As is usually the case, I've got a pretty strong opinion on this. (Actually, it is one of my aeronautical pet peeves.) This very question resurfaces with every new pilot generation. I think HMR said it well...
HMR said:
You guys who set power based on temps instead of using N1 on the 731's, where did you learn this? It wasn't from Garrett and I doubt it was from the aircraft manufacturer. How do you flight plan? How do you know what fuel burns you'll have on a transcon trip? I haven't seen charts in any jet I've ever flown that say "Fuel Flow @ 800 Degrees".
For you new guys, here a little TFE731 Class 101: N1 is the ONLY indication of thrust output. PERIOD, end of discussion. When it comes to the various engine indications, N1 tells you how much power the engine is generating; N2 tells you the internal speed of the engine; and ITT or EGT tells you the health of the engine. A "fresh" engine will be able to achieve its rated thrust at a lower ITT or EGT than an engine with some time on it. As an engine wears, the internal tolerances open up and it takes more heat energy (fuel flow) to generate the same amount of thrust. More fuel into the engine results in higher temperatures. A new engine will have a greater margin than older engines.
In a way, it's comparable to a turboprop engine where N1 is comparable to % Torque. With turboprop engines you advance the power levers until you hit the maximum torque. You continue to advance the power levers to maintain that torque until you reach the maximum ITT or EGT. The concept is the same.
Several years ago, we had this very same discussion within our flight department. We had a pilot who came up through the freighter ranks and believed that the only real limitations on the engines were the N1 RPM red line, the N2 RPM red line, and the ITT red line. He simply pushed the power levers up to whatever red line happened to occur that particular day without regard to the N1 that the engine was operating at. Takeoff, climb, cruise - it was all the same. Later on, when we got airplanes with -40 (DEEC) engines, his thoughts were that he could simply push everything to stops and keep it there because the DEECs would keep the engines from exceeding any parameters.
Back then, Allied Signal manufactured the engines and I spoke at length to one of their representatives regarding how to operate their engines. We exchanged e-mails. TransMach hit the nail on the head when he said...
TransMach said:
The real problem is that a lot of folks simply set thrust according to ITT. The 731-2-2B engine on the Learjet 35/35A/36/36A has a max continuous ITT of 832C and the manufacturer recommends that you reduce to 795C after 30 minutes. The correct method of setting climb thrust is setting maximum continuous RPM, at a temperature at or below 832C, or 795C after 30 minutes. If you depart a low altitude airport in the winter, i.e. Chicago in January, you will see ITT temps of around 730-750 at takeoff thrust. Now, if you push it up to 795C you have just exceeded max RPM for takeoff thrust let alone max continuous.
Well said, and it just doesn't apply to the -2 engines in the Lear, but to the -3,-4,-5, and -40's as well. The specific temperatures will vary according to the specific engine, but the technique is the same.
As long as we're talking power settings. Here are some more basics - the takeoff power charts will give you a specific N1 required to achieved the required takeoff performance. Garrett/Allied Signal/Honeywell looks upon that number as a "minimum" number. Take of is one area where if you get a little more that what the book says, you're fine. Many aircraft AFMs, allow you to advance the power levers to the stops on takeoff regardless of whether the engines are EEC, DEEC, or FADEC, and allow the fuel computers to do their thing to keep the engine parameters in line. (There is also a time limit in this type of operation - 5 minutes.) After takeoff, you need to transition into the climb power charts. Climb (and cruise) charts are based on specific N1 settings and should be used. The temperature limits are the maximum allowable for the specific N1.
HMR talked about cruise power settings, and he was spot on. I've flown coast-to-coast over 1000 times in 731 powered aircraft. I've seen every possible method used to set power. In a -3 or -40 powered Astra, the difference between "balls to the wall" (885C) and a charted "Max Cruise" power setting is a very consistent 1.5 to 2 minutes and 200 pounds per 500 mile increment. In other words, balls to the wall on a 2000 mile trip will get you there 6 to 8 minutes quicker, but it will also burn 800 pounds more fuel. Personally, the extra time is meaningless - a series of vectors at either end of the trip can easily chew up that much time. I'd much rather have the extra 800 pounds of fuel - often it's the difference between being able to make the trip non-stop or having to make an otherwise unnecessary fuel stop. I've flown with guys who end up sweating over their fuel reserves unnecessarily - all that they'd had to have done was just go to the charts and pull the power back a bit. If you want book performance you've got to fly it by the book. The problem is most of us are lazy and we don't want to take the time to go to the charts. We also don't normally fly the airplane out to the edges of its performance envelope where these types of sloppy habits and techniques start to take their toll.
LS
