Pinnacle Pilots: "Just wanted to have fun"
CatYaaak said:
The unrelenting level of immaturity revealed here is nothing short of shocking.
The immature person....
....banks and yanks and stresses airplanes not their own, without any thought for who may be flying it after them, or the pax who will be in it later.
....shows a complete disregard for the notion of "setting an example" for a relative new-hire.
....doesn't question when another pilot, even if more experienced, is doing obviously stupid things and making decisions the one's signing the paychecks wouldn't approve of....a situation, btw, that was probably posed to them hypothetically in an interview, and undoubtedly answered that they WOULD question the other person in the interests of safety. (Along those lines....)
...Lies. To the company, to ATC, to themselves. They think nothing of it. It's their world, they think, and everybody else is just livin' in it.
.... does things for "the fun of it" along the lines of lying on highway centerlines, playing with guns, and clawing for altitude even when they know they shouldnt be doing any of them. They can't differentiate between "fun" and "stupid". This is because immaturity also has them believe that a squished torso, a splattered brain, or winding up in a smoking hole is something that happens "to someone else", reams of historical evidence regarding their types in general notwithstanding.
....walks, acts, and talks like a child when they think nobody's looking, dude.
..is in denial and oblivious to anything they don't see with their own eyes, and doesn't bother to find out something they don't know of their own volition, even if it's their profession, and a big-boy/girl one at that. They can even be in denial after you've put yourself smack in the middle of the World of Hurt.
...can't excercise good judgement over any period of time because judgement requires knowledge in addition to the experience, and immaturity while engaged in edeavors that require critical thought spells Ignorance.
Is there any question that poor judgement driven by immaturity is at the heart of this accident?
From the FDR and CVR data:
At a known weight, at ISA +10 temps, flew off the performance charts available to them. On the way up, playing "Zoomie" numerous times complete with stick shaker...the first immediately after T/O. Seat swap with nobody at the controls. Request an unchecked-by-chart altitude for "the fun of it", 8,000' above what they were dispatched for. Continued climb well below profile Mach #, knowingly. Focus on FF instead of where it should have been. High altitude climb using VS instead of Mach Hold. No discussion (and therefore apparent unawareness) as to their razor-thin and unmaintainable situation. No references to Temps Aloft at their new, unplanned altitude. Immature glee to have clawed up there despite ridiculously/dangerously low Mach. Noted decaying Mach in level flight numerous times. Immaterial references to IAS. After arriving at the predictably unmaintainable altitude, PF exhibits his ignorance of the "Altitude Question" by questioning PNC (Pilot Not in Cockpit) PIC, who repeatedly displays amusement and confirms that they won't be able to stay there. ATC notes not only high altitude, but most importantly decaying groundspeed to the point it's mentioned between controllers.
No sense of urgency from either of the crew to get lower NOW while speed decays and pitch increases until the A/P diconnect and the shaker. After the shaker, the pusher...then numerous pushers each followed by what the FDR would indicate to be the PF pulling the aircraft into every-higher nose-up attitudes, exacerbating the problem by trying to maintain altitude AND NOT LETTING THE AIRCRAFT DO WHAT IT WAS DESIGNED TO DO, which is to get headed earthward in a controlled manner. During, and probably because of, these occillations the engine airflow was blanketed to the point the cores completely spooled-down. You want "core lock"? Do what they did and not what the airplane is wanting to do! Kept up the PIO to the point a wing dropped...82 degrees of bank. Apparent unawareness to smoked #2 engine due to pegging out ITT at any point from then on.
Oh, and this little ommision.....
THEY AVOIDED AND PURPOSELY DID NOT COMMMUNICATE TO THE FACT THAT THEY WERE NOW A GLIDER TO ATC, WHO WOULD HAVE IMMEDIATELY BEGUN ADVISING THEM AS TO LOCATION AND OFFER VECTORS TO THE CLOSEST AIRPORT. IN FACT, THE REPORT INDICATES THEY HAD THREE OF THEM AT THAT POINT.
Never achieved windmilling re-start IAS in the glide after starting APU. Not even hand-grenade close. No attempt to achieve it prior to windmilling re-light envelope. Seeming consternation as to why no N2 indications, or a re-try for min windmilling speed after the proper checklist was finally read. Instead, immediately focusing on APU start and low best-glide speed when achieving book windmilling speed but seeing no resultant core rotation where it should have been MIGHT HAVE CLUED THEM IN THAT THEY WERE A GLIDER AND NUDGED THEIR BRAINS INTO THAT HARSH REALITY, AND ACTED ACCORDINGLY WHEN THE OPTIONS WERE BETTER....FIND A PLACE TO LAND...DO EVERYTHING ELSE AFTER DOING THAT.
but instead...
STILL NO COMMUNICATION TO ATC OF THEIR DIRE SITUATION. CREW PURPOSELY KEPT UP THIS RUSE BY USING PHRASES SUCH AS "getting the OTHER engine started" WHEN DIRECTLY QUERIED. Is this the Clinton Approach of trying to mitigate or downplay a mistake that might paint you in an unfavorable light?...."Yes, I tried pot once" (yes, we went too high and stalled the airplane), "I didn't like it" (We are now doing the right thing and asking for lower)...."Didn't inhale!" (Hey, we'll pretend we only lost one engine so it won't seem so bad!). And importantly, no discussion even amongst themselves as to WHERE TO LAND THE FRIGGIN' AIRPLANE IF THEIR "A$$HOLES AND ELBOWS" APPROACH TO AIRMANSHIP AND SWITCH-FLIPPING DIDN'T WORK.
Swapping seats again..nobody at the controls. APU start doesnt work. and finally...finally....
an admission to ATC that they have lost both engines, at 8,500' AGL...about 30,000' too late, and even then it seems to come because they know ATC will see they can't maintain altitude. It's only at the last moment they seem to realize the gravity of the moment...their reality.
You know guys/gals.....
Machinery, even highly-reliable and proven engine types like CF-34s can fail if you abuse them. He11, these guys were semi-abusing this airplane structurally throughout the climb. Thats why they have limitations. For those saying that "there's no reason the engines shouldn't have re-started", go back and re-read the FDR starting just before FL410 shaker until losing electrical. Think about the recorded AOA's, pitch angles, column forces, airflow, engine temps, OAT, G's, oil, fuel scheduling, and what those engines went through. Compare that with what an engine would go through if they had let the pusher do it's job and established a hand-flown descent when they should have. If you still think it's a suprise they couldnt be re-lit, well I wouldn't even trust you with my car and no doubt still can't figure out why the airplane didn't fly at it's "certified altitude".
Training is never perfect. And yes, this airline's training prior to the accident regarding high altitude flight obviously sucked....they depended on their pilots sticking to flight plans, thereby operating well-within the aerodynamic womb...not on the fringe, and they didn't sufficiently stress the dangers of going outside it. But it remains that if the crew had stuck to, or even marginally adhered to the plan, it wouldn't have happened. And like someone else has mentioned, for lack company training neither pilot reflected a self-education of knowledge (that even if the company didn't provide it) is very basic to flying jet aircraft at high-altitudes and is readily available from many sources. Educating yourself to a higher degree than what any company can spoon-feed you is part of what proffessionals do, and i make no apologies for saying that if you're getting paid to captain a jet you better know this basic %@#@.
Everyone can make mistakes, and everyone does. Everyone has lapses in judgement, but usually singular and temporary. This whole event, on the other hand, is a friggin' showcase of immaturity from the get-go. This is the kind of thing only peer pressure can solve. I know the vast majority aren't like this. Hopefully, they'll apply the pressure to maintain standards and change those who can find a maturity level that befits the profession, or drum out those who can't.
RIP to those guys, but it's only sheer luck they didn't kill or maim someone on the ground as they sat in their living room, layed in their beds, or drove down the street. To any who still think "No Pax =Playtime" and airplanes are just a big 'ole toy, it's NOT just your World, and there ARE other people living in it. If you want to play find another way, like rent a Pitts, go find a remote area and get your ya ya's out like I do. Or something. However you do it, it's just like your mother told you, there's a time and a place for everything.
The whole thing, and some of the responses excusing it, disgust me.
YEAH! What he said!
latinachick said:
F/O failed his commercial multi because he left the baggage door open......it wasnt because of his flying ability!
Yup! You're right. It never got that far.
latinachick said:
actually i'm sorry...now that i think about it....he left the key in the door but had the door closed.....gosh the things you do when ur nervous!
Oh THAT changes EVERYTHING!
I blame the instructor who taught him. Key goes on the dash as soon as the door's open. That way when the key is used for the mag switch everyone can see where it is in the windshield while you're NOT using it - mag switch is safe. When it's not needed for the mag switch at least it's not in your pocket.
Curious,,,how many light twins actually have mag switches run by keys? I don't know any, but I hava only flown about 20 types or so.
Sure I missed a few.
That makes all the difference in the world. Why should a guy bust a ride for something minor like that?
After all, the sim instructor said Jesse flew the plane just fine but had problems with checklists and judgement.
When will people realize that stick skills are all that matter??? :rolleyes:
very well said in all of it. not to monday morning quarterback, but we are airline pilots. PROFESSIONAL airline pilots. flying modern jets. we should always be prepared to be bitten during NORMAL operations.
to invite danger in this profession is not a way to enhance your ego. to avoid danger is the best attitude to have and a key to making retirement age.
the job is fun. loads of fun. in normal operations. these aren't toys. they have been flown to their limits and beyond by professional test pilots. i'm not a test pilot. the numbers are my guidelines to operational safety...and my way home after each flight.
CitationLover said:
why is it that regional pilots will be looked at differently?
did they look at "professional" american pilots differently when they took out runway lights in denver this winter? landed in a T/S and overran a runway in little rock? crashed into a mountain in Cali? tore a rudder off an airbus doing exactly what they were trained to do? oh those "professional" delta pilots who forget to set the flaps for takeoff, "professional" eastern pilots who disengage an autopilot and crash in the everglades, etc etc.
cut the "professional" crap here. it was an accident (like all of the above were). we all look like sh!t at our worst moments.
one maxim definitely held true here. there were an unfortunate "chain of events" leading up to this.
UM, your examples are accidents, 3701 was careless and reckless. NO ACCIDENT. Just reading your post, and seeing what you fly scares me. It is not all your fault though, it is the culture you work in. Your company thrives in it. Don't respond to defend this careless and reckless incident either. It will only paint you in a corner and myself along with the others will catagorize you into the same group.
One point SimonSays forgot to point out was the innacuracy on the EAL crash in the Everglades. The AP was not disconnected by the pilots. If the associated poster had gone under a real CRM training regimen, he'd see stark differences in his examples.
I'm with SimonSyas in that this was pathetically avoidable.
You really need to stop defending your boyfriend.....It makes you look bad, and him even worse. Do you know how many accidents are caused by just leaving a baggage door open on take off.
AYYYYYYY PAPI!!!!!!
so forgetting to set the flaps for takeoff is an accident?
crashing an airplane into a mountain is an accident?
landing in a thunderstorm with up to 45kt gusts is an accident?
3 PILOTS not flying an airplane in a slow descent while concentrating on one minor problem allowing said airplane to crash in the everglades is an accident?
crashing an airplane due to a dual flameout with the a/c being above the charted max altitude was careless and reckless? seems to me all of the above were also careless and reckless and PREVENTABLE (links of the accident chain).
like these other preventable accidents, this current one will be used to teach pilots. my CRM course taught me to be open minded and finding things in ALL accidents that might be used in my flying habits to change myself. of course, it wasn't a REAL course according to you.
as far EAL: the NTSB concluded that the A/P was on but the mode allowed for unintentional pitch changes (p. 26 of pdf), so in essence it was unintentionally disconnected from an ALT hold mode (sorry for the semantics).
http://amelia.db.erau.edu/reports/ntsb/aar/AAR73-14.pdf
"REMARKS- CREW DIDNT MONITOR INST & DETECT UNEXPECTED DESCENT.PREOCCUPIED BY NOSE GR PSN IND SYS MALFUNCTION"
