Question for RJ drivers without VNAV
Always deferred
A lot of the new optimized STARs in the NAS are being designed as Optimized Profile Descents, with at or above, at or below, and window altitudes designed to minimize level segments. (ex: FRDMM, TRUPS, EAGUL, etc)
Obviously these are more easily flown in VNAV, autothrottle equipped AC. My question for you drivers of CRJ 200/700 and legacy ERJ aircraft, how are you managing descents on these STARs while complying with the myriad constraints?
Is there a good rule of thumb, or are you pretty much flying the V/S wheel and hoping to make the restrictions?
AD
3-1 rule still works great. The "banana" is a nice back-up.
We have VNAV on the CRJ200/700/900. It's not autopilot coupled so its technically called Advisory VNAV. It makes ODPs simple and easy. We just follow the "snowflake" down using V/S
Right but if you have several consecutive constraints, aren't you doing a lot of "diving and driving" to make the next constraint? In otherwords, in an A320 for instance, you get a "descend via" clearance and you dial in the lowest alt on the arrival and the VNAV and A/P fly the aircraft to make each constraint. I would imagine in the RJ, you would be doing a lot of tweaking with the VS wheel making sure to hit at or below, at or above etc.
The VNAV advisory on the CRJ's is a LOT better than the one in the Boeing (or at least the old faithful rig I fly) there is no "diving and driving" in neither the arrivals nor in non-precision approaches. The only negative as someone posted is that you have to tell the autopilot to do what the advisory is indicating, but I can assure you it is a lot better.
The "snowflake" looks at the entire decent profile while the VNAV info displayed on the PFD looks at the next waypoint. Fly the snowflake and it should all work out.
The A320 does not have VNAV, if you have an arrival and set in the lowest altitude, the aircraft will keep on trucking along at your cruise alt until you push to managed the decent. True VNAV aircraft will start down on their own when VNAV is engaged.
It will give you the down hockey stick and tell you to decelerate when at TOD. but again will maintain cruise alt until you tell it otherwise.
Sucks if you ask me.
Putting the lowest altitude in and flying the snowflake works but you have to be paying attention (4eyeballs) and adjust VSI to hit the constraints along the arrival, even leveling off for a short time when the flake disappears and then continue the descent when it reappears. Seriously cuts into USAToday time...
Yes on an arrival such as the FRDMM, you cannot just fly the snowflake.
And from what I understand, the ERJ doesn't even have the banana bar.
there is the rub. Absolutely no way to back yourself up other than being on top of your mental math from top to bottom. If you have an "at or above" or "at or below" it may put you right at the altitude, based on what it sees down the line on the ODP. All well and good until you are a little off the 'flake at just the wrong time. The guys who created these jacked up procedures arent going to be the ones getting violated if you miss an altitude......
PS: watch out for those speeds, they can throw the whole equation out the window......
Direct to page on FMS
Pull up the Dir to page on FMS and it will give you descent rate for all crossing restrictions. Vert speed and your all set to make all restrictions adjusting vert speed as needed
I disagree. I'd like the airplane to go down when I want it to, not necessarily automatically at TOD. There are even times when ATC keeps you high, flying past the hockey stick. You still stay at your cruise altitude. Would a Boeing start down automatically? That could get you into trouble if you aren't ahead of the game. On the flip side of the coin, you can of course argue the SAN-MSP NWA Airbus would have never overflown MSP if they automatically started down on the hockey stick like a Boeing does.
Edit: Boeing has LNAV and VNAV modes that show up on the FMA, an Airbus does not. It has NAV (like nav in any other FMS jet), and it has a managed descent function which you have to push the altitude knob to activate. You do set the lowest altitude for the arrival and once at or near the hockey stick, start down. It'll hit all points and speeds, and give you advisories if it thinks it won't meet a certain waypoint constraint (like 'more drag' which to be honest is done with a horrible calculation and quite a few times it mentions that even when you don't technically need it). Overall, I'm satisified with the descent functions of the A320.
