FlyingPieceOfSt
Wood You Fly This Plane?
- Dec 20, 2005
I don't know what this "bulletproof CJ-610" talk is about. Maybe I've only flown trash engines on the 24/25s, but all of them were stall susceptible. Push the power up quickly on the ground and the engine farts. Get below .75 at altitude and hit a bump, descend below 240 to re-light one. Then there's the 4 to 6 week spool up time after you introduce fuel on the start. You've also got the stall / surge bleeds that liked to hang up causing a huge bang in the climb on more than one occasion.
The JT12s on the early Sabreliners are much more "bulletproof" as far as I'm concerned. Much better handing airplane to boot. My only complaint about it is the nosewheel steering. Would have been better off with full time limited steer through the pedals and a tiller like larger aircraft.
The early Lears are the kind of airplane you want to have flown for someone else in your past, but not something you want to be flying now.
You have to like the story of a pilot who had only one igniter working between two cj-610's. He found a witch's type broom, dipped it in some Jet-A and had the co-pilot try to start the engine without an igniter...
He lit the broom on fire once the engine started turning over. Once the embers started falling off the broom he placed the broom near the engine inlet. The story says it worked. Must have been a S Florida Air Ambulance Op trying to get home. SCARY!
