Older 300s have/had a tendency to spool up assymetrically and if too much power is added in wet conditions the tiller can avert a serious problem before the rudder is effective...
The 500s are worse than the 300s for some reason too. Were the throttles on these planes always so stiff? You have to move them an inch at a time. It's the craziest thing. It seems like the right engine always lags the left, leaving a healthy split at cruise. I'm guessing this is normal for 30 year old airplanes? Just wondering why mx can't make them a little smoother.
Yes, they are very slow to respond to that "descend via" clearance.And the ATs never work either!
I watched many SWA CPs (including Check airman) keep their hand on the tiller until APPROACHING 60 knots on the T/O roll then transition the LH to the yoke....
Explain why 30knots in a jet designed to taxi at 30knots is somehow unsafe under the right conditions such as taxiing C to 25R at LAS? Please use small words.That doesn't make it right. Sorry, but the simple fact is SWA has a lot more pilots than anywhere else that seem to try and make up time on the ground. We have all seen SWA crews taxiing like they just stole a 737.
A hurry up mindset maybe lends itself to blurring the distinction between taxiing an airplane and taking off an airplane?
You simply don't need the tiller for directional control. The rudder is all you need. Even if you lose an engine, your left hand is on the yoke and your right hand is going to be closing the thrust levers. You are certainly not going to be reaching for the tiller with your left hand once you have closed the thrust levers or even worse, before you have closed the thrust levers. Probably the worst abuse of the tiller would be a Captain that induces tiller input while the F/O is flying?, that could really start some problems.
Again, a hurry up mindset lends itself to trying to hurrying up the takeoff roll, which in turn could lend itself to not taking the extra second to ensure symmetrical power before adding T/O thrust.
