MEI Questions
Immune, if you follow the program you Instructor has, you should do fine.
IMHO teaching in a light twin will kill you quicker than any other airplane. It is normally an underpowered trainer with a student of sometimes unknown ability. Plus, you are maneuvering low and slow and you will be dealing with asymmetrical thrust low and slow.
1. As always - know your aircraft. You cannot teach an aircraft if you do not know that aircraft. With each type, model, engine mfgr, engine model, factory or after market modification you could have a different animal and can and may be operated differently depending on many factors. This is where you dig into the aircraft manual(s) and talk to the mechanics and other pilots.
2. Always expect your student will do something you do not want them to do. In a twin (unlike a single engine trainer) the CG may not put you nose down during a stall (or just send you in a flat spin) especially if you have some one ride in the back to watch. (In a light twin some one in the back watching primary training- NEVER a good idea IMHO).
3. With bigger aircraft you need to know: In a turn on the ground - Will the tail clear if the wing tips do? Some aircraft have longer wings (or a longer tail) – find out. It could save you a dinged aircraft and some money.
4. In any multi-engine aircraft I have found that when an engine quits sometimes either too much gear or too much flaps will kill you. If you have an aircraft with long gear that create too much drag or if the flaps are too large for the single engine power you may have to retract the gear or reduce the flaps. This may not matter unless you are above a certain airspeed, weight, or temperature. Any good aircraft check out could show you the specific flight abilities of that aircraft. But keep in mind that if the aircraft is not performing – you may have missed something – think gear – flaps – cowl flaps –power setting - Prop pitch - etc.
Can you give an example model of twin aircraft which will not recover a stall if it is within CG limits.
Not true in a Seneca II. 2 people up front will require 50-100 lbs of ballast in the rear luggage area.
....or another student in the back...which I find is a VERY good idea IMHO, since we need ballast anyway and that kid will get more than his money's worth out of watching that lesson and learning from his flying partner's mistakes.
Kinda like getting two lessons for the price of one and it makes things easier on the instructor...since the student that has already back-seated has seen the maneuvers before strapping himself into the left seat, I only have to repeat myself 20 times per day instead of 25 or 30. :)
Thanks everyone,
Now, does anyone know the BE-95 like the back of their hand?
Yes, I have a POH/PIM but there are little things those dont tell you only experience does.
Who else has some good info?
:D
Off hand, no. I do recall reading accident reports many years ago about flat spin light twin fatalities in training. And I recall a story about a training sesson that went badly and the aircraft stalled flat so the Instructor reached back and pulled the student watching from the back into the front seat to recover from the stall. Sorry too many years and moves to keep copies.
The Seneca II was never meant to be a primary trainer IMHO. There is a balance problem but the II will climb out on one engine when others will not. Be careful with the extra 200 pounds (one person) of dead weight if you have to climb out on one. I know of a training crash that had an observer. When the engine quit on go around the student almost stalled the twin, the Instructor took over (too late) advanced the throttle and the second engine just took them to the scene of the crash. Had the observer not been there they may have climbed out or may not. I like to err to the safety side. IMHO too many schools "sell" the idea of watching to reduce their training time. I agree watching is a good training method but not in a light twin.
I am not the end all to be all in training. I have my opinions like every one has. I have a "want to live a long time" desire and have been at the outer edge of the line too many times to keep doing it. I have been in situations that later I was told "the aircraft is not suppose to be able to do that whatever bad thing" but it did and the aircraft doesn't always follow the book. In Light twin training - be very careful.
I agree that the PA34 wasn't meant to be a trainer, but I've come around to really liking them. You won't find a light twin that is more stable when flying on a single engine, and I really like that fact that I can still climb on one engine all the way up to 8 or even 10K on a single engine during the hot summers in Phoenix.
Reference single engine go-arounds. We do them all of the time. They are required for the UK-CAA CPL skills test and the Seneca handles them very nicely if properly executed, even in the heat and more often than not with a back seat passenger. It's also very forgiving and tame if the student isn't perfect with the rudder pedals...of course, I'm always right there to prevent a true test of the aircraft's forgiving nature....or lack thereof.
I remember reading the article of which you speak. It was written by an instructor who was doing some work with a student in a Beech Travelair when they entered a spin. The instructor tried everything under the sun to get that aircraft out of the spin, but failed. The aircraft spun to the ground killing the student(IIRC), but the instructor survived to write a fascinating article. It was a goood read and a real eye-opener. I read it on the recommendation of the DPE with which I took my MEI ride. If I can find it, I'll post a link.
EDIT: Here it is.
In a few months time, every multiengine trainer available for rent at KVNY crashed. Different instructors, different students, most pilot error, and the one mechanical, that pilot shoulda rejected the aircraft.
Light twin training is not for the complacent, sloppy, or careless, unless you are really lucky.
On this I can agree I think some of your other statements though are bit disingenuous on the verge of fear mongering.
Just go back to the NTSB accident reports. Keep reading, from what I have read and lived through I think what I said is not "fear mongering". When you read the reports keep a record of how may times the pilots lived. It will be a short list.
Most MEI's are young pilots tring to fill up their logbook. They can and do press safety/legality for an extra hour of time logged or a few more bucks.
Go read 50 or so light twin training accident reports and decide for your self.
Such as the report sqwkvfr posted where they are doing engine cuts below Vmc? Most NTSB reports result in people doing things improperly (almost always the result of bad judgment). Suggesting as you do that having a rear passenger (within weight/CG) is going to lead to a flat spin is disingenius.
One should not be scared of twin instruction provided one flies within the prescribed envelope. If you want to do full power on breaking stalls, cuts below Vmc, etc. Then having a rear passenger is the least of your issues. If you as an instructor are in fear of being in the aircraft then you shouldn't be instructing let alone in the aircraft.
The Seneca II does fine with two up front and no one in the rear. I flew many hours in the Seneca II and III with two on board in the front seats, always within CG.
As for single engine missed approaches in them, no. I once told an FAA inspector "no" when he insisted on doing them during a 135 checkride in the airplane. He told me he'd fail me for refusing to do one. I told him he didn't have a legal leg to stand on, and asked him if he'd like to get out now, or wait until we got back to the airport. He grumbled and said carry on...we did the ride without the missed approach on one (which he can't require in a Part 23 airplane...it's not certified to do so or required to be able to do it).
I did the same thing during a checkride in a King Air 90, and warned the examiner/chief pilot not to pull the engine. He did it anway, and despite having been warned that he wouldn't get the engine back if he pulled it, he gave it a shot. When he learned I was setting up to put the airplane in a field because that was the only option at the time, he demanded, then begged for the power...and was in tears before I let him have it back.
Ride passed...chief pilot educated.
I'd have given him more of a pass if he hadn't tried to insist he'd have done the single engine missed out of a high density altitude airport in the mountains, with passengers on board...in front of the company general manager.
In a light twin like a Seneca II or a Cessna 310, if a missed is required, I won't do it. I'll land between the runways, on a taxiway, after or before the problematic traffic etc...and I'd never teach a student to develop the mentality of taking one around on one engine, either. Bad, bad move.
AC 560, Are you here and now giveing CG and Climb performance of EVERY light twin out there as being safe under your conditions?? Could you put that on paper and sign it?
Having a passenger in a light twin during primary training is fine if all is going well. It is when all is not well that the extra person is a potential CG problem or excess dead weight that could be the difference between climbing/maintaining altitude or not. Can you FORECAST when a problem is going to happen for each flight? How about giving us a winning lottery ticket number?
Take a good look at Part 23 aircraft certification standards (it is poor at best) and remember that your aircraft could be 30 plus years older and you are not a test pilot under controlled conditions.
This reminds me of a discussion with a 100 hour private pilot that wanted me to take a Skyhawk through thunderstorms to attend a meeting. My reply would be the same to you:
"the keys are in the aircraft, Good Luck".
I believe I clearly stated One should not be scared of twin instruction provided one flies within the prescribed envelope. If you are flying in the envelope prescribed one is not going to have an issue.
