Timebuilder
Entrepreneur
- Nov 25, 2001
FracCapt said:Mast bumping is still very much a problem - but the training these days adressing it is much better. When an abrupt maneuver is made that places low G loads on the rotor, the aircraft is no long pivoting underneath the rotor because it's not supporting the weight. Abrupt or excessive control inputs cause the rotor to move very quickly, and it can go beyond its design limits and part of the rotor head will actually make contact with the rotor mast. If this happens too much or too hard, the mast cracks....and when the mast finally fails, bye bye rotor. This is not just a problem with the Robinson line, but with all helicopters with a semi-rigid rotor system - including all of the Bell 200 series, the Huey, and several other types. Mast bumping was actually discovered on the Hueys back in the Vietnam time frame...and pilots were trained to avoid situations that cause it whenever possible.
Mast bumping occurs more on the Robinsons than other types because the most inexperienced pilots are flying the Robinsons. By the time somebody is experienced enough to be flying most of the other helicopter suseptible to this problem(which are mostly turbine), they know what to avoid, and how to correct it if you get into a low G situation.
OK. I was hoping for a clarification geared towrd someone who might not be familiar with the concepts, such as myself.When an abrupt maneuver is made that places low G loads on the rotor, the aircraft is no long pivoting underneath the rotor because it's not supporting the weight. Abrupt or excessive control inputs cause the rotor to move very quickly, and it can go beyond its design limits and part of the rotor head will actually make contact with the rotor mast. If this happens too much or too hard, the mast cracks....and when the mast finally fails, bye bye rotor.
Birdstrike addressed it very well. I should have stated Low G maneuvers rather than low G loads. Just like an airplane...in forward flight, push the cyclic forward quickly, and you create low or negative G's. The lower the G's, the less effective the rotor disc is(which controls all movement except for yaw). Everything I'm referencing here is strictly cyclic inputs - not collective or anti-torque pedal. When the disc is lightly loaded(therefore ineffective), the limits of the teetering hinge can be exceeded, which allows the lower part of the rotor head(a few inches below where the rotor blades attach to the hub) to contact the mast.What kind of "abrupt maneuver" would place "low G loads" on the rotor? Is the pivoting mentioned refering to the use of the antitorque pedals, or their incorrect or ineffective use?
Are "abrupt of excessive control inputs" a referece to "yanking" on the cyclic or collective?
Because the maneuver he described - dumping the cyclic and loading the disc by pulling more collective - is very much a perfect timing maneuver. Screw it up, and you end up with mast bumping...possibly more severe than if you had just dumped the cyclic and left the collective in position. It's best to just avoid the potential situation. Of course, when you're in combat - you do what it takes to survive, and if that means doing something you were taught never to do because it "could cause a problem"....so be it.Timebuilder said:One question: why is the Vietnam maneuver you described "illegal" today?
Only helicopters with two rotor blades are subject to mast bumping. Anything with more than two blades on the rotor system is either a rigid or articulated system, and therefore not subject to mast bumping. They each have their own issues, though. Not all two blade rotor systems are semi-rigid - some are rigid systems(which are not subject to mast bumping). I don't know of any helicopters in the military that are semi rigid that haven't been operated in the military for many, many years. Some of these military guys might know of some...but I know they still operate OH58's, AH1's, and UH1's.Do modern helicopters used by the military have an improved rotor system that avoids the mast bumping problem?
Unloading the disc in a helicopter does NOT cause it to stop turning. It keeps turning at normal operational RPM, maybe even speeds up(because of the reduced load). A helicopter hangs underneath the rotor. When you move the rotor, the helicopter is like a pendulum underneath. This is why when you turn in a helicopter, it banks just like an airplane. The airframe will seek a position where the rotor mast is at a 90 degree angle to the plane of rotation of the rotor. When you unload the disc(and I'm talking completely here - not partially - for sake of argument, ie zero or negative G's), the airframe is no longer a pendulum underneath the rotor. You can move the rotor and the airframe will not react at all. When the rotor is moved(via cyclic input), the aircraft(and therefore rotor mast) does not seek a perpindicular angle. When this occurs, it allows the rotor disc to tilt beyond design limits, and the bottom part of the rotor head makes contact with the rotor mast. If you don't use abrupt or large control inputs, this won't occur. The corrective action for low G's is aft cyclic - like pulling back on the yoke in an airplane, you create a load by supporting the airframe underneath it. You load the disc back up.sky37d said:Don't gyro copters have the same problem with unloading the disc, which causes it to stop turning, or something like that.
I found the lyics to The Everglades:I remember Whirlybirds also. Was on about the same time as Ron Reagan hosting Death Valley Days and some show about a guy screaming through the everglades in an airboat...Lincoln Vale was his name I think.
