linecheck said:So you're putzing along at 10,000 to 14,000 feet and did everything that your QRH and dispatch told you to do. You think to yourself, "wow, I'm an awesome SWA pilot now; my chief pilot is gonna be proud of me."
Then twenty minutes from destination, you begin to smell something. Smells like smoke and not the mexican burito that you had for lunch. Something is definetly burning, but what? Smells electrical. Then you begin to see smoke.
You look up and see how much oxygen you have left. Its significantly depleted from your emergency descent, not to mention that you had a jumpseater on board who used a lot of your O2 as well. It doesn't look like there's enough O2 for 20 more minutes of flying. Suddenly you realize that the 130 passengers you have on board have no oxygen because all of their O2 generators have been depleted.
Still want to fly for another 20 minutes so you don't have to inconvenience passengers and make SWA look bad? Ever hear of the accident chain?
The pax O2 system is used for ONLY ONE PURPOSE... providing passengers oxygen at altitudes needing it in the event of a depressurization. Since they descended to a lower altitude and remained there for the remainder of the flight the system has ZERO USE.linecheck said:Regardless if the crew was in an emergency situation at the bottom of descent, the crew/company elected to continue for 75 minutes after an emergency event, with the rubber jungle hanging out, and with an important piece of cabin safety equipment expired: the pax O2 system and some of the crew O2 system. (and this of course is based on the information in the article which certainly can be heavily scrutinized.)
737tanker said:The problem was the outflow valve. At FL410 it went to full open. At 14,000 they were able to get it back under control and got the cabin pressure back under control at the normal cabin altitude of 8,000. Even if they hadn't gotten the outflow valve back under control it is safe and legal to fly unpressurized at 10,000.
