Learjet 45 crashes in Telluride
Useless information about a Cessna 150 towing gliders out of TEX...but it's beyond your capabilities...perhaps why it's useless to you. You've been beat out by a Cessna 150. Never the less, you believe the airport should be shut down "once and for all."
This, because you're not up to the task...the same task a beginning pilot in a little Cessna 150 can handle...and thousands of other pilots also handle in high performance equipment, every year.
So I am supposed to be impressed that a pilot in a
C-152 can "do it?" The village keeps calling for you Avbug!
Of course you're not supposed to be impressed. You're supposed to be embarassed that what you find dangerous and impossible is handled by a little old underpowered Cessna 152. You think the airport should be shut down forever because...*fill in your favorite excuse here*...and it's beyond you.
Impressed? No. You really ought to be embarassed...but given your observations thus far, it's unlikely you'll manage that, either.
As stated before, a poor carpenter blames his tools. You blame the airport. There's nothing wrong with the airport...just the pilot who would see it shut down.
THAT is decidedly NOT impressive.
I don't fly the 150 out of Telluride...but then I'm not the one calling for the airport to be shutdown forever, either.
Many pilots regularly fly in and out of there without heartburn...just one here has whined about it.
The Cessna 150 flies out of there regularly, towing gliders; it's based there, as are the sailplanes...and it's a daily activity.
Any one with HALF a brain realizes you cannot tow a glider with a C150 !
Grow the other half, and you'll realize that while you may not be able to tow a glider with a Cessna 150...it's certainly done regularly by people with complete brains...including those operating out of Telluride.
You see Avbug, they're called aircraft limitations. My Gulfstream, and every other jet I have flown, says there is a +-2% runway gradient allowed. Whomever sliced TEX into that moutain did so with "fuzzy math" that somehow proved <2%. Come to think of it, the Rose Bowl is the same way! But someday you'll learn, or perhaps not--the cemetery could always use
another spineless yesman like yourself! You keep going there and bring your lunch to cheer on that super 152 glider tow that you are so fond of.
We fly in and out of KTEX on a regular basis. It is not my favorate airport but it does not need to be closed. You have to be ahead of your airplane and to be man enough to go to your alternate when weather (celing, visabilaty and wind) exceed your personal limits. Since we fly a cat. D aircraft we are limited to VFR we also avoid X-wind over15kts.
They are doing a $52 million dollar revamp of the airport and runway. Runway will be level and there will be overuns with that crushed concrete stuff. It is supposed to be closed at some point for a few months during this project.
I've flown corporate aircraft into KTEX many times, as have thousands of other pilots...we're all able and do it without worry, and do it legally. Everybody it would seem, except for you.
Go figure.
If your limitation is 2.0%...where exactly is your "fuzzy math?" Runway gradient on 09 from the midpoint to the end is 1.5%, with gradient on 27 midpoint to end of 1.7%. You find these numbers in excess of 2%, then?
Forget the little cessna...even though it does with ease what you find to be a daunting task. Forget the thousands of pilots who do it with ease in turbojet and turbopropeller equipment. Forget the fact that the airport is served by a scheduled Part 121 operation. Forget the fact that the field is easily within the 2% limitation that you've cited. Forget the fact that you're wrong on every count. Forget the fact that the runway gradient is being reduced even more by improvements that are presently in progress.
You go right on fearing that airfield (and calling for it's closure) while thousands of others conduct daily, safe operations throughout the year...keep your head buried in the sand, and satisfy yourself with platitudes and calls for the airport's closure...simply because such a simple, popular, busy location is beyond you. You make it safer for everyone else, the farther away you stay.
The slope for RWY 9 is +.26%, the slope for RWY 27 -.26%. The runway gradient is 0%. Telluride is a great airport, and the T shirts are cool.
Just a point of reference, the Falcon 900 is +/- 2.5% but your point is well taken.
What about the OP...........
2 Whiz-kids land 40 feet left of the runway and total a Lear 45 after possibly shooting a Cat A/B only approach, which in turn puts themselves and 9 other pilots out of work at the parent company.
Not so fast, they've been asking the FAA for that money for several years, and if they do get it (they probably won't) it is a several year process. The line guy told me they are resurfacing one of the runways at KDEN, and he think the feds will allocate the money there.
The airport is under a myriad of improvements as we speak if you go to the Telluride Airport Website you can view the Master plan and which phase is currently underway. They plan on reducing or removing it completely the dip and lengthening the runway over 600 feet if all the funds are available.
http://www.tellurideairport.com/master_plan.html
The Company previously mentioned has laid off pilots due to the down turn in the economy like so many. Out of 11 pilots only a small number due to the incident/accident at KTEX. I worked for them and recently spoke with one of the Lear 45/35 Line Captains.
Agreed. Telluride is fine as long as we operate within the envelope. Airnav has some excellent recommendations regarding the airport itself. We operate a G3 and LJ55 in there under VFR straight-in only and NO excessive wind - meaning observing the tailwind limitation and no adverse windshear otherwise it can be bad ju ju...
Hear hear, and rumor has it that the genius captain on this flight was NOT amongst the pilots who were laid off!
My "Brother & Sister" put 2 of my real "Brothers" out of work due to _____________!
Can't wait to read the final report.......
It's getting better-- the crew actually shot this approach TWICE, then balled it up on the runway (or somwhere near the runway) on the second attempt..
From what I heard from one of the people associated with the company. It's because the FAA and NTSB are trying to determine if it was an accident or incident. It seems obvious doesn't it?
I know - go figure...It was totaled.
Don't know what regulations you have been reading but you can depart under Part 91 zero-zero to an airport that is zero-zero and do as many approachs at that airport as you want and then go to your alternate. The only restriction is fuel. Not the smartest thing to do, but legal.
Oh really? So the little tables detailing the approach speeds and such don't apply? And when the say that an approach for that catagory are not authorized, it means nothing?
Good luck with that.
Hung
It sounds as if Gulfstream 2345 is not quite up to speed on what NA means on the approach plate.
But then his profile shows he's pretty new to aviation, so I guess we'll cut him some slack...
Geez!
I remember an FAA inspector in LA telling a story of a Gulfstream captain flying into Burbank well below mins. When questioned, the captain had absolutely no idea about approach mins, alternates, etc.
Might have knew them at one time but after years and years and years of flying, and no one questioning (part 91) ....
Pretty amazing.
Pretty amazing.
Most G-whiz captains are the same..............:laugh:
Heard the Same about the Burbank 'G' Captain. Clay someone or another? Heard he started a magazine or something awhile back.
100-1/2
