Possible Violations @ CVG
You mentioned the maltese cross. The cross is not applicable on an ILS approach.
Only with reference to specific procedures and profile flying. The FAF on the ILS is depicted by the maltese cross on the approach. It can be defined only by a second navaid or DME.
Man ...
You are WRONG..
So much for reading your posts in the future.
You are quick to spout off but evidently should read more and talk/post less!
Man ...
You are WRONG..
Its called a "fluid conversation". Try to visualize things "outside the box". I am trying to clarify things to someone who was completely wrong about what he/she said. I got a little mixed up and made a boo-boo. Get over it, I did. Lets keep talking.
Notice that I corrected myself in post #19 before anyone said anything.
I know in ORD it's also been a problem. Moral of this story don't be lazy and arm the appr. Fly the step downs.
Yeah, that was my bad.
My point still stands. GS intercept is not always the FAF on a precision approach.
yes it is. the final approach fix on an ILS is ALWAYS the PUBLISHED Glide Slope Intercept Altitude (including any lower authorized altitude which will be noted on the plate). The FAF doesn't magically move depending on where you decided to intercept at. On NACO charts it's the lightning bolt symbol and on Jepps it's where the published altitude intercepts the feather. The Maltese cross is for non-precision use ONLY. I think that you are confusing the published glideslope altitude at the FIX (which is for "reality check" purposes) and the GSIA. In the case of CVG's ILS 18C, they are the same. Check out BOS ILS 4R. The GSIA/FAF is 1800, but the GS altitude at MILTT is 1723.
http://www.naco.faa.gov/d-tpp/0710/00058IL4R.PDF
In this case, if you decided to fly the glideslope down from say 5000, you would still be responsible for ensuring you meet the minimum altitudes at WINNI AND NABBO, but the FAF still remains at 1800 ft on the glideslope.
When shooting the LOC 4R, the FAF is MILTT D6.9/RADAR and the minimum altitude is still 1800.
yes it is.
No its not.
It will be the lowest altitude only. There will be no other step downs for a precision approach.
Thats what I am saying!
I did, and I noted that. Thanks.
No its not.
i don't understand this statement. give me an example of when you think the FAF on an ILS is not the published GSIA. remember that i am saying there may be a caveat on the plate that a lower GSIA is authorized. for example, the lightning bolt altitude will say something like "*1500 when authorized by ATC" and only used if ATC clears you down to that altitude PRIOR to intercepting. either way, it will still be PUBLISHED on the plate. the FAF can't ever be some point or location that gets made up on the fly.
I am talking about a straight forward ILS approach. Special notations do not apply to what I am talking about.
There is one GSIA only. At that point, and only that point, you will be considered to be at the FAF. If you intercept the GS anywhere above that, you are not at the FAF for that approach. Another posted insisted that you can intercept the GS above the stepdowns and it bcomes the FAF, when it does not.
Now, if there is a special notation, the FAF moves to that lower depicted altitude if you accept that clearance during the intermediate segment.
Discussions on FI are really getting bad...this is basic airmanship stuff...Shouldn't this be in the Flight Instruction section? At the rate we're going we are going to be discussing "ground effect! Myth or Reality?" by the end of the year.
The Russian has extended this thread about ten posts longer than it needed to be.
Here's the only answer.
GLIDESLOPE INTERCEPT ALTITUDE- The minimum altitude to intercept the glideslope/path on a precision approach. The intersection of the published intercept altitude with the glideslope/path, designated on Government charts by the lightning bolt symbol, is the precision FAF; however, when the approach chart shows an alternative lower glideslope intercept altitude, and ATC directs a lower altitude, the resultant lower intercept position is then the FAF.
Here's the link to the website the definition is located at. Notice the link starts with 'faa.gov', that's a pretty good indication it's good information.
Do you expect everyone to know everything? The truth is, a few people were wrong on this thread, not just one.
Incorrect. The posters who never actually read the thread and saw that I corrected myself in my next post extended this longer than it should have been.
That is exactly what I stated, proving that people who don't pay attention help to drag this out.
Do you want a cookie?
You've just extended the thread again to argue that you know what you are talking about. No one cares! You don't have to defend yourself, that is what's extending the thread which adds nothing.
I'm done with this thread, you can have the last word...I'm sure you'll take it.
Absolutely not.
What?!?! You bumped the thread more than 24 hours after my last post and basically accused the discussion itself of not getting to the point! All the while, if you had read the thread thoroughly, you would see that we had reached the point and clarified everything. Everyone who posts in such a way, extends the thread. Don't be upset with me for using the forum for what it is designed for.
Don't take it so personally.
while I agree with most posts I also think the FAA could solve many of these problems by slightly changing the procedures.
Many modern jet airliners are not designed to over-ride the gs capture. For example the md-11, except for a few that have loc track only either do approach mode (full ILS) or you must do approach in NAV only which is based on IRU navigation resulting in less than precision tracking. Can it be done, yes, but at the same time my point is people are consistently screwing it up so what can we do to improve the approach?
Can the MD11 Fly down hill in VS? and heading select?
I know it less than perfect but it might give some good pilot control that way.
By the way I agree with you about the faa. But lately it seams that we are forgetting how to hand fly the airplane.
Remember the days when you clicked off the autopilot at top of decent. how did we survive?
I miss flying jets. now we just try to stay ahead of the automation.
Omg
Are you kidding? Are you back in instrument kindergarden... I think there is a place for this question on the ABC's of flying on a different part of this site. You work for FedEx?
Running the numbers, LAMAH to ANTRI is 344 ft/nm, LAMAH to LOGOZ is 338 FT/NM, DULEY to LOGOZ is 333 ft/nm and LOGOZ to 2.9dme is 325 ft/nm. The 325 ft/nm is the "slope" of the glide slope. Work this backwards 2.9 dme to ANTRI is 14.2NM. At 325 ft/nm that puts ANTRI at 4647.5 feet above the 2.9dme fix. Add in 1260 (the MSL height you should be at over the 2.9dme fix) and you get 5875.
The chart itself is misleading. Most step downs have a "step" look to them. This looks like you are supposed to follow the GS from LAMAH inbound.
I don't have an IFH in front of me, but I seem to recall there being something specifically writting about "angled" lines and step like lines on approaches, but I may be starting to loose it.
USAF interpretation
Here's how the USAF IFR rules reads:
11.5.5. Altitude. When cleared for the approach, maintain the last assigned altitude until established on a segment of a published route or IAP. At that time, the pilot may descend to the minimum altitude associated with that segment of the published routing or instrument approach procedure.
Hence, the pilot would need to meet the stepdown altitudes, and not go below just because they are established on glideslope.
Exactly.
Some operators and aircraft types require a different configuration to "dive and drive" resulting in wasted fuel, pollution, noise and slower approach speeds.
I'm kinda glad someone mentioned this in a public forum so we can all be aware of the issue. Most of us probably would have caught it, but getting close to a 16 hour duty day I think anyone can get a little lazy and couple the thing up with the glideslope.
What some people say on here really scares me knowing that they are up there!!
A few weeks ago there was a discussion where some seemingly experienced pilots claimed that it wasn't legal to go below DH off an ILS missed.
Soemtimes I scratch my head about the ignorance some professional pilots display of the rules. :confused:
Boy, no wonder so many people are leaving flight info. Way to help better the general pilot group out there, fellas. Ya know, learning is facilitated through respect, allowing questions, and giving room for improvement. By jumping on people who might not be clear on issues, you are actually facilitating ignorance, rather than clarity. Good attitude, guys!
Just the fact that the controllers are going nuts over a problem being repeated shows that there are plenty of airline pilots unclear on the rules. If there are plenty of pilots unclear on the concept, maybe it's time to look at why they are unclear, rather than personally attacking someone who is unclear. That just doesn't help. The fact that there are apparently many airline pilots making this type of mistake pretty much proves that, in fact, this is not a basic "instrument 101" concept. Learning doesn't stop just 'cause you're an airline pilot. Just because someone passed a 121 ride doesn't mean you already know all there is to be known about flying. Personal attacks aren't going to solve this.
The moral of this thread is: If you aren't sure about something, don't you ever dare to ask about it on flight info.com.
I totally agree...ultimately the pilot needs to get it done correctly, descending in prof/ vs/ whatever and naviagating in some form of nav, loc track, heading , or track....great
however, without having flown there , I believe we referred to ry 18c....a center ils seems to imply they want or require precision, whether or not it is a PRM or not so why not make it easy for us and let us fly it like the other 9000 airports around the world...if I am cleared for an ILS why should I be flying in vertical speed and heading....all I am saying is the FAA could reduce the chance for errors rather than blaming all us dumb pilots.
also if I was planning 18r and at the last possible minute they change me to 18c, I would scramble to get the freq and arm approach land , and very likely miss the fact that the glideslope did not coincide with the stepdowns....
It is one thing to get caught busting something when you know better...it is a completely different matter to not even KNOW that you are supposed to meet the step downs. I'm sorry if I offend anyone but if you are an airline pilot and you are SURPRISED that you need to meet the stepdowns then you deserve whatever ribbing people give you. There is a difference between accidentally landing without a clearence - and not even knowing that you were supposed to get a landing clearence.
I do see how these "accidental busts" can happen, I don't see why Jepp can't just put a heads-up note on the approaches that state something like "warning-GS outside FAF does not assure compliance with step-downs" or something to that effect for those of us in our 15th or 16th hour of duty.
Later
I can't believe this has gone on for four pages. Someone gave the correct answer within the first few posts. Obviously, KCVG uses this procedure for operational reasons and it seems that the step downs were designed that way on purpose. It looks like a lot of CFIIs haven't been doing a very good job. Scary.
Nothing new here. It seems many who should know better routinely confuse MDA with DH. When I got my ATP (long long ago in a galaxy far far away) the FAA inspector chastised me for going below DH on an ILS miss. This was in the aircraft, with the inspector calling no runway at DH. I argued, sucessfully (I passed), that DH means decision height, or the point where the decision is made to execute the missed approach, and that the airplane is not static at that point but will continue to move in the established direction. You cannot make the decision at DH and not go below decision height.
Absolutely excellent post. We all have things to learn and we need to extend respect to others when helping to educate them. I, myself, am guilty of being wrong about technical subjects here and there.
The last time I flew with a CFII was twenty years, four type rides, and two airlines ago. People forget.
We probably all remembered the requirement to follow the step down fixes, but unless you fly outside the United States, there are few precision approaches where the use of the glideslope does not provide adequate guidance and plenty of room. (that probably explains why Delta is getting this right and other airlines might be overlooking it)
Worse, at CVG the Jeppesen Chart depiction (although we know it is not to scale) clearly shows the glideslope well over the stepdown fixes, which is not normal convention. This is an easy thing to miss unless you perform the math, or put the step down fixes in the FMS.
Unfortunately the avionics in the average 120 knot avgas powered bug-smasher provides much better SA than the average jet in 121 service. In fact, the RNAV procedures have resulted in the removal of most of the step down fixes on precision approaches since something had to be deleted to make room. Even the RJ's have 1980's tech in the FMS.
Well I dunno, as I recall the AIM was pretty clear- GS signal is not valid outside of 10 nm. If you're outside of 10 miles, you fly the profile-Inside 10 miles, the glideslope is valid. As some else posted, the CIVET arr/profile descent into LAX25L had this same problem with guys getting violated, and that was about 10 years ago. A heavy DC-8 always seemed to be on the high side of each crossing restriction at idle power clean and 250K so Mr Douglas had figured it out for me. Sounds like some controllers with too much free time on their hands.
