NWA/DAL solving the seniority issue
jetflier
Things are very quiet here at NWA, too quiet. The MEC is not tipping its hat on any information from the NWALPA/DALALPA neg.
IMHO, DOH intergration of both seniority lists with a no bump, no flush seems to be a fair way to go.
If not then fences around the equipment be put into place until the most junior pilot on the property retires. Coincidentally, that was what the NWA/Republic merger arbitrated, called affectionately, "The Roberts Award". This ruling finally ended January of 2006.
Personally, I do not want to fly DAL equipment nor bid into any of their bases. All of the NWA pilots that I have talked with agree also feel the same way.
In fact, these pilots all agree that a merger is not wanted, and that NWA is in a very good financial shape right now and a merger with DAL may reverse that positive trend.
An arbitrated ruling on the seniority list intergration certainnally will bring more negatives than positives to the solution for both NWA and DAL.
Career Protection & Progression​
“Cross-Bidding” System ​
    • All pilots at DAL-NWA are provided with two seniority numbers.
    • The first number is their current seniority number used for bidding purposes within their current airline fleet.
    • The second number is an ALPA-issued “system” number used to bid vacancies at the combined carrier. Method for assigning the system number T.B.D. (relative seniority, ratio., etc.)
    • Future new-hires would have their "system" number.
  • Methodology
    • The current DAL and NWA fleets are identified by ship number and/or distinct aircraft types.
    • When bidding vacancies within their original fleet , a pilot’s original airline seniority number would take precedence.
    • “New” aircraft, in terms of either quantity or type, would be open to bids based upon the pilot’s system number.
    • In the event of furloughs, a pilot to have the option of exercising cross-bid rights, using their system number, or accepting furlough pursuant to the PWA.
  • Examples
    • A senior NWA B-747 captain, SN 200, would perhaps receive the numbers 200/325 while a senior DAL 767 captain, SN 200, might have the number 200/400.
    • A new-hire, hired after the merger, would have two identical numbers, say 10,000/10,000.
    • Future 747/A330 vacancies would be first filed by the current NWA pilots.
    • 767 vacancies would be first filled by the current DAL pilots.
    • A-320 vacancies would be NWA, B-737 vacancies would be DAL.
  • Benefits
    • Pilots have the choice, deciding when they want to use their "system" number to bid into new / growth aircraft.
    • Creates the benefits of a merged list without many of the problems associated with outright merger of diverse seniority lists.
    • Creates credible career protections and advancement opportunities for all pilots.
    • The order of precedence between the two numbers effectively creates seat and base protections.
    • Over time, the seniority lists become effectively merged as a greater percentage of pilots, hired after the merger, have identical seniority and system numbers.
Someone sent this concept to me for our use and I think it is the best balance I've seen for base and seat protections which allow for unrestricted growth. This would reduce some, but not all, the pressure on the Merger Committees to resolve the intractable issues of seniority integration.
I can think of possible tweaks, like whether or not aircraft on order are included in each airline's allocation, or are open for future bidding with the combined system number.
Latest rumor is that the NWA and DAL MEC members met, but that there was insufficient movement to continue talks.
The DAL MEC is under pressure from its membership for having already given too much up.
Viper:
Thanks. This idea is free to a good home. Anyone can claim it, make it their own and try to get it up to the people who are negotiating.
Can someone explain what "no bump, no flush" means? I've heard the terms thrown around but don't understand what they mean.
Having had a look at the 'cross bidding system', I must say that looks quite good to me. I was working once for an airline which was merged and such a solution was never presented to us...The stronger union simply won the case.
Suppose it was a DOH merger and the number 1 DL guy wants to fly the 747. He would bump the most junior 747 guy out of his position
Call your reps. They will share info with you, but only over the phone or in person. Nothing in print. As always they will not comment on current negotiations. IE SLI.
That's what you said last time and the board rumor turned out to be true.... Should I re-phrase and Say the meetings happened and the NWA side did not make sufficient movement to keep those involved in the talks substantially engaged?
In the mean time, as rumors of the concessionary position the Delta Reps offered seem to be confirmed, the pressure is mounting on the Delta side to not be as accommodating. Every pilot who has brought the subject up plans on voting against "relative seniority." (which was the position of their own reps)
(Based on comments from line pilots) If there is some middle of the road meeting of the minds, the Delta pilots are not going to vote for it. With an equity pay out weighted towards the senior side of the list, it is certain to be unpopular....
In the interest of our profession I hope that ALPA can make this transaction work for its membership. This thing is perilously close to being USAPA version 2.0.
Regardless, this merger could very well be this pilot's exit from 121 flying.
I stand to lose a lot in this merger and will likely resign once the details are confirmed. None the less, in the interest of our profession I hope that ALPA can make this transaction work for its membership. This thing is perilously close to being USAPA version 2.0.
Are you serious? Why?
Actually, last time he stated that the rumor that they/we had walked away for good was false. Or the the deal was dead.
Read every word he says. The devil is in the detail.
I bet you dont ;)
Joe,
Fin as with many that have to look up at a 11,000+ seniority list, has a lot to weigh. If you are in your 40's and less than 1500 pilots from the bottom, the prospects of a upgrade equating to a decent QOL get less and less.
Each person has to weigh that. As we all know it isn't what it used to be. 80-100K is not bad, but it is not what many have see nor signed on for, especially for people who will be affected by a merger as well as the age 65 implementation.
Joe,
I understand that completely.....that is why I have chosen to stay at the top of the list here at ASA.....The view looks better to me from here than it does at the bottom of the Delta list....
The bottom of a legacy list looks a little scary right now.....
Just like a pilot, you have to adjust for changing conditions. If strong headwinds resulted in insufficient fuel to assure a safe outcome you would be wise to consider a diversion.
No bump/flush is a given in any senario. Who would DOH be fair to? Even relative seniority is a huge concession for most DL guys. An 8 year DL pilot can hold MD-88 Capt, 777 FO, and 757/767 FO system-wide. What do you think his options look like after a relative seniority merger? Much, much worse.
It seems from this side that many on the NW side want everything and want to give up nothing to get it. DL guys seem to realize that, even with the large hit they would take in a realtive seniority deal, compromise will be required in any merger. Not so sure now though as positions seem to be hardening here.
I agree with you though on arbitration. It will probably eliminate any of the benefits the pilot group would receive and it will eliminate the opportunity for both sides to vote on the proposed contract/SLI. It's also been proven that if the larger group doesn't like the outcome, they may take their sheet and go home. It may end up being the only option though if this merger is forced on us.
Fins, guess the grass really isn't as green on the other side as some think, is it?
(ps, it's VERY annoying how you constantly edit your posts after the fact. It hard to reply when the original post has changed three times by the time my reply goes through.)
Joe,
That's kind of ironic. I make 80-100K at ASA am in the top 50% of the list. But from what I'm hearing my QOL and prospects are way better than those of you who got the "dream shot".
And everyone wants to know why we "losers" CHOOSE to stay at a regional.
My thoughts exactly. Those who left are very quick to taunt those of us who choose not to. I'm pretty confident in my decision right about now.
True, but sometimes it is greener. In the past year Delta has announced more growth, more aircraft orders and hired more pilots than they initially forecast. Until there is an agreement & see details we do not know how to shade the grass.
In either event pilots should avoid labelling each other on the basis of decisions made by airline managers. No one with an ATP deserves any less respect than anyone else.
Some have had the misfortune of working for Frank Lorenzo while others went to work for Herb Kelleher and Fred Smith.
Delta is a terrific place to fly, a legitimate #1 choice. Don't get me wrong on that point. My concern is that Delta is not going to offer the same opportunities and some of the intangibles that make Delta such a pleasant place to work might not exist going forward with a contentious merger. Folks tied to Atlanta might have some serious thinking to do if there were not a fence to protect them from displacements.
Sorry about editing. I surf Flight Info while working job #2 and sometimes come back to a thought after getting distracted.
As you know I made the move last year. There is nothing that I regret. I was in the top 300 pilots at ASA. It was a lot to give up at a chance, but with anything, there are no rewards without risk. That was my take on the move across the street.
Short term, you are correct. I loose my vacations of choice, weekends and holidays off, as well as pay.
It year two or three, I will make the same about that I did at ASA. That is under DAL's concessionary contract.
I will be able to see weekends and the holidays off in a few years if I choose to stay on the 88 or go to NYC.
Even with the work rules that are currently in place, I have doubled my time at home, and enjoy it here. It truly is a different world at major. I do not care how you try to color it.
Yes, I could get furloughed, but as with the other points it is short term. Long term I will more than double my earnings and do the type of flying that some, not all of us dreamed of.
Those who regret leaving are looking at the pain that we are now in. Not at the way that it will be in two, five, ten years etc.
A merger will cause some pain, they always do, but I believe that if the pilots can work out the issues, there is a lot of growth coming to the new company.
Fin has the option to quit. He has a company that will make more in two years than he will make here in 10. Many of us do not have a second business that profitable. I only wish I had options like that.
It's not an easy decision to make. Walking away from a $80K+ a year job for one that starts out at less than half that with little job security takes some serious consideration. There are only a few airlines I'd leave for. Luckily for me, my first choice called. Not everyone sees NW as an option they'd leave a regional for. I put a premium on being on the front edge of a hiring wave.
I don't think someone is a loser because they chose to stay at a regional.
