still have two slots to fill in the 9 April class, and then they'll start making calls for the 23 April class next week. They said they're hoping to make the calls by mid next week.
Hey Oneshot and Perfect 10,
Just curious if you know what number you guys are from dec list. I am a june 9th poolie and am very close. I was #93 in dec. i figured that I will make April class if 10 people defer. If not, hey Im just glad to be here and should be in the first fall class!
congrats to all poolies getting out!
SWA rocks!
SWA rocks!
Way back when....PD told me I was somewhere between #25-30 on the entire poolie list, but that was before age 65 thing and after Feb class....not sure if the numbers seemed to jive, but I think they have a harder time since their only accurate assessment is after they speak with everyone! Clear as mud huh?! Good luck! hope you make the class!
Good luck guys! Congrats on the calls. And man does it feel good not to see JKE's stupid posts!! Ignore list is an amazing thing
