ACL65PILOT
- Dec 6, 2006
http://ntsb.gov/Events/2009/Buffalo-NY/AnimationDescription.htm
Right now the server must be flooded or down, I can't even ping the site,,,
Waiting to take a closer look of the exact timing of the flaps and the roll excursion.
The flap retraction killed them... if the flaps had been left down the plane wouldn't have departed so violently and they would've had a pretty good chance to pull it out. Right wing down, nose down and airspeed rapidly increasing, they would've had the knots to transition to a nose low unusual attitude... but w/ the flaps coming up all bets were off. The plane rapidly departed and fliped over which doomed them to a bad outcome. When you stall an airplane you don't change configuration until you are coming out of it... end of post.
Tailhookah
PS- I never have said that the CA didn't get them into it... the FO didn't help out and probably doomed the flight to a heinous ending.
Hopefully all this sh** comes to a head. The gov't wants more experienced pilots at the controls? Force minimum compensation to attract more experienced talent. Continue to pay $17-25K a year and all that talent is going to go overseas (Middle East, Asia, etc...)
I have never flown this airplane but I can guarantee you guys the glaring problem isn't the retraction of the flaps. The most alarming thing to me is that this captain's reaction to an iminent stall is to pitch 20+ degrees in an effort to correct it. This is basic aviation and stall recovery should be second nature.
If anyone encounters this in the future, simple gouge here: Cram the throttles up to the stops and give up 2-3 degrees. Worry about the trashed engines when you get on the ground.
If this captain had used the correct procedure the flap retraction would have been inconseqential.
