Southwest taxis past me while I roll out on landing
Whatever dude!! I like SWA but it's a job. Pay is good, the days off are plentiful, but tell me you weren't hoping you would be flying that 747 to Hong Kong instead of your 5th leg to OMA in some piece of crap -300?
It's a slog to get to that last leg especially if you are sitting next to some retard former fighter guy for 3 days.
I do fly that 747 to Hong Kong!!! For the pay I'd take leg 5 to OMA.
Taxiing fast requires NO brakes.
Taxiing slow requires brakes.
I would know.
Gup
Taxing fast heats up the brakes way more because you have to slow down from a higher speed which takes more brake pressure. (unless you plan on hitting something to stop you).
Taxing slow is the way to keep the brakes cooler.
With good technique, you can taxi slow without using a lot of braking, it's all in how well you manage your momentum.
Brake temps are a function of residual temp building up over time more than what you are doing at the moment.
Sooooooo, why not use the reversers at idle to slow you down? Yes i know a lot of carriers prohibit this, but why? Truthfully, you are allowed to use them on landing until stopped technically, so what would be the difference? You could then use minimal brakes from ANY taxi speed. I started to think about this after i witnessed many corporate birds doing just this thing. Just a thought...
Don't know for sure. Might be a FOD issue. Big planes are going to kick up much more crap on a crowded dirty taxiway. Used to do it to great effect on Lears.
My guess it would be a maintenance issue. A corporate jet might do how many extra reverse cycles in a typical week, 10-15? An airliner is going to do that many in a given day. I guess it's a trade off with the brakes.
737-300/700 don't really have a brake heat problem. we don't even have the temp sensors installed (active?) in the 700s but I have yet to see a deflated tire or hot brakes here at SWA. (knock on wood).
and I can see why they don't want us using those big CFM's to slow down. the cowls are only a few feet off the ground and like C-150ETOPS pointed out, there is a lot of crap on taxiways/in the ramp area.
The Southwest attitude on hurrying on the taxiways and runways is exactly why they have had two overruns on runways and killed innocent children doing it. Most professional airline pilots know about the southwest taxi speeds and just shake thier heads in amazement. It will probably take another accident with many lives loss before it changes. Besides we get paid by the hour so whats the hurry?
Happy hour?
Commute flight home?
Getting away from the dork in the seat next to you?
Anyone else?
the MDW accident was caused by a thrust reverser that didn't deploy. nothing to do with hurrying or taxi speeds.
I know that flightinfo isn't known for reasoned debate, but this is close to or a new low.
rather than bendover you should change your name to getover, as in yourself. accidents happen. they are tragic. hopefully we learned something from our MDW accident. in fact I think the whole industry learned some things about the 700 and thrust reverse (it is included in landing distance calculations, unlike the 300 or most other planes). I'm not sure what your beef is with SWA but implying that child died as a result of our safety culture is wrong.
Taxiing at speeds in excess of 28 knots puts more heat into the wheels than they disipate while taxiing without the use of brakes. Boeing did not object to 20 normal/30 max published taxi speeds.
We have a small minority who think that taxiing the airplane like they are pushing a grocery cart trying to get to the open isle at walmart. I commute and it is embarrassing at times.
Reversers are only effective at higher speeds. To use reversers at taxi speeds as a means to slow the aircraft down is much harder on the aircraft than than just smoothly managing your momentum. It use to be the sign of a good pilot was someone who treated the aircraft like he had to pay the repair bills himself. Has that been lost on this current generation?
I think you nailed it with "small minority" from what I have seen, most of the SWA pilots don't taxi any faster than anyone else. Every once in awhile you do see a SWA taxing like Kyle Busch, but they are not the norm.
Dan, I might be wrong here but I believe keeping heat in the brakes is exactly how you keep them from wearing on carbon-ceramic systems. Application of the brakes when cold actually wears more of the material away than when heated which is why the manufacturers recommend a solid application of brakes during the rollout-so as to bring the pads up to operating temperature and reduce wear during taxi.
There's a video from an brake oem out there that discusses this and gives a demo, I'm looking for it.
Anyway, by the logic of the brake manufacturers taxiing faster is actually better in terms of brake wear and function.
Carbon Brakes
Copied this from PPRUNE.....
[FONT=verdana, arial, helvetica]Carbon fibre-based brakes are made out of so-called carbon-carbon composite material that consists of two components: weaved carbon cloth and a solid carbon (and other things) matrix. The carbon matrix is formed by Chemical Vapour Infiltration (CVI) method. According to this method, a vapour of gases (such as CCl4) are introduced across the [heated] weaved carbon cloth and react on the surface of these fibres with formation of solid carbon phase which has ceramic and silicon in it. This solid carbon phase is the one that plays important role in friction and wear performance of the brakes. The CVI coating is a few microns thick and is fine grained and harder than similar materials produced using conventional ceramic fabrication processes.[/FONT]
[FONT=verdana, arial, helvetica]There is a general wear mechanism for carbon-carbon aircraft brakes proposed in 1988. According to this mechanism, there are two types of wear:[/FONT]
[FONT=verdana, arial, helvetica]Type I. This type of wear happens at low energy conditions, such as aircraft taxiing, or when low pressure is applied during braking. At these conditions, a particulate powdery wear debris are formed. The worn particles cause abrasive wear which is the most damaging mode in terms of brake wear - it's like applying a sand paper over the brakes. The particles are mostly formed by carbon matrix, not carbon fibres.[/FONT]
[FONT=verdana, arial, helvetica]Type II. This type of wear is at high energy conditions, such as in aircraft landing, or when high pressure is applied during braking. The difference is that at these conditions, a smooth friction film is formed on the brakes which serves as a solid self-lubricant. This film protects the brakes, therefore the brakes wear less. Of coarse, the braking efficiency suffers, meaning that the friction coefficient is lower for brakes that have formed such a film.[/FONT]
[FONT=verdana, arial, helvetica]The mechanism of formation of this film is not completely clear, even though its existence was proved many times by many researchers. Usually, the following explanation is offered: under higher braking energy condition, higher pressure and temperature assist deformation of wear particles to form a debris film. The particles do not melt though, but plastically deform (carbon does not melt). Nobody will say anything more definitive about this film formation, although there have been a lot of research done on density, crystalline structure, porosity, microscopy and X-Ray diffraction of these films. However Malhotra did work on silicon barriers on carbon-carbon and also on ceramics, which makes me think that these are important parts of it. Murdie, Don, Wright at the Materials Technology Center (MTC) at Southern Illinois University, USA (later CAFS / Centre for Friction Studies) did most of the work on the aircraft braking systems, thanks initially to those kind folks from BF Goodrich and Aircraft Braking Systems (and thereafter the sponsors look like a who's who of industry). [/FONT]
[FONT=verdana, arial, helvetica]Because carbon is oxidised in air at temperatures as low as 500 degC, the extensive research aimed to improve the oxidation resistance of carbon-carbon composites. CAFS researchers studied the oxidation of carbon-carbon materials. [/FONT]
[FONT=verdana, arial, helvetica]There were two commonly accepted ways to protect these materials against oxidation. The first method makes use of oxidation-resistant coatings, such as SiC (silicon carbide). The major problem with this method is the fact that coatings usually induce stresses and often lead to crack formation. The other method of protecting C-C composites was by using matrix inhibitors, such as boron or boron carbide. They reduce the carbon oxidation by spreading a sealant borate glass within the composite. However, due to their low melting point, such inhibitors introduce temperature limitations for composite applications and are effective only after an appreciable fraction of carbon has been gasified. In the braking process and at high humidity, a carbon composite loses much of its friction property and becomes greasy--more like a lubricant. This could be a problem operationally [he says tongue-in-cheek]. [/FONT]
[FONT=verdana, arial, helvetica]What MTC did, but won't tell anyone, was to develop a third method of protecting against oxidisation – by making sure the carbon didn't get too hot. The nano-composite material uses ceramic particles to protect carbon from high heat in an oxidising environment. I reckon that there is silicon in the coating as well. The silicon forms the film and the ceramic retards the heat transfer to the carbon fibres. Their dynamometer testing (because they had one) showed that the ceramic-enhanced carbon composite had about a 20-fold higher coefficient of friction than a standard carbon composite. For certain friction applications, ceramic doped carbon materials exhibit more braking capability.[/FONT]
[FONT=verdana, arial, helvetica]The upper limit comes because as temperature and braking energy rise even higher (like in a rejected take-off), the silicon friction film would break into chunks due to shear stresses and thus expose the ceramic-carbon mix to higher friction and so the wear rate would increase again. The other bad thing that could happen at extremely high energy braking is the ceramic cannot sufficiently slow the heat transfer to the carbon fibres and the carbon heats over 500 degC and starts to oxidise. This is especially critical if the temperature of the total brake system exceeds 1000 degC – because that means that the thermal gradient is too steep, the ceramic can't offer enough protection, the carbon fibres get hotter, and the oxidation of the carbon fibres leads to a very rapid degradation of the brakes.[/FONT]
[FONT=verdana, arial, helvetica]In conclusion, high braking pressure leads to a lower brake wear, but only up to a limit. The lower brake wear is due to the formation of the silicon film at high energy braking which serves as a lubricant and protector of the ceramic/carbon brake material. The formation mechanism of the film is the subject of scientific debates, but it's known that it does not form at low energy braking, and it is destroyed at extremely high energy braking.[/FONT]
Enjoy...
