Mythbusters, Plane on a treadmill..
Soon someone will come on this board and say that the mythbusters test wasn't fair, wasn't accurate, or didn't depict the myth correctly in some minor fashion.
They will realize they were wrong, but fall back on some minute detail to defend their lack of comprehension.
They will insist that they were right to think it wouldn't fly according to the myth as originaly stated.
Watch
Not sure its a good thing or a bad thing to admit I orginally posted the question here back like two years ago :lol
Now I want to know if someone from here sent in the question to mythbusters to get it tested.
Just think....this thread was probably read by Adam himself while he was reading over "thousands of internet posts about this subject."
Watch
I guess that would be me then. The demonstration portrayed on the show did not meet the elements of the test in a very necessary way. Namely, the conveyor belt (tarp) was not moving as fast as the plane's wheels were moving. As evidence, you can see the traffic cones marking the takeoff distance. If the tarp was being pulled the same speed as the wheels, the plane would not have passed a single cone. Instead, it passed the last one at lift off.
The error in the test design was moving the tarp at takeoff speed and not the plane's wheel speed which was faster.
I have not yet realized an error in my original thinking and do, in fact, insist that a plane tested under the right conditions will not take off.
You've gotta be kidding me. Please tell me that was a joke.
So what if you thought of it in terms of a glider with a tow plane. The tow plane does a low pass (wheels not touching the ground); but, the glider sits on the treadmill. The treadmill is going the opposide direction of the tow plane and the gliders intended takeoff direction. The tow plane is the forward propulsion for the glider (the equivalent of a powered aircraft's engine).
By your theory the tow plane would just stop and fall out of the sky when attempting to pull the glider along the moving treadmill because the glider is unable to move forward because of the opposing movement of the treadmill.
The only limit I could see would be how fast the wheels can spin before ripping themselves apart. It MAY, I reapeat MAY, take a bit more thrust to get the aircraft moving initially; but, ultimately the aircrafts thust will overcome the opposed movement. The wheels would just be spinning twice as fast.
PS. Not sure I would want to get into a plane with the pilot that Adam and Jamie used. He didn't quite seem all there.
Yes and so it starts. :crying:
The fact that the aircraft overcame the normal take off speed should indicate to you that the speed of the conveyor makes absolutely no difference what so ever, uh.
Thank God the truck didn't go faster than 25 mph.
If Jamie hadn't been so vigilant on his speed he might have exceeded the takeoff speed of the aircraft. The aircraft would have then started going backwards creating a tsunami vortex. When the aircraft rolled off the back of the tarp the resultant forces could very well have created a black hole and none of us would be here to post today.
It was no mistake that Jamie was driving. Adam would have killed us all.
Dead or alive we still could have lived normally. RIGHT??
If I had a dog as ugly as you are stupid, I would shave it's a$$ and make it walk backwards...
There must have been a malfuntion of the flux capacitor on the 'airplane' on the show. (Note the very generous use of the term 'airplane'.)
The crux of this 'debate' is all in how the question is worded. Ferinstance, if the plane really was on a treadmill, would the crew still have to be on board 55 minutes prior to departure to do everyone else's job in getting the flight away from the gate? As welll, if the plane really had a relative motion of zero, but was boarded, with the beacon blinking and door closed, would that make Shaneekwa in the tower quit asking us "WHY YOU AINT BORDED YET?!?!" Finally, if in this same situation, i.e. engines turning, but no relative motion, would the delay ultimately be recorded as "Crew SNAFU-Late completion of checklists"?
One more time, especially you PCL, repeat after me "Bernoulli was right: no relative motion, no possible flight..."
Unfrackinbelievable.
All the idiots keep saying "spin the treadmill at the same speed of the wheels".
Not possible. Increasing the speed of the treadmill also increases the speed of the wheels by the same amount... infinite feedback loop until you reach ludicrous speed and go plaid and then all bets are off.
Andy Neill is so stupid he couldn't pour piss out of a boot if the directions were written on the heel.
Your point is so very painfully obvious, but some people just don't get it.
It doesn't have to be "very scientific". It's basic physics, Newton's 3rd law. The RC plane on the treadmill was more conclusive than the full-scale test.
If anything, they should've dragged the "conveyor belt" faster since the nay sayers actually believe the speed of the belt matters. They just gave them more ammo.
-Brett
Is this a joke?
Just focus on keeping the blue side up, Andy. God help us.
My thought exactly. I was saying that while I was watching the show. I wish Jamie would have driven at 75 mph just to prove that the reverse motion of the treadmill has absolutely no bearing on the acceleration of the aircraft.
the only difference between flying 1' above a moving treadmill and taking off on a moving treadmill is the wheels spinning.
so tell me, just how fast do you have to spin the wheels to get the plane to stop in mid air?
-Brett
What was the tire limitation speed on that "airplane"? (once again, note very generous use of term airplane...)
Again, it's ALL in the wording of the orginal theorem: There are two major possible interpretations. First, can the airplane fly if it's relative motion is zero? This is usually what is strongly implied, though not stated, as the criteria for this debate. That is, if the airplane isn't moving forward through the realtive wind, would there be any of the conditions necessary for flight? (Even NASA concludes that flight is a combination of Bernoulli and Newton.) Clearly, no.
The second option, the one actually tested, refers to what would happen if the friction of the wheels and bearings of the "airplane's" landing gear were negligible. Negligible, as in the thrust or power of the airplane was able to overcome that friction and move the airplane forward through the relative wind. For all practical purposes, the Mythbusters guys -two very obvious 40+ year old virgins- did exactly that. The tires of the airplane, which reduced the friction of the object relative to the ground, allowed the power of mighty Rotax engine to propel the "airplane" forward through the relative wind, therefore producing lift around the various airfoils of the "airplane". (Also, I tend to think that the volume of air being moved aft of the "airplane" over the airfoils of the airplane by the propeller also contributed to the flight. [NOTE: Real airplanes have propellers.])
For a counterpoint to the opinion that the landing gear is irrelevant, remove the landing gear from the airplane and firmly attach it to a trailer/sled/moving object that happened to be moving in the opposite direction of the powerplants of the airplane. (You know, similar to the scene where Maverick is riding the motorcycle shaking his fist at the F-14, yet immediatetly before he slams into the approach lights for the opposite runway...) Spin the Rotax, or CF-34x or PW-127, for that matter, and see what happens. I think what would happen would be loud, colorful, and very expensive, but I doubt you would be able to call it flight.
This entire subject boils down to how the question is worded.
so tell me, just how fast do you have to spin the wheels to get the plane to stop in mid air?[/quote]
Missin' the point: Spin the tires at a velocity of zero. With no tires, the airplane is firmly attached to the conveyor belt, it does not get to move forward through the air, it is earthbound.
Now, once the "airplane" is in flight, the tires are nearly as useless as the stewardesses.
I don't think they're virgins. I doubt they've ever been with a woman, though. The show is set in San Francisco.
I agree entirely. Can a plane take off from a convetor belt that is moving faster than the airspeed of the plane. Absolutely.
Can a plane takeoff from a conveyor belt that is moving the same speed as the tires (which will only happen when it is going so fast that tire rotation speed and/or the limits of rolling friction and bearing friction is reached). No because it will cease to make sufficient progress along the belt to achieve the necessary relative wind over the wings. I thought this was the way the original question was posted.
What I saw was that the takeoff distance was relatively unaffected relative to the runway under the belt. It was much greater (doubled?) relative to the belt.
Of course the plane takes off:
F = MA
Yes, I agree that a major source of controversy has been a product of misinterpretation of the original question. However, I'd like to think this question was thought up by Hummer-driving soccer moms at a scrap booking meet who never thought to add things like "frictionless bearings" and "tire limitation speed" into the equation. It was a question for the laymen. One day when you and I are sitting down having a beer, you'll have to explain to me how "tire limitation speed" is of any relevance to the spirit of the question.
With that said, I disagree that the plane having zero relative motion was implied by the original question as there were no elements in the original question that would inhibit forward motion. That is a false assumption by the reader and the whole point of the question to begin with. Think about it, how many no-takeoff people have you spoke with that their first analogy was "imagine a car on a dyno..."?
Of course the plane wouldn't takeoff with zero relative motion! That is so painfully obvious, not even my grandmother would assume that a plane with zero forward motion (relative wind) could take off.
The friction in the bearings are negligible. Yes, if the conveyor belt was spinning backwards at 2000 mph, the bearings would blast out in all directions, killing the pilot and copilot, and there would be no takeoff. If the treadmill accelerated backwards to Vr (or heck even Vr x 2) as the airplane added power, there is not a chance on Earth that the friction from the bearings alone would inhibit forward motion.
Also, you're saying that the airflow from the prop alone on a single-engine fixed high-wing contributes to (even a remote amount of) lift?
Word!
-Brett
