Question for RJ drivers without VNAV
The way ASA has us doing it by dialing in the lowest hard altitude and following the snowflake really bothers me because you are setting in a lower altitude then you are cleared to. Works great until you get distracted and try to catch up. There is nothing to stop you from descending below the min altitude except the snowflake. People will bust altitudes with this method without a doubt!!
If you follow the snowflake you will not bust an altitude. As far as getting distracted, that's why we get CRM drilled into us every recurrent
I love when people like 777 say that they cannot get distracted, won't be a month until you are covering your a$$ with an asap. I have seen people forget to descend on a mandatory altitude I can't count how many times. So let's say you do, even though I know you are a super pilot and begin to descend at a higher rate to catch up. Throw in a single chime, no big deal and you start to address it. You are now descending faster than you should be to catch the snow flake and you forget for like 60 seconds to adjust. OOPS!!! You went below a min alt. You have to be kidding me to think because you took a crm class you can't seriously F UP!! I prefer to know that I can and will so I don't set the lower alt until I cross the fix that allows it.
Right but if you have several consecutive constraints, aren't you doing a lot of "diving and driving" to make the next constraint? In otherwords, in an A320 for instance, you get a "descend via" clearance and you dial in the lowest alt on the arrival and the VNAV and A/P fly the aircraft to make each constraint. I would imagine in the RJ, you would be doing a lot of tweaking with the VS wheel making sure to hit at or below, at or above etc.
Sometimes you have to put the sammich down and do some of that pilot stuff.
Seriously?!?! You'll be one to bust an altitude thinking it will never happen to you.
Here’s the official definition of Advisory VNAV from AC 90-107
a. Advisory Vertical Guidance. Vertical path deviation guidance indication that is
generated by any means, but is only an aid provided by some manufacturers to help pilots meet
altitude restrictions. Advisory vertical guidance is an optional capability implemented at the
manufacturer’s discretion; not a requirement for positioning and navigation equipment.
NOTE: It is the pilot’s responsibility to use the barometric altimeter to
ensure compliance with altitude restrictions, particularly during approach
operations. Advisory vertical guidance is not approved vertical guidance like
that found on approaches with lateral navigation (LNAV)/vertical navigation
(VNAV), LPV or instrument landing system (ILS) lines of minima.
I remember when I was at CoEx (now XJT) we were doing these "decent vias" ten years ago. They wern't the optimums but you still dialed down to the bottom crossing restriction as now. And as someone earlier mentioned, the old 3-1 worked just fine..
Did they have crossing waypoints every 4 miles that don't line up with each other? The 3-1 method still works because the design uses 2.2 degrees, but you would fly under the crossing alt unless you leveled off every 2.347543 miles.
3:1 doesnt work because the glidepath changes from fix to fix. You risk missing a window.
Only the FAA would design something that is "optimized" yet is only a 2.2 degree angle. What is that optimized for? Certainly not fuel burn in a jet airplane unless you count burning more gas than necessary during a descent.
Maybe just a couple that were that close together. The 3-1 worked out fine and I always based it at about a 2000 fpm descent rate, give or take adjusting for a headwind or good tailwinds. These new optimums give a couple thousand feet window to allow for that which helps. To me its much easier now than before when everything was a HARD altitude restriction.
I disagree that it's much easier now, but it's possible that I'm just not that smart. Take the FRDMM1 arrival into DCA for example. There are no less than 14 different altitude constraints. You can't assure that you will make every single one without doing 14 simultaneous descent calculations, or without just blindly trusting the "snowflake." Three are "at" altitudes, one is an "at or below," and one is "at or above," while nine are "between" altitudes, making descent calculations very difficult. There are some arrivals where you need to be at one end of the range or the other, in order to make subsequent restrictions, but that sure is difficult for me at least to figure it all out.
Also, the whole point is to have all the aircraft descending at the same rate and speed (to ensure good spacing), but with these altitude ranges, it is very possible some aircraft will be at the high end and others will be at the low end, where they will have very different ground speeds. I thought having just a few hard restrictions was much easier, and kept everyone at the same altitudes for the entire arrival.
Pull up the Dir to page on FMS and it will give you descent rate for all crossing restrictions. Vert speed and your all set to make all restrictions adjusting vert speed as needed
That is what I did when I flew the RJ. Best way to make the cross. For the at or below/at or above windows, I change the altitude to the middle altitude. 13,000B/10,000A I set 11,000. Keep in mind that you may have a short distance between that last B/A altitude and the mandatory cross at the end of descent. And yes, the speed restrictions dick up the whole calculation! So be careful out there!
They might want us all spaced nicely, but this scheme won't accomplish that goal. They will get what they are asking for, and not what they want!
I go out on a limb and say that these "optimum" RNAV arrivals we're built with VNAV capable aircraft in mind. I'm based in PHX and that was one of the first places to use these arrivals. The engineers and flight managers from my airline built some of them and we used for testing these arrivals. Having a plane with VNAV makes all the difference I suppose. I'm on the Airbus, and fifi doesn't have too much problem handling them. Once and a while it'll bite ya, but if you keep monitoring, 9 out of 10 times you're golden.
An ATP and asking if there is a "rule-of-thumb" for descent planning??? Geeze, I picked a bad week to stop drinking after hearing that!
I was referring to rules of thumb that non coupled VNAV aircraft are using flying STAR procedures with numerous constraints. For example, a 2.2 VPA was mentioned. It may work for one arrival but not for another. Judging by the responses on this thread there is no standardized way to fly these, and the dive and drive currently being done is contrary to what the designers of these procedures are trying to accomplish - less workload and better efficiency.
And yes I do know the 3 to 1 and 5xGs rule. I was seeking information so I can communicate to the designers the issues being experienced on the line. It didn't warrant a smart ass remark from you.
Welcome to the world of amateur smart ass remarks...This is flightinfo.com and NOT a forum of professionals...sarcasm is the rule of law here...So, move along...
If you had said this in your first post you might have gotten some better responses IMO.
This thread turned into a technique thread, which now knowing what you were seeking the information for, was not what you were really looking for at all.
It all dive and drive for CRJ operators and 500% workload increase. At least we don't have to do the NUMMY arrival which has the same crossing windows and no VNAV.
