RJ Crash Prelim
efiscompmon-
FLG3701 was a Part 91 reposition (not a maintenance ferry as some have assumed) flight which means there wasn't even a requirement for anyone in the SOC to do a "release" or paperwork for the flight. We do that as a courtesy for you guys. The dispatcher who did the paperwork filed them at FL330. HE DID NOT, I repeat, DID NOT FILE THEM AT FL410. Why the crew went to FL410 is still unknown but I assure you it wasn't because they didn't have enough fuel for FL330.
Fuel policy was no issue here, sir.
By all means, PM me with any other 9E SOC concerns you might have.
They went to FL 410 because it is certified for FL410 and they met the requirements in weight and temperature in accordance with the climb capability chart in the performance section of their FCOM page Per-51 and in line with the preface of their FOM that says seek the most efficient operating practice requesting "2. maximum efficiency 4. maximum economy for our flight operational activities" listed under company objectives page 2 in the "FOM Preface" in the front of the book.
Hey Dispatcher ; You have the FOM and FCOM in front of you at your desks. Why don't you guys open them up and read them once in awhile instead of sitting around between desk duties and telling jokes and B.S.ing. We know not all of you at the desk are like this. If your not then, don't take offense. But hanging around with you guys once in awhile and then talking to each other out on the line, that is what we pilots that have come around down there saw. Either read the book or don't complain when we ask for something you don't understand. Speaking out of frustration of people who don't take the time to learn how to do their job well sorry if you're offended.
efiscompmon said:
Of course, Express I refused all offers of technical assistance and acquired knowledge from CMR (both CMR mgmt and Alpa) when we got our jets in 2000. Better to go it alone with our memphian inferiority complex and re-invent the wheel with our FSI manuals. I have never been privy to a min speed limitation--boy would I be peeved if that is a contributing factor in this investigation.
Can't help but wonder if SAFETY could have been enhanced by chatting with the world's largest operator of the type. I'll put that SQUARELY on Jon Y. and Santi L.'s shoulders.
Sorry to hear that. Our company limits the climb speed to minimum Mach .70. We've had one high altitude speed problem incident I know of. The fleet manager posted to us that according to our Mach .74 climb chart, that aircraft would've been limited to FL380 (w/ approx 9K lb full). We are now indefinitely restricted to FL380 as well.
Well, I dug out "Fly the Wing" and looks like you guys were both right; I hadn't read that since college, good refresher stuff... then I tried it tonight just for giggles to see what the "Real World" loss of TAS is.
Achieved Mach .74 climbing through 29,0 and held it climbing 500 fpm to 33,0.
TAS at 29,0 Mach .74 SAT -35 = 436 KTAS
TAS at 33,0 Mach .74 SAT -36 = 435 KTAS
I'll try it going back to DTW in the morning and on my 5 leg trip Wednesday but I'm pretty sure I'll have the same result. Maybe the difference is more drastic between 33,0 and 37,0 (not that I'll be going that high - don't have any legs long enough for this dog of an aircraft to get there), but from what I read the TAS curve with a constant mach # is pretty linear, although I didn't go through the long math explanations in the book to decipher that info.
Diggler, given your experience I don't think you have any grounds to be telling us what we should and shouldn't be studying... just a thought.
Hmmmm, go easy on Jay. He's one of the better guys we have down there and given that one fuel comment directed at the SOC regarding this event (which we all know probably wasn't a factor) and the other event which we know DID happen but certainly not from Jay, I'm not surprised he got a little defensive... I probably would too. ;)
Actually, I haven't had a problem with fuel in quite a while now, so the new fuel policy is actually working out for me (most of the time). To tell the truth, half the time they're giving us alternates we don't need which adds to my personal "comfort level". (Never mind that the alternate weather is often worse than the destination - couldn't resist Jay!) :D
I'm not sure I'm following what you're trying to prove there. The speed of sound is solely a function of air temperature, not pressure altitude. In your two examples, the temperature is almost the same, therefore the TAS is almost the same given the same Mach speed. The hotter the air, the higher the TAS for a given Mach speed.
What you are more interested in as far as keeping the plane in the air in this case is IAS, no? That's a seperate issue than the ratio of Mach to TAS. The ratio of Mach to TAS is independent of altitude, whereas the ratio of Mach to IAS (speed of the air over the wing) is not.
That's stretching it a bit, not to mention Monday Morning Quarterbacking. There is absolutely NOTHING wrong with having this aircraft (or any other certificated for it) up at FL 41,0. To suggest that it is otherwise is to say that the manufacturer, test pilots, and FAA (not to mention the thousands of us who have safely taken the aircraft to that altitude) are somehow less knowledgeable than you are... I wouldn't go there if I were you.
Hey Lear, I think you ought to reopen that book and actually read it this time. Diggler's profile really doesn't state his experience level, which you insulted. Oakum may or may not have as much time as you. I certainly don't, but I will venture that our understanding of this subject is far more complete and accurate than yours. Before you go out and 'perform these tests' with people in the back, you may want to read and understand why you are getting these results.
And Mach .77 at 41,0? H*ll, we're lucky to get .70 out of the thing that high. Our standard cruise speed is .74, and although I'd be trying to go MUCH faster to have the airflow over the wing (resultant lift) to get higher, it may have bled off to .74 or .70 to get that last 4,000 feet but we'll know more in a month or so about that.
.70 at FL410 on a standard day will give you an IAS close to 200 kts. Waaay too slow for me to feel comfortable, especially with no remaining thrust. I am making no remarks about the accident, only pointing out the fact that at least one highly experienced captain seems to feel comfortable at these speeds. FL410 is probably not the place to be learning about it.
Ignorance is one thing, but insulting others due to that ignorance is another. Don't throw stones if you live in a glass house.
Stifler's Mom said:
Tell me if this sounds possible????
Trying to get the RJ up to 410, the pilots level off to build up speed, then pull up to gain that last bit of altitude needed to reach 410. As a result, they get the airspeed too slow, and have a double flame out. (Is there a speed to maintain during climb?)
Then during the descent, attempt a restart too soon and end up burning up both engines?
The reason I asked this possibility was because some instructors at FSI in ATL were talking about this scenario. Evidently, data from this accident was run in one of the CRJ simulators, or computers that depicts the flight path versus the recorded data, and this was what they believe may have happened.
I know it's nothing official, but thought it was interesting that an RJ training department was already looking at any information they could get their hands on.
Coil, I agree with you completely. That's why I believe this "book" discussion, although good review, to be relatively unrelated to the topic. The change in TAS with an increase of altitude has nearly NO bearing on the SAFETY of flying the aircraft at that altitude. Does it decrease with altitude? Yup, forgot about that, BECAUSE THE REDUCTION IS NEGLIGIBLE and once I learned that IN THE REAL WORLD, I eventually forgot the information, just like the equation for lift generated by an airfoil in aerodynamics class we were made to memorize or where to find the data on a NOAA chart. It just doesn't apply to real-world every day flying.
I only respond in kind after I am attacked. To wit, the hypocrisy you're showing here, insinuating that I am somehow endangering the lives of my passengers WHILE FLYING A CONSTANT M.74 CLIMB FROM 29,0 TO 33,0 because of a difference in TAS that isn't going to amount to jack sh*t in the REAL world, given YOUR flight experience as well, is ludicrous, not to mention assinine. THAT CLIMB SPEED IS OUR PUBLISHED COMPANY PROFILE! :rolleyes:
There's another reason you're not the Captain. I'm certain there are many other Captains out there who feel perfectly comfortable flying this airplane around all day at 200 Kts clean. As long as there is an adequate margin between the stall speed and the IAS, I'll fly around all day at that given IAS.
I could say the same for you. Once you've accumulated PIC time in just about every Lear out there (an aircraft that DOES fly at the edge of the envelope up at coffin corner), the 727, and then the CRJ, why don't you come back and have this discussion. Until then, why don't you read some more books in that glass house of YOURS.
I'll bet BBQ on this...
Mike15601 said:
Food for thought from a previous incident.... Date: 20 MAR 1994
Time: 00:36 CST
Type: Canadair CL-601-3A Challenger
Operator: Crystal Aviation
Registration: N88HA
Msn / C/n: 5072
Crew: 0 fatalities / 2 on board
Passengers: 0 fatalities / 0 on board
Total: 0 fatalities / 2 on board
Airplane damage: Written off
Departure airport: Burlington International Airport, VT (BTV)
Destination airport: Long Beach Municipal Airport, CA (LGB)
Narrative:
Both engines lost power at FL410; forced landing in a field, striking an irrigation structure and trees. Improper refueling by FBO personnel at Lawrence, MA caused the Challenger to depart with water contaminted fuel.
Yes the alt limits are dictated by the pressurization issue. where the engines are mounted on the fuselage, if they were to have a turbine rotor burst, the projectiles may penetrate the pressure dome.
I am willing to bet BBQ that when they get to the teardown report on the engines they will find water in the fuel filters. There is no other reason why BOTH engines would shut down like that. There is still enough oxygen at 410 that they did not starve because of that.
Speaking of which....when was the last time YOU checked your water drains?
I have taken the CRJ to 410 a few times (light and cold outside). It will do it if you climb the aircraft at the right speed. In fact at comair most of our climb charts show to get to 410 you have to climb out at .77 to get to 410. If you have speed you can make it no problem. Trying to go to 410 straight out of the gate is almost impossibe (as with most airliners). To get to 410 I would level off at 330 or 370 and get my speed to .79 to .82 and then climb to 410. ATC will often let you go wrong way at 390 for a while to build speed. At 410 the difference between the low and high speed cues (checkerboards) is quite large. You are not really in the "coffin corner" at 410 as long as you climb at the right speed.
As for why would you go to 410 there are a couple reasons. The fuel flow is about 500 lbs less per engine than at 33000. The air is usually smoother. And you can get good shortcuts (nice on last legs home). There is really not to much of a TAS speed difference between 330 and 410. Also if you descend right (stay high as long as you can ) you can save a lot of gas (which is nice considering most airlines are trying to stiff us on the gas). I am not saying the RJ is always going to make 410 or even that is practical. But sometimes it is practical and all you have to do is follow a safe profile.
Also, please dont assume to much with the pinnacle crash. Let the ntsb do the research. These two guys probally had a tough fight with the airplane and did all they can do. God Bless them and thier families.
I was not implying that you are endangering anyone's life, simply that you are conducting an experiment in which you don't understand the reasons for the results you are getting. .74 is of course a perfectly safe climb speed and is our company profile as well. The reason you think the decrease in TAS is negligible is because you were comparing two similar altitudes on a day with a nonstandard lapse. Then you come on here spouting off about what you found without even an inkling as to the reason behind it, until Singlecoil informed you of something these other guys have been trying to say all along.
My question to you is what is your company's published minimum climb speed? If none, what min speed would you feel comfortable climbing at? You already stated that you would be lucky to get .70 out of the CRJ at 410, implying that you have flown it at speeds lower than that. Like I said before, you are looking at 200 KIAS at that Mach # and less if you've flown it at lower speeds. For me, that is not an 'adequate margin above stall.'
Yeah, they feel comfortable at low altitude flying at 200 or less clean, as do I, because there is a lot of excess thrust available at those altitudes. If the airspeed decays, you add more. At 410, the thrust levers are at the stops and if the a/s begins to bleed off due to temperature change, winds, turbulence, etc., your 'adequate margin' is suddenly gone and you are scrambling to lower the nose.
I have already stated that your experience is more vast than mine. For you to continue to assert that your experience has made you more knowledgable than others is ridiculous. Experience and knowledge do not always go hand in hand. I fly the CRJ and I'm knowledgable about the CRJ and its limitations. No, I have not flown an airplane in which I had to be concerned about coffin corner. Does that make me less knowledgable about it? You and I both fly an airplane in which the high speed end of the coffin does not apply but at FL410, the slow side does apply, and the lack of thrust at altitude can put you in a corner just as tight.
Amen to that! I cannot tell you how many times I used to fly with guys who would get incredibly antsy flying around clean at 200 knots. It was almost like 215----> Flaps 20 All the time! And it was alwyas the guys who had a very shallow understanding of aerodynamics and a lack of confidence in the airplane. All irregardless of the fact we were well above the low speed cue.
When I was brand new to the company and the airplane, I flew a trip with a Capt who ALWAYS had to go as high as possible, trying to do 390 or 410 every leg (CHS or RDU from DFW). When it's 5+ above ISA and heavy, the airplane doesn't like it, and this guy made me VERY uncomfortable - to the point when we leveled and the airplane wouldn't accelerate beyond .706 (at Climb power +.5%) I told him I was uncomfortable and we needed to descend.
However, when it's around ISA or less and the airplane's light, it'll get up there easily. Another time (and another Capt) we were going to RDU mostly empty, climbing through 350 at .75 and 700fpm. We kept climbing at that rate and mach all the way to 410 and were able to cruise at .77-.78. The airplane will do it, depending on the conditions.
Does anyone know what the ISA deviation was at 410 for the accident crew?
And since when does the CRJ stall in level flight at 200 KIAS clean?
I'll Take That Bet, Gatorman
How about some Bryant's vs. any local Memphis BBQ?
DISCLAIMER: DO NOT INFER THAT THIS REFERS TO THE POSSIBLE EVENTS OF PINNACLE 3701
The CRJ can suffer a double engine failure if aerodynamically stalled. Not pusher, not shaker --stalled. At high altitudes, the shaker/pusher is not necessarily able to keep up with the rapidity of the stall event. The airflow into the engines is blocked....simultaneous double engine failure. At lower altitudes, the greater atmospheric density slows the event, full stall not likely.
This is not just a CRJ problem. Look at past accident reports. The have been previous high-altitude flameouts from just such a situation. Trying to top wx in a Lear or Sabre, flameout, now you're in it.
Fuel IS NOT the only thing that will cause double engine failure.
In defense of Lear 70, I have flown with him on the line. He knows what he is doing, and he is SAFE. Some guys have a problem with him, but that's more politics. Rest assured he is motivated by the right things.
FLY SAFE!
I have flown the RJ for two years, and the thing is a pig.
On a regular day with a full load you have to climb at no more than 500 fpm through the upper 20's. Granted this is with a heavy plane. I have a hard time believing the CRJ-200 can ever make it up to FL410 especially without leveling off to keep your speed.
The CRJ-200 would be way better with more powerful engines.
At Comair we are limited to climb at 250kts/.70 mach. We have this limit so the airplane is not stalled and so the engines get enough air.
It will be really interesting to see what their speed was at the point of the double engine failure.
Jet
Well...It Did....As many others have said and done. So your point is??
No need to be a smart a@@ t-gates.
If you read my post I said I can't see the CRJ climbing to FL410 especially without leveling off to keep your speed. As others have said it can be done. I personally can't believe it but like you said t-gates others have done it.
The plane should always be flown above the green line.
If these guys did make it up to FL410 in practically record time I'm betting the results will show that their speed was somewhere near or below the green line.
I'm basically saying I think a lack of speed at that FL will be found to have caused the double engine failure.
THIS IS ONLY MY OPINION, and if the company had no policy to keep the speed above a certain level in a climb, the company nor the pilots can be faulted.
Thats what the airline in questions lower airspeed LIMIT is also. Just like Comair. Listed on page PER-51 of the FCOM 2 as 250/.70 and a 300 FPM climb.
Doesn't mean you have to climb at .70. It only means the lowest limit is 250/.70 and a 300 FPM climb.
If you can make it all the way to the altitude shown on the chart for your temp and weight and can do it at 500 FPM and .74 on a good cold day so be it.
Just a couple days ago we were FILED for 370 and climbed all the way there after transitioning to Mach at .74 and 500 FPM at ISA +2 with a weight of 45000 when we got there.
If we had to we COULD have asked ATC for a 300 FPM climb as a lower climb speed limit for the last thousand feet or so in accordance with the PER-51 chart and then put the nose over to 400 FPM and then maybe later to 300 FPM to maintain .70 and then leveling off keep in climb power till we reached the FILED .76 MACH and then set CRZ power in acoordance with the cruise power charts above FL360 per the limitation.
And I back Lear 70. He has quite a bit more real experience than most.
They stalled it at FL410 (at least according to MY source in the investigation).
I read the post, and no smart-ass comment was meant. I'm just not sure what you're getting at. You say you can't see it, but then you concede that you believe the rest of us that it can be done. I'm just trying to make sense of it....
Peace Bro...
Ummm... excuse me *cough* BULLSH*T. All this was started by my failure to remember that TAS decreases with altitude assuming a constant mach #. NO ONE was trying to say that TAS had nothing to do with it, which is what I've been trying to say from the start. If you think I don't understand something as basic as keeping an adequate stall margin, you need to seek help. Guys don't make Captain at as many places as I have without that understanding.
We have none, other than our low-speed climb profile of 250 to M.70. As to your other question, any speed that keeps me with a comfortable buffer between my IAS and the low-speed cue (as in I'd prefer not to see it on the speed tape at all) and without a decreasing trend vector. That said, this aircraft (and just about every other swept-wing jet) performs better at higher speeds, that whole Lift and L/D Max thing which I'm sure you're familiar with, so I prefer to fly this aircraft at 320 to Mach. 77 in the climb (our high-speed climb profile), especially when heavy, slower is fine when lighter.
No, that is not my "Implication", that is your "ASSumption". The only thing that can be implied with that statement is that I've had the aircraft at 41,0 and that M.70 was the best speed on more than one occasion that I was able to maintain, sometimes being unable to maintain it and having to choose a lower altitude.
If you believe you need that much "excess thrust" to keep your butt out of a pickle, then maybe you ought to concentrate on keeping up with the aircraft enough to INSTANTLY notice changes that could get you in trouble. Even at 41,0 there's enough time to notice the IAS trending slower or the low-speed cue creeping upwards; unless the turbulence is moderate or worse or the temperature change is 10 deg in a second, you're going to have time if you recognize it IMMEDIATELY.
You're correct, experience and knowledge do NOT always go hand in hand. In the same token, someone "knowledgable" isn't always "experienced". I never asserted that my experience made me more knowledgable than you; quite the opposite, I very specifically pointed out that I had forgotten that information. What I asserted is that, given my experience, I more than likely have a much better grasp on what this aircraft can or cannot safely do and will CONTINUE to maintain that this aircraft will fly just fine at 41,0.
Time will tell.....give it a rest.
Raise your hand if you are an armchair NTSB Investigator!
Lear70,
You worry me. It has nothing to do with this unfortunate accident and I'm not interested in agreeing or disagreeing with you various theories. You're jumping all over 172driver and reminding him of all your experience, and the number of jets you've flown as captain. Well, I gotta tell ya your "experience" may be everything you say it is (thruthfully I don't care) but your attitude is cause for serious concern.
Maybe 172driver can't match your alleged expertise or your "command" exposure but, if I had to choose I think I'd prefer to ride with him. When a professional pilot has to remind his peers with such frequency of his "experience", in my book he has demonstrated a remarkable lack of it.
Regardless of what names you choose to call me after you've read this, I still recommend that before you slide into that left seat you should remember to select the Pride switch to the OFF position. You'll have many more uneventful arrivals over the life of your career if you do so.
it dosen't matter what anyone here ASSUMES to be the real cause.
whatever you may think it is (and i mean this to everyone here) its still ASSUMPTION.
the NTSB will make a final report when theryre done investigating. you will know then.
if they stalled it for real, the flight recorder will tell. the voice recorder will tell. they will know. and then you will know.
have patience. you will find out.
enough of this "who knows more" crap about the specific and minute flight characteristics of the CRJ in question. Two unfortunate pilots died.
give it a rest and wait and find out when the REAL information comes out.
I have gotten the RJ to FL 410 five times. A couple of time from SFO-BIO, early in the morning with only 5-8 people onboard at .75-.77. Once from YVR-SLC at .78 and once OKC-SLC .75. The last time was a reposition from FAT-BOI and at .82 mach with only the crew on board (Captain, FO, and Flight Attendant). All the times with B engines. I wonder if they had A engines. At FL410 you lose your N1 settings (carrots), so you have to use Vol 1 performance guide. I wonder also if you lose the N1 performace data at FL410, you also lose your engine performance information for your Flight Data Recorder and thats why the NTSB dosn't have that information. Also the the RJ has only one oil pump and at high altitudes it has been know to cavitate. At Skywest, we have had crews shutdown engine for low oil pressure who have flown in the high flight levels (not a good thing) and all you have to do is to desend to warmer air.
PCL_128 said:
Read that more closely. The FCOM doesn't list it as a limitation at all. It lists it as one set of RECOMMENDED climb speeds. Three different speeds are listed, but the book says they are only recommended, and you can fly at different speeds if you feel necessary. We do NOT have a minimum climb speed listed in the FCOM.
QUOTE]
No you need to read it more carefully. I have been using climb charts my whole carreer. You need to read them like a lawyer.
The PER-51 chart are the limits of climb in feet per minute and speed in the climb and the speed you can maintain when you get there at the weight and ambient temp. Re-read the page before and the last sentence of the first paragraph.
It does not mean you have to climb all the way up to the altitude listed for the weight and temp when you get there at a set vertical speed of 300 FPM and 250 until you transition to .70
If you were to do that you would have to have the power way back in the lower altitudes.
What since it says you can use the climb speed of 250/.70 listed on MAN-7 determined by operational requirements you are going to set vertical speed of 300 FPM and 250kts till you transition to .70 with the power all the way back in order to do it. I know you didn't mean that right?
No your not and you know this. You will do the normal climb as listed 290/.74 until you have to set vertical speed 500 while the speed is coming back to no more than .70 Mach and then if you have to you would request a lower climb rate to be in accordance in accordance with PER-51 to no lower a limit of 300 FPM in order to maintain .70 to the listed altitude.
I'm sure you don't mean you would let the Mach speed or airspeed ever to get below 250/.70 above 10,000 right.
Again if you can climb at .74 Mach up to the climb limited altitude listed for your temp and weight when you get there on PER-51 and maintain 800 FPM while doing .74 at rated climb power predicted byt the carats and then above FL360 using a climb power paper chart in the Performance section as predicated by the limitations section you can.
Although most undoubtebly you would be holding 500 FPM or less to the lower limit of 300 FPM in order to hold .70 MACH in the last 1000 feet of altitude climb or so.
Now go back again and read carefully what I just said before you say anything else. Because the implication we are not speed limited is pretty irritating.
We ARE LIMITED by our climb performance charts.
No shyte. I was sitting with the guy who gave me my type ride on the CL-65 3.5 year ago and we were thinking about what things might have been going on during this accident. Night, went to 410 after being filed for 330, dual flame out, ADG deploy (loud), lost electronics (dark), clackers and shakers (maybe), depressurization, unfamiliar territory (at night), 20 minutes to think about what you need to be doing in a forced landing.
Having been in 3 forced landings I can kind of understand what might have been going through their minds but putting that into a CRJ situation.....<shiver> not good.
PCL_128 said:
Sorry Hmmm, you're wrong. The speeds listed on those charts are not limiting. If the manufacturer wanted to put in place a minimum climb speed, they would have made it a limitation. They wouldn't have buried it in a climb chart. The climb charts are used as a reference to determine what altitude you can get to and your time to get there. They do not give us a minimum climb speed.
You'd better copy what I just wrote and take it back to Lear 70 and ask him to read it and see what he says next time you fly with him so you guys can talk about the implications at length. You might have misunderstood what he was teaching.
If you want to maintain a lower speed down to flaps 0 manuevering speed and adjusted by the altitudes listed at the very bottom of the speed cards in the airplane below 10,000 and have the flaps out as listed in the profile. You can.
But you are paid to do your job as expected and trained. Follow the profile and your performance charts while you are getting paid to fly the company aircraft. If you want to do things outside what is listed by the performance charts and profiles you can do so at your own airline where you can write your own books.
THOSE CLIMB CHARTS ARE LIMITING. NO EXCUSE TO BE OUTSIDE THE CHARTS.
If you don't like it start your own airline.
Again, I'm sure you were not implying that you ever fly below 250 or .70 in the CLIMB after transitioning above 10,000. Even when complying with ATC who may be requesting a faster rate of climb.
And when complying with ATC level flight speed adjustments I know you are looking at those flap vref speeds and adding your manuevering speed of 10 knots for the weight you are at. And although some do not like it, it does say in the approach profiles to go to flaps 20 when speed reduction is desired below 200.
I know you are doing this and were just wanting to shout without thinking of the implications they lead to.
