DoubleOverHead
Active member
- Aug 10, 2005
reserve is reserve is reserve. If you get in early on this hiring boom, you probably wont be on reserve long. dont listen to the above posts about all lines being relief lines. Thats for the md80, I think it was done by the company to force guys into bidding the bus. the bus lines have your standard 20% reserve/ relief lines, rest all hard lines. For now the bus is growing more in DTW than FLL. That will give you a hint on where you will probably first be based until all the 80's are gone and the system is balanced again. DTW has always been a bigger crew base but not by much.
I would venture out and say all new hires will go straight to the bus. They just hired 4 more cpt instructors and 2 check airman. A new bid is supposed to follow for more instructors.
Hope this helps
Hope this helps
