CatYaaak
- Jul 10, 2002
NJA Capt said:Yak,
To use your own quote:
If such statements are indicative of your brainpower, then frankly, you're doomed.
Sir, what is truly ludicrous, is your post.
I purposefully used as few words as possible to NOT be misunderstood. I did not, write, nor imply, that the 40 hour week was that of a corporate pilot. You interpreted that yourself, then proceeded to post based on your misunderstanding.
The 40 hour week is a common data point that we both may refer to. I do NOT know what ever corp pilot schedule is, just as you have no clue what mine is. We can however, compare our respective schedules to one common point, ie…a normal person’s 40 hour week.
Well, excuse me for not picking up on your stunning display of complete, total illogic when you veered off into the realm of irrelevancy and compared yourself to a 40 hr. workweek..something practically no pilot ever works. The issue at hand, of course, was YOUR union leadership...ASAP...comparing JetJets pilots' productivity to NBAA (read; corporate) salary averages in it's statement, which was the subject of the whole discussion and point of comparison. Yes, I must be an idiot....for assuming you could focus on the subject. And you say I meander?
But now that you've compared yourself to secretaries and insurance salesmen (for what reason, who knows), what's next?....perhaps the work schedule of dolphin tank dolphins? I do know by now you won't say anything to back up ASAP's claim, because it's nothing more than ignorant, union pablum that sounds good to the rank and file, but easily disproven because it's based on the idiotic premise that "productivity" in corporate aviation is based simply on hours flown per year, and nothing more. That screams ignorance.
Here's a little irony for you to pass along to whatever genius wrote that stupid apples-to-oranges claim; If "productivity" is measured in simply hours flown per year (as the claim infers), and a company needs crews or airplanes as much as an individual NetJets pilots or aircraft flies, they don't need NetJets at all. In fact, you'd make absolutely no economic sense to them. Even at your current low wages, your frac model is too expensive compared to operating their own department and equipment and hiring their own crews at NBAA salaries for that level of use.
But I sure hope you can follow a line on a taxiway or approach plate better than you can follow a line of debate. Of course, you union devotees aren't used to being disagreed with no matter what your leadership spews, let alone put forth facts to support it. It's all about parotting the same thing over and over and ever more loudly. That's all well and good...it's your house and you can trash it if you want...but only to the point you begin to leak your spewage into the real world by making ludicrous comparisons and arbitrary scablist threats. When that occurs, expect to be challenged.
