new equipment suffixes
English,
If it does DME/DME updating for postion correction, you would be correct.
If it has GPS and DME update, it's safe to call it /L.
A newer model FMS certified to RNP standards and RVSM certfied would be a Q. Doesn't really specify if it has to have an IRS based platform.
As long as ATC lets you up into RVSM airspace and clears you direct, you have the right combination.
/L...that sounds good, I'll go with it. Thanks!
From NBAA last Night
All: Apparently Boeing and maybe Airbus have been unable to certify many of their airframes IAW AC 90-100. We don't have any other details at this point but the below NOTAM just went out. Will post more as we get.
!FDC 5/7641 (KFDC A0058/05) FDC THE IMPLEMENTATION DATE FOR AIRCRAFT COMPLIANCE WITH AC 90-100 HAS BEEN DELAYED UNTIL SEPTEMBER 29, 2005. IN THE INTERIM, ALL OPERATORS THAT COMPLY WITH THE REVISED AIRCRAFT EQUIPMENT SUFFIXES /E, /G/, /R, /J, /L, AND /Q ARE AUTHORIZED TO FILE AND FLY RNAV SIDS/STARS AND ROUTES. OPERATORS SHOULD COMPLY WITH THE OPERATIONAL GUIDANCE CONTAINED IN AC 90-100.
It was finally verified that all UNS 1C users and better can file /Q as long as they are RVSM, UNS 1 C uses GPS as primary for updating and can provide up to RNP 0.3 for approaches and 1.0 for terminal area and 2,0 for enroute.
If you are flying across the pond you need 2 FMS's to be able to say that you are using GPS as primary for updating, If not you need to file /F or If RVSM then /K
Q
ok so if i am flying a lear 60 with two UNS 1B+'s am I /K or /Q now? I would think Q, but I'm not sure.
We fly a Falcon 100 with a GNS-XLS... RVSM RNP all the bells and whistles... We file Q..
I did too until September 1...are you still able to file that today?
Gezz you guys got me all screwed up now.....
I thought I was a frick'en /Q.
I got to pick up my LOA in TEB on the 7th...I'll ask them!
OK...going to Mexico....use the new FAA suffixes or just go with /W?
I double check that if I were you. It takes more than just having all of the "bells and whistles". Your AFM has to have the appropriate approvals. About the only aircraft that are currently eligible as "/Q" are late model "big" Gulfstreams and Boeing and Airbus stuff. For aircraft like yours and what's his name's Lear 60, you're going to have to wait until the manufacturer issues an appropriate AFM revision or suppliment. Check the NBAA website and some of their airmail threads - I'd bet you lunch that you're actually a "slant L".
'Sled
Hey English, you driving or flying? If you're driving you don't need to use any suffixes. :p If you're flying you should use /L even though the FAA has put off the implimentation for a few weeks - some of the air carriers were having problems getting their aircraft in compliance.
'Sled
Last question...filing a Mexican flight plan outbound...will the Mexican controllers have any idea at all about what /L is? These are FAA suffixes and not ICAO, right?. That's why I started wondering if I should do /W back to the states.
It's my understanding that these suffixes bring us into compliance with ICAO (Another example of the tail wagging the dog?) but I could be wrong here. I'd file /L both directions - I'm sure they'll let you know if they can't accept /L.
'Sled
You also need to have a GPS coverage RAIM program that covers the entire duration of the flight, not merely during the approach AND you must have the appropriate AFM verbage. Just having approved equipment doesn't hack it. Kind'a sort'a like having a RVSM compliant airplane vs. a RVSM LOA.
'Sled
