Looks like Gulfstream got the WSJ's attention
Kiss my ass "JimmyKool". MEL is a MEL. Deal with it or serve tacos for a living.
The MEL determines that it's legal. It's the PIC's job to determine it's safe.
Most of the time, an MEL'd item is perfectly safe. Sometimes it isn't, due to conditions or due to another piece of broken equipment. That's where the PIC's judgment and experience come into play.
I'll pick a random example: I had one of the two RMIs crap out on a Beech 1900 a while back. Can it be MEL'd? You bet! Good for 10 days, if memory serves. But there's a catch: If you have a dual generator failure (and I have), that broken RMI is the one that would (normally) still be powered by the battery. If it were inoperative in this scenario, you'd have no nav information and only the wet compass for heading information. On a typical day with clear skies or high ceilings, that's not really an issue, and I've taken planes in that condition. On one of those low-IFR-everywhere days in New England, however, it's not a smart idea. I've refused in that case on the grounds of safety. Nobody fired me.
Do you seriously think I should be fired for exercising sound judgment because the authors of the MEL didn't cover every possible scenario?
No, you have a valid reason for the RMI issue. I'd imagine though the MEL should state somewhere the VFR restriction if that truley is the only heading source in a power loss situation. Anyway, you sound like you have a valid reason for turning down that flight.
Just shutting it down for a broken TCAS is crazy. And a 10,000' ceiling doesn't get you much sympathy.
Some of you people are so addicted to technology, it's scary. You're pilots; you can fly without multiple electronic boxes holding your hand.
Glasspilot:
7,000 plus hours.
FSI instructor. SwissAir Contract
Closed down Independence Air. ACA/Indy 5.5 years.
CRJ exp 4,500 hrs plus
CRJ PIC 1,200 hrs plus
Trubine PIC 3,000 hrs plus
Types: CL-65, B-727
You are right. Not accepting an aircraft with a TCAS MEL'ed is unacceptable. But multiple deferals must be considered. Some pilots "comfort level" is not always the same as others. I happen to be more comfortable flying in icing conditions, while newer guys who flew in FL get a little nervous. My point: Maybe the Capt. had good reason to deny the flight. Maybe Not. I tend to agree with you though. There are always a few pilots in a group who stand out for "ultra" safety reasons. The majority of the other pilots at that company would have probably taken the aircraft, that's why Flight Ops was so P*ssed. Who the heck knows....I'm done.
Glasspilot:
7,000 plus hours.
Types: CL-65, B-727
If you flew out of VRB, then you should know the extremely high risk of midairs in that area. I probably know you, I was in the Saudi contract. I also know my Saudi friends buried one of their own while I was there, due to a midair. I remember at least one midair a year in central FL, just involving the major flight schools. To me, that may be a risk a private pilot is willing to take, but is completely unacceptable in 121 ops. Paying pax on board deserve a higher level of safety. In this captain's opinion, low level flight in central Florida cannot be accomplished with an adequate level of safety without TCAS.
I also don't understand your total abdication of captain's authority. Maybe a captain errs on the safe side, maybe he errs on the dangerous side. But it works best if the guy actually on board is the one best qualified to make those decisions. If you always defer to the company, how can you maintain any level of authority to conduct operations in as safe a manner as you see fit? Would you always call your chief pilot's office to determine an appropriate level of safety? How's that going to work out if his rear is not the one in the pointy end? Seems to me you would want to keep your authority for when you actually need to use it.
Who's right and who's wrong? If that Captain took the plane and had a midair and killed 19 pax wouldn't there be people on FI saying, "Damn, I can't believe he took that Airplane thru central florida with no TCas and pressurization."
Sometimes common sense can out way a MEL.
I am not saying what he did was right, but I can see his side of the story. I know when I flew Corporate out of Cental Florida our main goal was to get above 10,000' fast has hell. We knew how many GA's were flying low level in FL.
Yes, multiple MEL's need discretion, but flying at 10,000 without TCAS is no different that flying at FL370 without TCAS. Might even be safer as there is less traffing right at 10,000.
refer to your regulations, nobody at 370 is allowed to be without a transponder (making ATC separation possible). Below 10, no transponder required for part 91 ops (making see and avoid your only option). Midair collisions below 10 on vmc days in florida happen every year. No flight level midairs come to mind.
Sec. 91.135 Operations in Class A airspace.
(c) Transponder requirement. Unless otherwise authorized by ATC, no
person may operate an aircraft within Class A airspace unless that
aircraft is equipped with the applicable equipment specified in Sec.
91.215.
Sec. 91.215 ATC transponder and altitude reporting equipment and use.
(1) All aircraft. In Class A, Class B, and Class C airspace areas
5i) In all airspace of the 48 contiguous states and the District of
Columbia at and above 10,000 feet MSL
"In this Captain's opinion" you have already flown around low level in central Florida without TCAS, or did you bring a hand held TCAS with you in your PA-44?
The pax deserve the safety of TCAS? No they don't. They deserve the safety of each and every FAR their government sets forth. Those FARs allow for an MEL and that MEL allows for the damn TCAS to be deferred. I should be charging a ground instruction fee here.
As to my "total abdication of Captain's authority"... Where did I do that? I supported the half the panel lights out at night guy. I even supported the RMI is only heading info if the Gens quit guy. I do not support the TCAS is broke so I ain't goin guy...plus he's a GIA weenie so right away I'm sure he's screwing something up.
I know it's tough to make it three whole days without your paper in flight, but put it down and look out the window and do your job.
91.215.
Yeah, ummmm. A transponder is not TCAS.
2006, Brazil, B-737-800 and a Legacy. Boeing crashed and the Legacy landed. Both pilots had passports seized and were held in their hotel for a few months. This happened at FL370.
One of the airplanes had their xponder off. So how is that helping your point?
Combo MELs are something you have to look at and use your judgement on...Just because it's legal doesn't make it smart. MELs are developed as stand alone procedures. When you start compounding them you have to look at the implications of the intermixed items.
My point was never that TCAS isn't great. It's just that it can be deferred or not installed. I'd feel better if it couldn't, but it can.
You're right about multiple MEL's. But a TCAS and a 10,000 foot are not by themselves compatible. The pilot screwed up or the article left out major facts.
I was referring to Florida, not a 3rd world country with atc rules and services that pale in comparison to ours. Midairs below 10 in florida are common, in the flight levels i can't think of any.
In the lower 48, atc is able to provide separation services for at least two reasons; transponders and two-way radios. Between 10 and FL180 transponders are required but not two-way radios (meaning that atc can see those a/c and their altitudes even if your tcas isn't working). Above FL180 a/c are to be in communication too, providing the best atc separation possible. So, I'd much rather be at 370 with no tcas than below 10, perhaps even below FL180.
True, a no transponder a/c below 10 renders your tcas useless, but it also leaves atc with only maybe a primary target. On a nice weekend day in Florida there are tons of aircraft operating below 10, some with transponders, some without. Given this scenario and the combination of an inop tcas and a below 10 restriction, this captain did not feel it was safe because he could easily imagine the worst case scenario...and midair in which there was no warning.
Yes, I personally flew without TCAS while instructing low level in Florida, it was some of the most dangerous flying I've done, and I wouldn't put paying pax in that situation.
The pax only deserve the minimum level of safety guarranteed by the government? I'll bet you any amount of money that you go above and beyond that on every single flight. You do make decisions for yourself, right?
See and Avoid has been scientifically proven to be an inadequate means of collision avoidance. Let's say you're cruising at 250kts, and have a 270 degree field of vision. In 3 miles vis, you've got 22 seconds to see head-on traffic. But if you start looking over your left shoulder and scan each 10 degree segment for three seconds (which you would have to do since collision-course traffic has no relative motion), you would still be looking way left while you just got nailed. The Big Sky Theory is really what's keeping most GA aircraft apart, but that's relying on too much luck for me, particularly in high-density training areas.
My point about captain's authority is, you either give him complete authority to make the best choices as he sees them (be those choices right, wrong, or somewhere in the middle), or you give him no discretion. It's either or. The moment you start second guessing him, firing him for this safety decision but not that, then captain's authority doesn't really exist. You might as well just make him call the chief pilot any time there's a question about safety. And I would guess that a bottom-feeding operation's chief pilot is NEVER going to err on the side of safety. Allowing for complete captain's authority is not a perfect system, but I'll take it over your system.
In RVSM, you need an operable TCAS system. FL370 is in RVSM airspace.
I would assume many on this board are arguing with you because you said a colleague should be fired for exercising "PIC authority." You won't find many friends with that kind of attitude...Captain.
Any pilot can imagine a "worst case scenario" on any flight. A pilot who never flies isn't really a pilot is he? If you can't fly a plane without TCAS then it is because A. you're too lazy to be bothered to look out the window for traffic, or B. you're incompetent.
I would not have fired the pilot. I would have brought him in for additional training. That said, if I was a GIA Chief Pilot in this situation then I would fire every single pilot on the list and then quit.
As for mid air collisions...
29 September 2006; Gol Linhas Aereas 737-800; near Peixoto de Azevedo, Brazil
The aircraft was on a scheduled domestic flight from Manaus to Brasilia when it had a midair collision in the area of São Félix do Xingu with an Embraer ERJ135 Legacy 600 executive jet operated by ExcelAire. The ExcelAire Legacy 600 jet had been on a flight from São José dos Campos to Manaus. After the collision, which damaged the left wing, left stabilizer, and left elevator of the executive jet, the crew of the damaged ExcelAire aircraft was able to land at a nearby military airfield at Cachimbo, Brazil. The 737 subsequently crashed 30 kilometers (19 miles) north of the Peixoto de Azevedo municipality. The Legacy 600 was on the first leg of a delivery flight to the U.S. The 737 aircraft was also relatively new, having come into service with the airline less than three weeks before the crash.
All six crew members and 148 passengers on the 737 were killed. The two crew members and five passengers on the Legacy 600 were not injured.
1 July 2002; Bashkirian Airlines Tupolev 154; near Ueberlingen, Germany
The aircraft was involved in a midair collision involving a DHL 757 while both aircraft were flying at about 36,000 feet (about 11,000 meters). Debris from both aircraft fell in an area near Lake Constance on the German-Swiss border. Both crew members on the DHL 757 and the 57 passengers and 12 crew members on the Tupolev 154 were killed. The 57 passengers on the Tupolev 154 included 44 children. The 757 departed Bahrain and was continuing on to Brussels after a stop in Bergamo in northern Italy. The Tupolev 154 was on a trip from Moscow to Barcelona and had made a stopover in Munich shortly before the accident.
12 November 1996; Saudia 747-100; near New Delhi, India
22 December 1992; Libyan Arab Airlines 727-200; Near Tripoli, Libya
31 August 1986; Aeromexico DC9-32; Cerritos, CA
The DC9 collided with a single engine Piper Archer which had made an unauthorized penetration of controlled airspace. All 6 crew members and 58 passengers were killed. The three occupants of the Piper and 18 people on the ground were also killed.
25 September 1978; Pacific Southwest 727-200; San Diego, CA
The aircraft had a midair collision with a single engine Cessna and crashed. All seven crew members, all 128 passengers, both occupants of the second aircraft, and 13 others on the ground were killed.
1 March 1978; Nigeria Airways F28-1000; Lagos, Nigeria
10 September 1976; Inex Adria DC9-32; Near Zagreb, Yugoslavia
5 March 1973; Iberia DC9-32; Nantes, France
30 July 1971; All Nippon Airways 727-200; northern Honshu, Japan, CA
6 June 1971; Hughes Airwest DC9-31; Near Duarte, CA
9 September 1969; Allegheny DC9-31; Near Fairland, IN
19 July 1967; Piedmont 727; Hendersonville, NC
The 727 was climbing away from the Asheville airport when it hit a Cessna 310 about eight miles (13 km) from the airport. All five crew members and 74 passengers were killed. The three occupants of the Cessna were also killed.
9 March 1967; TWA DC9-14; Near Urbana, OH
The aircraft crashed after an in flight collision with a Beech Baron. All four crew members and 21 passengers on the DC9 were killed. The sole occupant of the Baron was also killed.
16 December 1960, United Air Lines DC8 and Lockheed Constellation, New York, NY
The two aircraft collided over New York with the Constellation crashing in Staten Island and the DC8 crashing in Brooklyn. All seven crew members and 76 passengers on the DC8 were killed. All 50 occupants of the Constellation were also killed.
No you don't. Find me a reg and I'll buy you a beer.
oh, and notice the quotes around my calling myself "This Captain". I was making a point to the guy I was responding to. He referred to himself as "this Captain" in his post and I thought it a tad over the top.
First: I'm am all for Captains discretion. We're talking about on the ground acceptance of an aircraft. The pilot chose to not fly an airworthy airplane. TCAS inop does not ground a plane at his company, your company, or my company. GIA terminates instead of retrains. Guess that place sux. Who knew.
Second: It's not my system. It's the way the whole industry IS. If you guys need a little time catching up that's fine. But at the end of the day when you show up to work tomorrow or next year and the TCAS is broke you're gonna strap in and go fly. You're macho chest thumping isn't going to help you then.
Ever considered the possibility that he had a weak right-seater? Maybe he felt as if he was busy enough managing an airplane with less than ideal crew. Or perhaps coupled with that it was a typical Fla. day with build ups and about a million VFR trainers and doctors out trying to stay out of the clouds in some of the most congested airspace on Earth? And TCAS does display traffic that doesn't also have TCAS provided they have a transponder, so it is still effective in cases where intruding A/C don't have TCAS. Controllers are human and busy as hell down there, not to mention the guys flying around with no Xpdr at all.
And you'll do well to remember that any captain can refuse any airplane he feels like. To me safety sort of requires that I look at all the reasons I shouldn't go, and then measure them against the reasons that I can. Then I make a judgement call. It is that judgement that I get paid to exercise. that's reason enough. One of the fist guys I worked for ( a small cargo operator) told me on the phone once, "if you're not comfortable then it can wait...that's what tomorrow's for". Wherever you ended up, Matt, I'll never forget that.
You say you're all for captain's authority, but you're ok with retraining or firing captains who don't make the "right" decisions. Your logic needs work.
For you, on the ground acceptance of an aircraft is required if it's legal. You've never refused a legal aircraft for safety reasons? If you haven't, you either haven't been PIC for long, or "YOU'RE DANGEROUS!" (Add clicking sound of biting teeth).
In the lower 48, atc is able to provide separation services for at least two reasons...
all the midairs you listed were not in the flight levels in US airspace...are there any?
Ummm. Yeah, I've never refused an airworthy airplane. I've been a PIC for over 6 years,
so I guess that makes me dangerous....no wait, "DANGEROUS!"
...or maybe you're an ipod wearin, backpack totein, frosted hair wonder pilot. One of us is right and it's not you.
No, I guess you're right there. Not many US flight level midairs. Although the one in Germany a few years back was very TCAS related. Doesn't matter though as I'm not arguing that TCAS is bad. I love TCAS. Best device in the plane for safety. Doesn't change the fact that it's in the fricken MEL though does it?
I'm a good bit older than you might think. Anyway, let's try some examples. You're captain on a CRJ200. It's 85 degrees outside, dewpoint 80 (humid as he'll), there's a money line that looks to be in excess of two hours long, and the APU is deferred. Perfectly legal. It's in the MEL. Oh, and you've got 17 wheelchairs--something about a WWI reunion. And the chief pilot just called and said refusing the aircraft is not an option as the company completion factor is in the toilet. Do you go?
Probably doesn't know what a money line is. Probably thinks WWI is something you play on X Box too.
Son, your ego is writing checks your body can't cash!
C'mon guys, you're all missing the opportunity for these great quotes. This is FlightInfo, isn't it?
The PIC is responsible to insure that the flight can be safely carried out with the MELs that are in effect. The PIC made a personal determination that the flight could not be carried out to his level safety. For you or any pilot to armchair QB this guys decision is pure BS! Save it for Colgoon, or Whizknuckle and last not but least Messa! This guy made a decision and paid a heavy price for that decision. You are a managments wet dream!
PBR
P.S. You are the poster boy for a lot of things that are wrong in this industry.
PIC: The tray table is broke and that is BS. I don't work for a place that has that little concern for passenger comfort.
Chief Pilot: The tray table is deferred. That's it. Take the flight or we'll find someone who will.
PIC: Fine, I'm outta here. I can't believe this type of operation even exists.
YOU ALL: How do you not support the PIC dicission? Are you communist? You're DANGEROUS! Oh my gosh, you're what's wrong with this industry....
This is why I shouldn't troll around in the regional threads. You all (the ones posting against flying with a deferred TCAS) are inexperianced shinny jet blah blah blah. I don't care anymore. Take you're stupid RJ's and enjoy you're 100% TCAS rate.
Don't bother to respond as I'm out. Out out out. See ya. Remind me to never fly 121 again.
