md83drvr
Active member
- Nov 26, 2001
The NTSB report you cited has nothing to do with the APU operation. It would not affect the out come if an APU was/was not running and a fuel truck catches fire. I'm sure the crew in the report you cited had the APU running, most likely for heat/AC if they were sleeping on board. If you are going to cite an NTSB report find one that is relevant.
The APU inlet on the CRJ is on the top, almost no danger of ingesting anything from the ground. The exhust is from the right rear, and the "danger area" is only 15 feet. If you watch the crews do their walk around most guys are within that area, it is not that hot, there is more of a danger of your hat blowing across the ramp.
I don't know what you see as close proximity to aother a/c, but in DCA the aircraft are no closer than any other ramp/gate area.
If you actually know anything about fire science then you would know that the danger from JET-A is not the liquid but the vapors. No vapors with SPR. Plus the SPR is on the front on the wing well clear from the APU exhust. There is more chance of a static discharge causing a fire/explosion then the APU. That is why the fuelers ground the aircraft before they connect.
With my 19 years in aviation,most as an airline pilot and 20 years in the fire service (carrer and volunteer) I feel comfortable everytime I walk away from an a/c with the APU running. Don't over react, and don't try to Monday night quarterback.
