brokeflyer
- Apr 12, 2005
Shall we look at this with out the childish name calling????
Some posters keep saying "if it is required by OP SPECS".
Ok, which OP Spec?? Please provide the reference.
As for prior OP Specs, before automated OP Specs some Inspector would type (with an actual typewriter) each page of OP Specs. And I know that most Inspectors are not trained typists. The problem was many OP Specs were just wrong/illegal/not correct/etc. Now an OP Spec must come from a computer data base of "FAA Approved" chapters that the POI can choose from. So prior (old - no longer in use or illegal) OP Specs can not be used today.
So again which OP Spec requires/allows an SIC in an aircraft that does not require an SIC in a cargo operation??? I would like to look this one up.
JAFI
it would be in the list of approved aircraft, if none of them require an sic then that is that. Also in section A, they can add the requirement for an SIC if the faa feels compeled to require an operator to do that.
so, go look it up, and tell me what planes they have in there. there is your answer.
Go ahead and log the time though, dont listen to me. I have a nephew that wants to be a pilot. These pilots loggin illegal sic time will just make a job search easier for my nephew.
