NOTE: If above 40,000 feet, one air-conditioning unit or cowl anti-ice must be selected on for each engine.
I was thinking the same thing. Is the angle of attack at FL410 high enough that the air flow through the engines is disrupted?comrcap said:My guess is that they stalled the airplane and both engines flamed out. The rj-50 is a pig at FL410, even if empty. That is why Comair has a min speed limitation (climb) for our rj's. We've had a couple of incidents a while ago where the aircraft was allowed to go below the green line and get on the back side of the power curve. Stick shaker and all the rest. No flame out though, thank god!
Overheat from CONT only? Don't think so pal..jetflyer said:So if they turned the Continuous ignition on LIKE THE MEMORY ITEMS SAY, the engines most likely WOULD NOT RESTART but would immediately begin to overheat
