Questions for G550 drivers?
1900heavy
Member
Total Time
7000
Just out of curiosity, do you guys ever single engine taxi?
I know you're boss is filthy rich, but still...I am with 121 Major and we
do it all the time.
One more question, how many pilots do you guys have per airplane?
Thanks.
SpeedRestricted
Active member
Total Time
.1
Filthy rich owners does not mean they are not cheap. The number of pilots varies greatly between operators and the types of operations being conducted. 91, 135, how many hours per year, do you need the plane available 24/7 or are most trips scheduled, is the owner cheap? etc etc...On longer international trips you often need relief crews to combat fatigue and comply with rest requirements. I've seen 91 operators with 1 crew for the plane and just fill in with contract pilots when needed. 135 operators and fortune 500 corp. tend to need multiple crews in order to maintain the availability of the plane.
TransMach
Total Time
>12K
G550 Questions
In the GIV / GV / G550 world there's hardly anybody with more than two pilots per airplane. Every "Third Guy" I know is out of work.
As for the GIV / GV / G550 "contractors" I know, hardly anybody is working at all.
Now for single engine taxi ... never seen it done in a "G-String".
TransMach
Gulfstream 200
Database Expert
Total Time
18,550
I know of no bizjet operators who taxi on one engine. The only time I ever did was in a Lear 25 at KTEB. Obvious reasons.
Most of the time bizjets don't operate out of the same busy, 37 inline for takeoff airports that airliners do. Also bear in mind we take lots of extra fuel, 2 hrs reserve is not unusual. Our pax dont want to hear "after 2 circles in holding we have to go to XYZ"
We currently have 3 pilots on the plane I fly, previous job averaged 4 per airplane. Jobs with just 2 can be tough jobs, unless there is no issue using contractors. Three fully qualified Captains on a long range A/C really is a minimum IMO. Anything less than that QOL becomes an issue.
Then again....these days guys are complaining less about working more.
A few years ago you were a chump if you only had 2 guys on your G550/Global and made less than 175K.....that today would often be considered a pretty good job.
Go figure.
GVFlyer
Total Time
18K+
We do not taxi single-engine. We man at 1.5 pilots per seat.
freighthumper
Total Time
6700
We taxi single engine when operations permit. Mostly taxi in, but sometimes taxiing out in busy places where an extended taxi or hold is expected. Even the filthy rich(and cheap charter) have to be smart about cutting down fuel expenses if they are to remain competitive these days. That said, the GIV isnt the best plane to taxi out single engine as many of the preflight checks are done with both engines running in the blocks. It takes a different procedure to get things up and ready for flight, but it is possible. Most times its more effective to just shut one down while you wait though.
BoilerUP
Citation style...
Total Time
1500+
I'll try to shut one down if we're pulling onto a crowded ramp and an airplane next to us is boarding...but otherwise no SE taxi.
2.5 pilots per plane
91er
Homey don't play that.
Total Time
7000
We do not single engine taxi. 4 pilots per airplane.
2EASYPilot
Total Time
Lot's
We will on occasion taxi with one engine shutdown on the 900. Four pilots per aircraft but then again we do 900 hours per aircraft a year.
AA717driver
A simpler time...
Total Time
+/-13k
Having gone from a very efficient 121 operation to the G550, my instructors and sim partner were VERY patient as I started one and taxied out, having my sim partner start the other one.
Same with checking the rudders on the taxi out (reeeellll smoooth...). The Gulfstream is designed for both engines to be started on the ramp and the flight controls checked prior to taxi.
Just go with the program, Tim... :rolleyes:
TC
gear_guy
Total Time
6000+
In the GIV you really are not saving anything by taxing single engine. This is mainly due to the excess thrust required to taxi especially at higher weights. If you have a long delay (more than 30 min.), it may be ok to shut them both down in the holding area. I have found that it is about 400# however you slice it.
falcondrivr
Total Time
10000
i fly with a pic in the g4 that s/e taxis all the time. there is a checklist in the afm for doing it. (basically just taxi on left engine) not my practice, but i have to defer.... he says that they calculated that in 300hrs/yr, they save $30k in fuel/yr. dont know if i believe it, but thats the story.
AA717driver
A simpler time...
Total Time
+/-13k
You based in EWR? ;)
Yeah, you'll save some gas but you're running the APU at the same time and jacking the operative engine to get moving.
I'd be surprised if you saved $30k/yr. in airline ops by s.e. taxi.
JMO.
TC
K.V.
Total Time
a lot
...then how does your friend ever functionally check the PTU and the single rudder limiter??
