• NC Software is having a Black Friday Sale Event thru December 4th on Logbook Pro, APDL - Airline Pilot Logbook, Cirrus Elite Binders, and more. Use coupon code BF2020 at checkout to redeem 15% off your purchase. Click here to shop now.
Standard Rate turn requirements
dickburns
Total Time
1 hour
Is there any requirement for standard rate turns? If there are, can you cite some references (AIM or FAR, please!).
Thanks for your help with this.
(posted also in Regionals and Corporate)
Andy Neill
Total Time
6200
If you consider the Instrument Flying Handbook a worthy reference, there are multiple mentions of using a standard rate turn. For instance, look at the turns executed as part of an instrument approach described on pages 5-30 through 5-32.
http://www.faa.gov/library/manuals/...andbook/media/FAA-H-8083-15A-Chapters 5-7.pdf
For those flying faster aircraft, turns will be less than standard simply because the degree of bank required will exceed 30 degrees.
VW Pilot
MMM...PIGEON CASSEROLE
Total Time
Rising
I thought standard rate turns are ALWAYS used during instrument flight??? 3dgs per second and for faster planes 1.5dgs per second....or 15DGs bank standard....
avbug
Total Time
n/a
If faster airplanes used 15 degree banks, getting a turn done would eat up a lot of real estate. 25-30 degree bank with a flight director or autopilot is more standard.
We only do 15 degrees when slow and within 10 knots of the minimum speed for our flap configuration. Otherwise we use 30 degrees of bank when flying by hand, or the 25 degrees commanded by the flight director, or autopilot. For small changes in direction, lesser banks are used.
VW Pilot
Total Time
Rising
Avbug...I think you misundertood me..probably because of the way I typed it. I meant 15dg banks for standard rate turns. Not 15dg banks for faster planes. And 1.5dgs per second for faster planes, half standard. I was using 15dgs standard as in reference to putt putts like 172s and Warriors.When learning the manuevers, 100 KTS is used while under the hood....At least this is what is taugh by the two instructors I have been with and this is what Sporty's Instrument Rating DVD course is saying. The mis-undertanding came from my typing error...
Andy Neill
Total Time
6200
I'm betting most air carrier aircraft have no means of measuring a standard rate turn other than the heading indicators and a clock. We had no turn needle.
nosehair
Total Time
24/7
?? "Turn Needle" ?? ..is that like 'on the beam' ?
Seriously, though, to the original OP, who is looking for a 'regulatory' or 'other' *requirement* for the standard rate turn.
I think it used to be in the AIM as a standard for vectors. The controller needed to know the turn would be at the 3 degree rate. At slow speeds.
I can't find that reference in the AIM now, and a lot has changed since Everthing Is Radar And GPS, so I don't know anymore...
