wingnutt
...recognize this?
- Mar 31, 2002
Hey Flybet,
Remember when you took off with the severed elevator cables and didn't tell anyone? Only a complete idiot would do that twice in less than 12 hours.
not only does he remember it, he was bragging about it right here on this very forum...
http://forums.flightinfo.com/showthread.php?t=71496
but just in case he dosent recall...
About 2 years ago I flew a caravan out of Cedar Rapids Iowa, my show time was about 9pm or so, DHL guys loaded my airplane I did the weight and balance started the engine and taxied to the runway. I got cleared for T/O so I powered up my PT6, at about 75kts the airplane rotated to about 20 degrees nose up. I tried pushing the yoke forward but the yoke was already full forward. So I began to trim like crazy forward. Got the airplane undercontrol and turned on the AP, then I re-did the weight and balance and after all the calculations I came to the conclusion that it was not a CG problem. Had a bit of a problem on the approach into CVG b/c the yoke had no more forward movement. So I had to use the AP all the way down to the flare. Before departing out of CVG I asked the DHL guys to load my plane a bit nose heavy. Took off and once again, nose went up high, this time I even got a steady stall horn, I just about pissed my self. I tried pushing the yoke and once again and nothing. So I trimed the living hell aout of it. The AP flew all the way back home, once I was on a downwind at CID turned of the AP and realized that I had a complete control failure. I tried banking the airplane, and nothing. So I used the AP once again the capture the LOC and Glideslope, and then basically landed the dang thing with the trim. Two hours later mechanics said it was a miracle that I was on the ground b/c the cables on the trim were broken as well. All the bolts and cables of the airplane were streched, and ripped.....lucky to be alive, someone upstairs must like me.
that or the Darwin award was already taken for the year uke:
You walked away from your Cedar Rapids route and Butch Baxter warned
MRA about you.
you wouldnt be referring to the infamous "runway-extension-at-the-expense-of-my-prop" project, would you now
When MRA took over MAF you were not even on the their payroll anmore!That's why your never got taken over like the rest of their pilots.
yes, but its all MRA's fault
BTW no former MAF pilot ever got fired from Martinaire and the senior MAF guys are still around.
...game...set...match :smash:
