gunfyter
- Mar 25, 2002
FOOTNOTES1. See, e.g., Notice of Proposed Rulemaking, 60 Fed. Reg. 65951, 65959-61, 65976 (1995); Notice of New Task Assignment for the Aviation Rulemaking Advisory Committee (ARAC), 63 Fed. Reg. 37167, 37167 (1998). The term "rest," again without definition, is used in several other regulations establishing flight crew rest requirements for larger and scheduled carriers, see 14 C.F.R. ?? 121.471(b), 135.265(b) (2000) (9 to 11 continuous hours in the 24-hour period preceding completion of a flight assignment); id. ?? 121.471(d), 135.265(d) (one uninterrupted 24-hour period weekly); the term appears to be used interchangeably among these regulations.
2. Pertinently, the FAA notice says that the crewmember must be "free . . . from present responsibility for work should the occasion arise." 64 Fed. Reg. 32176, 32176 (1999). By contrast, in the duty-to-be-available scenario, it is much less clear that the crewmember has a "present responsibility for work" since the assignment can be declined.
3. The proviso is unusual (compare the Hobbs Act, 28 U.S.C. ?? 2341-51 (1994 & Supp. II 1996)), but reviewing courts have often read the Hobbs Act and like statutes as containing an implicit "good cause" exception, see American Gas Ass'n v. FERC, 912 F.2d 1496, 1514 (D.C. Cir. 1990); RCA Global Comms., Inc. v. FCC, 758 F.2d 722, 730 (D.C. Cir. 1985).
4. See also Letter from Donald P. Byrne, Assistant Chief Counsel, FAA, to Frederick G. Pappas, Jr., Director, Flight Services, Midwest Corporate Aviation, Inc. (June 24, 1991) ("[A] rest period must be prospective in nature. Stated another way, a flight crewmember must be told in advance that he or she will be on a rest period for the duration required by the regulations. In addition, a rest period must be free of all restraint. However, the Agency's interpretations hold that receipt of one telephone call or beeper call does not constitute a violation of a rest period provision. Moreover, a flight crewmember in a rest period must be free of present responsibility for work should the occasion arise.").
5. Interestingly, "rest period" is defined in section 135.273(a), a different section of the same subpart as the regulation at issue, added in 1994 to govern flight attendants in air charter operations. 14 C.F.R. ? 135.273(a) (2000); 59 Fed. Reg. 42663, 42663 (1994). It is there defined as "the period free of all responsibility for work or duty should the occasion arise," the very language used in the 1999 notice.
6. Compare Letter from Donald P. Byrne, Assistant Chief Counsel, FAA, to Frederick G. Pappas, Jr., Director, Flight Services, Midwest Corporate Aviation, Inc. (June 24, 1991) ("Does a pager check during a 24 hour standby period interrupt crew rest? . . .tandy does not constitute crew rest. The pager check does not interrupt crew rest because crew rest is not taking place."), with Letter from Donald P. Byrne, Assistant Chief Counsel, FAA, to B. Stephen Fortenberry, Evergreen International Airlines, Inc., (undated, in response to a letter dated October 12, 1989, with respect to section 121.471(d)) ("Is telephone standby in a hotel or at home 'duty'? No, not in the sense that it produces the need for the rest period required by section 121.471(d).").
7. The example given by the FAA brief (slightly corrected) is of a pilot who goes off duty at midnight on Monday night, wakes on Tuesday at 6:30 a.m. and would normally go to sleep again at 11 p.m. If the pilot is subject to recall on two hours' notice after 10 a.m. on Tuesday, conceivably he could be called at 10 p.m. on Tuesday for a flight at 12:30 a.m. on Wednesday at which point he will have been awake for 18 hours already, unaware that sometime during that period he should have gotten some sleep.
