front nosegear collapsed
As opposed to the rear nosegear?
All in good fun
you are clueless, these 2 had more experience than whats in 90 percent of todays regional cockpits.
every single person reading this has landed in conditions, when viewed in retrospect, could be viewed as dangerous.
so please stop this nonsense and thank god it wasnt you, cause you could be next, no matter how smart you think you are.
I wonder what the "spin" is as was mentioned
The gear wouldn't come up when they left IAH (I think), so they pressed the override button - gear came up. When they reached IAD, the nose gear wouldn't come down! THEN Embraer came out with a memo stating "don't use the red button".
Bottom line, crew was exonerated.
Was the GS OTS when they shot the approach, or did they take out the antenna after/as they went off the runway?
And for what it is worth, remember that those calculated approach speeds are not necessarily the speeds you are meant to cross the threshold at. Vref is still your 50' over the numbers speed. If winds give you a 15 knot correction over ref for the approach, be sure to get yourself slowed down for the touchdown. There are generally no landing distance charts for landing at ref plus anything. Vapp is just that...approach speed.
