Flyin2low
Indentured Servant
- Jan 7, 2006
The "banana bar" is a Collins proprietary feature.
That's funny because the Honeywell FMS had one too?
Putting the lowest altitude in and flying the snowflake works but you have to be paying attention (4eyeballs) and adjust VSI to hit the constraints along the arrival, even leveling off for a short time when the flake disappears and then continue the descent when it reappears. Seriously cuts into USAToday time...
I am going to address you first part prior to your edit. You must not really understand true VNAV. I would never want an airplane to start down on its own because it reached TOD. I would though if I were CLEARED to descend VIA. if you trucking along at FL340 and have been cleared to descend at pilots discretion or VIA XYZ arrival in an airbus and set in your lowest alt the bus will maintain your cruising alt. Now in a boeing or any other plane with a coupled auto pilot and a true VNAV you set in your bottom alt WHEN CLEARED!!!! and the airplane will start down at the TOD.
You are correct you would get in a lot of trouble if we had airplanes with out clearance starting down to a lower alt with out pilots input. Come on man!
That's the only way to do it. I have been told that VPA 2.4-2.2 works to set up a continuous descent on the Freedom or Truups arrivals. Maneuver between the snowflake and bananna and have a lot of Pilot Deviation reports ready to file.
