O MY GOD, Check out this TAF
rubicon789
KNBG 282121 06015G25KT 9000 BR SCT030 BKN050 OVC080 QHN2960INS VCTS
TEMPO 2202 VRB30G45KT 1600 SHRA BR SCT005 OVC010CB/
BECMG 0204 06040G55 SCT005 OVC010 QNH2900INS
TEMPO 0206 VRB50G70KT 1600 TSRA BR SCT005 OVC010CB
BECMG 0507 VRB115G130KT 0400 +TSRAGR BR SCT005 OVC010CB QNH2860INS
TEMPO 0509 +FC
BECMG 0910 QNH2750INS
TEMPO 0915 +FC
BECMG 1516 120145G175KT 0100 +SHRA BR SCT005 OVC010 QNH2663INS
FM1630 VRB06KT 9999 SCT300 QNH2668INS
FM1830 270140G160KT 0100 +TSRA BR SCT005 OVC010CB QNH2672INS T24/11Z T34/20Z
Sounds like Total devistation if this thing keeps gaining steam... Holy 5hit !!
I guess the eye isn't too bad...
...if you can get there.
-FC doesn't exist nor does -ts because the NWS says "there is no such thing as a light thunderstorm."
Two things that amaze me by this TAF.
1. The winds obviously, but...
2. Check out the pressure between 0500-1600Z. From 28.60 to 26.63! Holy CRAP!!!!
2000Flyer
There is no modifier for TS at all... If you see a -TSRA or a +TSRA then that is modifying the RA part, not the TS. If you don't see a modifier, then it means Thunderstorms with moderate rainshowers.
Maybe a stupid question, but what does this mean?
QNH2668INS
QNH2668INS
QNH is the 'european' or 'military' or WHATEVER term they use to refer to the altimeter. You don't hear people in europe say "altimeter please". They say "Q-N-H please."
Basically its 26.68 inches of merc. In europe they use Millibars.
QPPPP - QNH
Q - indicator for QNH, PPPP - Pressure value.
Measured in hecto Pascal (HPa), 1 Hpa = 1 mB(millibar)
FD
It's all ICAO standard stuff. Same concepts as what we use here in the US, different names. Go ICAO!
Roughly: QFE=absolute alt, QNH=true alt, QFF=density alt, QNE=pressure alt.
Cut and pasted from the web:
PRESSURE SETTING DEFINITIONS
  • QFE:
    The pressure corrected to the official airfield elevation. An altimeter set to the particular airfield QFE reads zero when an aircraft is on the ground (strictly the height of the altimeter above the ground). In the circuit, the height indicated is the height above official airfield datum.
  • QNH:
    The pressure 'reduced' to mean sea level, assuming ISA temperature profile from the station/airfield to MSL. An altimeter set to the airfield QNH reads the elevation of the airfield when on the ground.
  • QFF:
    Barometric pressure 'reduced' to mean sea level, assuming an isothermal atmosphere from the airfield/station to MSL, using current (screen) temperatures. The difference between QFF and QNH can be considerable when atmospheric conditions are significantly different from ISA: i.e. at 'hot and high' airfields.
  • QNE:
    When the ISA mean sea level standard pressure of 1013.2 hPa is set on an aircraft altimeter subscale, the height so indicated upon landing at an airfield is known as the QNE reading. More widely, this is also the PRESSURE ALTITUDE, which is alternatively defined as the height of any level in the international standard atmosphere (ISA-see above), above the level corresponding to a pressure of 1013.2 hPa.
According to the NOAA it is the end of the world.
MOST OF THE AREA WILL BE UNINHABITABLE FOR WEEKS...PERHAPS LONGER. AT
LEAST ONE HALF OF WELL CONSTRUCTED HOMES WILL HAVE ROOF AND WALL
FAILURE. ALL GABLED ROOFS WILL FAIL...LEAVING THOSE HOMES SEVERELY
DAMAGED OR DESTROYED.
THE MAJORITY OF INDUSTRIAL BUILDINGS WILL BECOME NON FUNCTIONAL.
PARTIAL TO COMPLETE WALL AND ROOF FAILURE IS EXPECTED. ALL WOOD
FRAMED LOW RISING APARTMENT BUILDINGS WILL BE DESTROYED. CONCRETE
BLOCK LOW RISE APARTMENTS WILL SUSTAIN MAJOR DAMAGE...INCLUDING SOME
WALL AND ROOF FAILURE.
HIGH RISE OFFICE AND APARTMENT BUILDINGS WILL SWAY DANGEROUSLY...A
FEW TO THE POINT OF TOTAL COLLAPSE. ALL WINDOWS WILL BLOW OUT.
AIRBORNE DEBRIS WILL BE WIDESPREAD...AND MAY INCLUDE HEAVY ITEMS SUCH
AS HOUSEHOLD APPLIANCES AND EVEN LIGHT VEHICLES. SPORT UTILITY
VEHICLES AND LIGHT TRUCKS WILL BE MOVED. THE BLOWN DEBRIS WILL CREATE
ADDITIONAL DESTRUCTION. PERSONS...PETS...AND LIVESTOCK EXPOSED TO THE
WINDS WILL FACE CERTAIN DEATH IF STRUCK.
POWER OUTAGES WILL LAST FOR WEEKS...AS MOST POWER POLES WILL BE DOWN
AND TRANSFORMERS DESTROYED. WATER SHORTAGES WILL MAKE HUMAN SUFFERING
INCREDIBLE BY MODERN STANDARDS.
THE VAST MAJORITY OF NATIVE TREES WILL BE SNAPPED OR UPROOTED. ONLY
THE HEARTIEST WILL REMAIN STANDING...BUT BE TOTALLY DEFOLIATED. FEW
CROPS WILL REMAIN. LIVESTOCK LEFT EXPOSED TO THE WINDS WILL BE
KILLED.
AN INLAND HURRICANE WIND WATCH IS ISSUED WHEN SUSTAINED WINDS NEAR
HURRICANE FORCE...OR FREQUENT GUSTS AT OR ABOVE HURRICANE FORCE...ARE
POSSIBLE WITHIN THE NEXT 24 TO 36 HOURS.
I think the worst part will be the flooding of the above ground graveyards or whatever they call them down there. Can't bury caskets in the ground since they're below sea level anyway. The water is just going to wash away all these above-ground caskets. Wouldn't want to be around to see (or smell) that when they break open!
