Question about IAH?
The shuttle from Terminal A to Terminal B runs on demand, i.e., if people need to transfer they have to call one over there. I think they pull one off of the B to E route, so it may take a few minutes just for the bus to arrive. I would just haul butt down to the inter-terminal train one level below baggage claim and go through security over at B. The lines are never very long over there. One thing I'm not sure about is if you'd need a jumpseat pass to get through security. If so, you'd have to wait in line at the ticket counter. Let us know how it goes.
inthegoo said:
hey saluki,
ok i got it, only the one part of terminal a where delta is has the bus where u dont have to exit security to go to B, so what if I arrive on frontier from den instead of UAL is that in the right place to not go through security?
thanks
Yes, you would be in luck if you took Frontier, as they park right across from Delta in Terminal A. Definitely, the Airline to fly if you want to make your flight in Terminal B. Good Luck!
20 min connection from A to b, takes a major set of cajones.
First of all, you are talking IAH.
What makes you think your flight will actually land on time?
Been commuting to IAH for a year now, and nothing is more frusterating than sitting in the cockpit watching the weather at IAH NOT allow you to land.
Second, waiting for a bus can take more time than just doing the OJ run. If you decide to do the run, take the elevator, or stairs to the basement. Get on the underground train, or if the train isnt at the station, OJ run again to Terminal B. Once at Term B, run up the escalator, or take the elevator to Ticketing level and security is usually a breeze if you are in uniform.
Good luck, it is IAH after all!
