PC12Cowboy
Berry Beery Bad
- Nov 6, 2003
HMR...HMR said:Mini- If you're so worried about busting 200kts in the 172 during the checkride just back it off a little bit to 1700rpm or so.![]()
Singlecoil said:The maximum airspeed underlying class B is 200 knots or clean maneuvering speed whichever is lower. In an MD-80, that can be 250 knots; 230 knots in a heavy 737. They don't expect you to keep flaps out to make this restriction.
Yea, I wish! I have flown with Primus 2000 (Citation X), as well as P1000 systems, and neither depict special use airspace on MFDs. A pretty big oversight in my opinion. On the other hand, every handheld GPS these days has it, as do most small GA aircraft. Is that backwards or what?!?!Mr. Irrelevant said:In faster and more complex aircraft, you may very well have a MFD that depicts airspace...
Singlecoil said:Whoa, Whoa, Whoa.
There is a very big caveat to this rule. The maximum airspeed underlying class B is 200 knots or clean maneuvering speed whichever is lower. In an MD-80, that can be 250 knots; 230 knots in a heavy 737. They don't expect you to keep flaps out to make this restriction.
I think he meant "whichever is higher".Bandit60 said:I don't understand your argument. According to your statement "the max airspeed underlying class B is 200kts or clean maneuvering speed whichever is lower", then if the clean maneuvering speed is 230 or 250 then the 200kts is lower so therefore you must maintain 200.
Bandit60...Bandit60 said:I don't understand your argument. According to your statement "the max airspeed underlying class B is 200kts or clean maneuvering speed whichever is lower", then if the clean maneuvering speed is 230 or 250 then the 200kts is lower so therefore you must maintain 200. Where did you find this because this could affect some bizjets as well? I dont remember seeing it in the regs but I could have missed it.
So don't get used to using those G530s while training.....the jet you move into probably won't have it. It's back to using "paper."
Bjammin said:Thanks for that great research! Now maybe we can put this thing to bed.
I found out some fighter type aircraft have letters on file with the FAA that allow them to fly above the 250KTS below 10K in any airspace. Some of our jet's best climb speed is 300KTS and, especially in formation, it is very difficult to fly any slower without a configuration change. So please don't bust on a military guy if he says he flies faster then some required speed limits, even under class B airspace.
mnixon said:Last time I checked the Government makes special considerations for military aircraft.
