bigshooter107
- Jun 10, 2006
What is the average bid run solution with 2000 pilots, to update and be" live"... ?
Do you mean, how long does it take before the solution is complete and your line is posted? Probably 15 minutes tops, would be my guess. By the way, I don't know if this makes a difference or not but it's a separate bid solution for each domicile and seat. So it's not really trying to solve 2000 bids at once. Our biggest base has about 315 hard lines right now and has about 415 pilots per seat bidding for hard lines, relief lines, and reserve lines. (Even years back when we had the most block hours to fly, the most I ever saw in our biggest base was about 525 hard lines and 650 pilots per seat.) So it's really solving 425 FO lines, 425 CA lines (for IAH), and then another amount of FO and CA lines for all the other bases. Keeping in mind that CAs bid before FOs.
we had line bidding and it was instant.... with PBS it takes forever to run because the company runs it multiple times and selects the one that is most efficient... so this real time stuff is just non sense... it wont work and is only as good as the people that bid in front of you...its a worthless bell and whistle
I don't think you understand the way smartpref works. There is no need to run it multiple times in smartpref to get the most efficient solutions. The parameters are all set ahead of time and there for any bidder to see. It'll solve to those parameters on the first solution.
Your system requires multiple solutions because of its configuration.
there is no set solution to pbs... thats the point of PBS... it allows the company to run it, switch it to what fits them best.... otherwise they would stick with line bidding
however if this is something the XJT guys want... then fine... tweak what we have and add this real time bid.... but dont scrap all the great stuff we have with our current pbs
What I'm saying is that with smartpref, of the company wants X amount of lines in order to have X amount of reserves for any given day of the month, they set that ahead of time (and you can see those parameters ahead of time), and the software will build to that given set of parameters the first time.
Not all PBS software work the same. It's different from how prefbid works.
the company wants the flexibility to move around..... and that is ok with most of us... its give and take..
